9566 connectés
  carte mere + proc
carte mere + proc
n°3067699
frouge
Posté le 11-03-2004 à 08:59:10  profilanswer
J'ai grillé mon Athlon 1800+ sur ma carte mere ASUS A7V333.
Je voulais savoir quel est le CPU le plus puissant accepté par la CM
merci !
n°3067715
shady78
Posté le 11-03-2004 à 09:16:57  profilanswer
http://www.asus.it/support/cpusupport/cpusupport.aspx
The following table shows the support for CPU / Motherboard
CPU  Since PCB  Since BIOS  Memo
Athlon 700 1.01  ALL
Athlon 750 1.01  ALL
Athlon 800 1.01  ALL
Athlon 850 1.01  ALL
Athlon 900 1.01  ALL
Athlon 950 1.01  ALL
Athlon 1000 (200 MHz FSB) 1.01  ALL
Athlon 1000 (266 MHz FSB) 1.01  ALL
Athlon 1100 (200 MHz FSB) 1.01  ALL
Athlon 1133 (266 MHz FSB) 1.01  ALL
Athlon 1200 (200 MHz FSB) 1.01  ALL
Athlon 1200 (266 MHz FSB) 1.01  ALL
Athlon 1300 (200 MHz FSB) 1.01  ALL
Athlon 1333 (266 MHz FSB) 1.01  ALL
Athlon 1400 (200 MHz FSB) 1.01  ALL
Athlon 1400 (266 MHz FSB) 1.01  ALL
Athlon XP 1500+(Model 6)(Palomino) 1.01  1006
Athlon XP 1600+(Model 6)(Palomino) 1.01  1006
Athlon XP 1700+(Model 8)(Thoroughbred) 1.01  1006
Athlon XP 1700+(Model 6)(Palomino) 1.01  1006
Athlon XP 1800+(Model 6)(Palomino) 1.01  1006
Athlon XP 1800+(Model 8)(Thoroughbred) 1.01  1006
Athlon XP 1900+(Model 8)(Thoroughbred) 1.01  1006
Athlon XP 1900+(Model 6)(Palomino) 1.01  1006
Athlon XP 2000+(Model 6)(Palomino) 1.01  1006
Athlon XP 2000+(Model 10)(Thorton) 2.00  1017
Athlon XP 2000+(Model 8)(Thoroughbred) 1.01  1006
Athlon XP 2100+(Model 8)(Thoroughbred) 1.01  1006
Athlon XP 2100+(Model 6)(Palomino) 1.01  1006
Athlon XP 2200+(Model 10)(Thorton) 2.00  1017
Athlon XP 2200+(Model 8)(Thoroughbred) 1.01  1006
Athlon XP 2400+(Model 10)(Thorton) 2.00  1017
Athlon XP 2400+(Model 8)(Thoroughbred) 1.01  1012
Athlon XP 2500+(333 MHZ FSB)(Model 10)(Barton) 2.00  1016
Athlon XP 2600+(333 MHz FSB)(Model 10)(Barton) 2.00  1017
Athlon XP 2600+(266FSB)(Model 8)(Thoroughbred) 1.01  1012
Athlon XP 2600+(333FSB)(Model 8)(Thoroughbred) 2.00  1015
Athlon XP 2700+(333FSB)(Model 8)(Thoroughbred) 2.00  1013
Athlon XP 2800+(333FSB)(Model 8)(Thoroughbred) 2.00  1013
Athlon XP 2800+(333 MHZ FSB)(Model 10)(Barton) 2.00  1016
Athlon XP 3000+(333 MHZ FSB)(Model 10)(Barton) 2.00  1016
Duron 600 (Model 3) 1.01  ALL
Duron 650 (Model 3) 1.01  ALL
Duron 700 (Model 3) 1.01  ALL
Duron 750 (Model 3) 1.01  ALL
Duron 800 (Model 3) 1.01  ALL
Duron 850 (Model 3) 1.01  ALL
Duron 900 (Model 3) 1.01  ALL
Duron 900 (Model 7)(Morgan) 1.01  ALL
Duron 950 (Model 7)(Morgan) 1.01  ALL
Duron 950 (Model 3) 1.01  ALL
Duron 1000 (Model 7)(Morgan) 1.01  ALL
Duron 1100 (Model 7)(Morgan) 1.01  ALL
Duron 1200 (Model 7)(Morgan) 1.01  ALL
Duron 1300 (Model 7)(Morgan) 1.01  ALL
Duron 1400 (Model 8)(Applebred) 1.01  1017
Duron 1600 (Model 8)(Applebred) 1.01  1017
Duron 1800 (Model 8)(Applebred) 1.01  1017
n°3067725
frouge
Posté le 11-03-2004 à 09:21:53  profilanswer
je te remercie ^^
  carte mere + proc
ACHAT carte mere + proc + ramQui veut m'aider à choisir mon proc. et ma carte mère ... ???
Problème de carte mère, procPb de demarrage avec MSI KT4AV-L : proc ou carte mere ?
Question proc et carte mère (A7V8X) ?PC ki demarre plus : comment savoir si c est le proc ou la carte mere?
GROS Probleme carte mere ou proc... !Conseil concernant l'achat : meilleurs proc, carte mere, carte graphiq
proc et carte mèreProc ou carte mère grillé ? (K7S5A + tbird 1.2 Ghz)
Plus de sujets relatifs à : carte mere + proc
