3669 connectés
  Problème de reboot intempestif.
n°4463661
froud
Posté le 23-11-2005 à 17:04:51  profilanswer
Salut !
Voilà, j'ai le jeu Earth 2160 depuis qques jours. Cela fait 2 fois qu'en cours de partie, mon PC s'arrete d'1 seul et redémarre tout seul.
Je pensais à peut etre mon alimentation qui commençait à fatiguer u peu, ms au redémarrage, un rapport d'erreur a été envoyé à Crosoft, elle la page suivante s'est affichée
Stop error caused by a device driver
Symptoms
You are receiving this message because a device driver installed on your computer caused a stop error message. This error message required a restart of your computer. After the restart your computer should continue to operate normally, however the error may re-occur until the problem is corrected.
Cause
A stop error occurs when your computer encounters an error from which it cannot recover. This is usually caused by a device driver which encounters an unhandled exception or performs an illegal operation. When the operating system detects this situation it is stopped to prevent further problems, such as data loss or further system instability.
Resolution
Your error report has been computer analyzed and is unable to determine the exact cause of the error at this time. Since a cause and resolution has not been found your error report will be analyzed by Microsoft and any associated vendors to determine the cause of the error. After a cause has been found and corrected you will receive an updated message the next time you receive this same error with instructions on resolving the problem. We apologize for any inconvenience this error has caused and are working to resolve it as quickly as possible.
Je comprends le message, ms du coup je me demande bien ce qui est la cause de ce pb !! Un problème de driver OK ms lequel ??
Qqun a t il déjà eu ce message ?
n°4465224
froud
Posté le 24-11-2005 à 10:12:00  profilanswer
:bounce:
n°4467383
froud
Posté le 25-11-2005 à 11:28:57  profilanswer
mntnt j'ai ce message là :
Message d'erreur : STOP: 0x0000009C (0x00000004, 0x00000000, 0xb2000000, 0x00020151) ...
Voir les produits auxquels s'applique cet article
Numéro d'article : 329284
Dernière mise à jour : lundi 1 décembre 2003
Version : 1.0
Cet article peut contenir des liens vers des informations en langue anglaise (pas encore traduites).
Pour obtenir une version Microsoft Windows NT 4.0 et Microsoft Windows 2000 de cet article, reportez-vous à l'article 162363 (http://support.microsoft.com/kb/162363/).
Symptômes
Votre ordinateur peut générer le message d'erreur "Stop" suivant sur un écran bleu :
"MACHINE_CHECK_EXCEPTION"
Notez que les quatre paramètres à l'intérieur des parenthèses peuvent varier.
Cause
Ce problème se produit car le processeur de votre ordinateur a détecté une défaillance matérielle irrécupérable et l'a signalée à Windows XP. Pour cela, il a utilisé la fonctionnalité MCE (Machine Check Exception) des processeurs Pentium ou la fonctionnalité MCA (Machine Check Architecture) de certains processeurs Pentium Pro. L'erreur peut être provoquée par l'une des situations suivantes :
• Erreurs de bus système.
• Erreurs de mémoire pouvant inclure des problèmes de parité ou de code de correction d'erreur (ECC).
• Erreurs de cache dans le processeur ou le matériel.
• Erreurs des tampons de traduction (Translation Lookaside Buffers) dans le processeur.
• Autres problèmes matériels détectés spécifiques au fabricant du processeur.
• Problèmes matériels détectés spécifiques au fabricant du matériel
personne n'a d'info plus précise sur le pb ?? :cry:
n°4467427
Snipe_tout
Posté le 25-11-2005 à 11:55:16  profilanswer
teste ta ram avec memtest86+ ...
n°4467635
froud
Posté le 25-11-2005 à 13:49:51  profilanswer
RAS, aucune erreur avec memtest86...
n°4473392
Snipe_tout
Posté le 28-11-2005 à 08:45:48  profilanswer
tes drivers de la carte mère son bien installer ?
Message édité par Snipe_tout le 28-11-2005 à 08:45:56
n°4473461
froud
Posté le 28-11-2005 à 10:09:02  profilanswer
bah oui, il y a 1 nouveau bios dispo ms je ne l'ai pas encore installé, il permet uniquement à la CM d'etre compatible avec les nvx CPU d'AMD.
pr le reste, j'ai installé les nvx pilotes de ma CG.
ms fait nouveau hier, mon PC a fait la meme chose en rippant 1 DVD. j'ai l'impression que ce pb arrive lorsque la machine est tres sollicitée...
n°4473515
Snipe_tout
Posté le 28-11-2005 à 10:43:04  profilanswer
température du processeur kan tu rip ?
n°4473560
froud
Posté le 28-11-2005 à 11:12:27  profilanswer
je ne sais pas, je regarderai ds le bios qd le pb reviendra alors...
merci de ton aide ! :jap:
n°4473655
Snipe_tout
Posté le 28-11-2005 à 12:13:42  profilanswer
non tu prends ce logiciel et pendant que tu rip tu connaitra tes température :
http://www.clubic.com/telecharger- [...] erest.html
C'est un super logiciel qui te permet de tt connaitre en detaille de ton PC
n°4474247
froud
Posté le 28-11-2005 à 16:47:07  profilanswer
bon il doit effectivement s'agir d'1 pb de température du CPU. Je viens de jouer, pas de pb, la t° était stabilisée vers 68°, c'est à dire pas loin de la limite. pr peu que les autres fois il ai pris qques degrés de plus, et c'est surement ce qui a fait rebooter.
merci encore, je te tiendrai au courant ms à mon avis, on dedans là !
n°4474250
Snipe_tout
Posté le 28-11-2005 à 16:49:08  profilanswer
BOn donc la c'est vrai il chauffe beaucoup ...
As tu regarder si ton radiateur n'est pas encrassé de poussière ?
Ou si le ventilos tourne correctement ?
C'est quoi exactement ta config ?
n°4476222
froud
Posté le 29-11-2005 à 14:37:56  profilanswer
Ma config est noyée sur le forum. pr mon ventirad, c'est vrai que c'est 1 peu du bricolage pr limiter le bruit. je verrai pr le nettoyer 1 peu aussi, meme si je l'ai déjà fait il n'y a pa tres lgtps.
n°4476277
Snipe_tout
Posté le 29-11-2005 à 14:58:03  profilanswer
:D j ai un PC qui a 1 moi et un ventilateur Zalman 7700ALCU et il est deja blindé de poussière ;)
n°4476549
froud
Posté le 29-11-2005 à 17:04:41  profilanswer
bon petit coup d'aspi, ça fait pas de mal de ttes façons. ms je me suis surtout aperçu qu'1 de mes ventilos d'extraction d'air chaud ne tournait plus !! 1 mvse connection et voilà le résultat... je les rebrancher, 1 petit S2 en aspiration supplémentaire et je pense que la t° sera plus raisonnable.
en ts cas merci encore ;)
n°4477915
Snipe_tout
Posté le 30-11-2005 à 09:13:32  profilanswer
Ben de rien ;)
On as tous nos petit problème et c'est tjrs plus facile d'avoir des avis différents pour être sur de ne pas se planté
Message édité par Snipe_tout le 30-11-2005 à 09:15:43
n°4478829
Blakkness
Posté le 30-11-2005 à 16:57:20  profilanswer
J'ai le même souci (BSOD "machine_check_exception" ), mais dans mon cas, c'est quand le PC se tourne les pouces qu'il plante !
Exemple, hier je lance eMule -> Crash.
Quand je joue -> aucun pb.
Concernant les T°, tout est bas et memtest ne me sort pas d'erreur.
J'ai 4HDDs, je me demande si le crash n'intervient pas quand l'OS fait appel à un HDD non utilisé (eMule tourne sur un autre disque que mon système par exemple).
Des idées ?
Message édité par Blakkness le 30-11-2005 à 16:58:22
n°4478861
Snipe_tout
Posté le 30-11-2005 à 17:12:26  profilanswer
Oui tres bonne idée regarde en installant emule sur un autre disque ...
n°4478949
DarkFalcon​813
Posté le 30-11-2005 à 17:43:26  profilanswer
Slt. J'ai aussi un pb de redémarrage lorsque je joue a certains jeux. Au début je pensais a la température CPU (proche de 90°C) Mais j'ai rajouté qq ventilos et maintenant dans les jeux je tourne entre 40 et 50°C et sa me le fait tjrs. Les jeux en questions sont GT Legends, Serious Sam 2 et même Train Simulator ! Sachant que je fais passer sans pb le dernier Need For Speed en graphisme a fond, je vois pas d'où peux venir le pb...
Problème => reboot intempestifprobleme de reboot intempestif avec lecteur cd rom
probleme de reboot intempestif, help !!Help Probleme reboot intempestif inexpliquée
Probleme reboot intempestif et ecran bleu ???Problème systeme (reboot intempestif)
Problème Insoluble :( reboot intempestifproblème de reboot intempestif... quand j'utilise mon dvd ou graveur
Probleme de ram ( reboot intempestif)problème de reboot intempestif
Plus de sujets relatifs à : Problème de reboot intempestif.
