3161 connectés
  Boitier
  [Topic Unique] NZXT Hadès : concurrent des HAF 922 et Element G
n°7350251
Fssabbagh
Satsui no Hado
Posté le 03-03-2010 à 08:48:52  profilanswer
Bonjour à tous et bienvenue sur le topic unique dédié au dernier boîtier de NZXT le Hadès.
Spécifications
MODEL Hades Series
CASE TYPE  Mid Tower Steel
FRONT PANEL MATERIAL  PLASTIC
DIMENSIONS (W x H x D) 200 X 430 X 501 mm / 7.87" x 16.9" x 19.7"
COOLING SYSTEM
FRONT, 1 X 200mm red LED (included)
REAR, 1 X 120mm (included)
SIDE, 1 x 200mm (included)
TOP, 2 X 120/140mm (1 include 140mm)
DRIVE BAYS 9 DRIVE BAYS
9 EXTERNAL 5.25" DRIVE BAYS
4 INTERNAL 3.5" DRIVE MOUNTS
Screwless Rail Design
MATERIAL(S) Steel with black finish
EXPANSION SLOTS  7
POWER SUPPLY 500 WATT PS2 ATX 12V 2.0 ( OPTIONAL )
WEIGHT 6.95 KGS (W/O Power)
MOTHERBOARD SUPPORT MOTHERBOARDS: ATX, MICRO-ATX, BABY AT
    *  Expansion galore: Nine 5.25" bay setup or Five 5.25" and Four 3.5"
    * Latest Hardware Support: VGA clearance room for 300mm cards like the ATI 5970
    * Dual 200mm intake Large air system: 200mm front fan, dual top 140mm fan, Side 200mm fan, rear 120mm exhaust. NZXT includes the chassis with all fans except for one top 140mm fan
    * Control the flow: Gaming, overclocking, or office work the dual 8W per channel fan control allows control over the dual 200mm fans that spin up to 150 CFM each
    * Monitor your system: A three C/F temperature display at front panel allows the user to see temperatures inside the chassis even with the door closed. A slant on the door allows for easier viewing from above.
    * Punched side panel: Besides aesthetics, the side mesh and extrusion allows for even greater and ease of wire management on the right side panel
    * Meshed front: 5.25" meshed bays, meshed door, and meshed bottom panel allows for air to flow into the system with ease.
    * Wire Routing: Motherboard punched holes allows for quick CPU bracket removable and optimal wire routing.
    * NZXT Solid State bracket allows for two SSD drives to be installed
    * Pre-drilled water cooling holes on the backplate
    * Front mounted 2 USB, Audio, and E-SATA ports
    * Mounting holes for dual radiator at the top
    * Removable filter at the bottom PSU
prix de 100€ soit le même prix qu'un Coolermaster HAF 922 ou qu'un Thermaltake Element G  ;)
la boîte contenant le matos
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/1.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/2.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/3.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/5.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/6.jpg
Bundle
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/7.jpg
le manuel est écrit en anglais, espagnol, allemand et français
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/8.jpg
Vues sur le boîtiers
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/9.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/10.jpg
contrairement aux autres boîtiers, un filtres anti-poussière est aussi présent sur le 200mm de la porte gauche :
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/11.jpg
Message édité par Fssabbagh le 03-03-2010 à 09:19:25
Messatsu !
n°7350258
Fssabbagh
Satsui no Hado
Posté le 03-03-2010 à 08:54:41  profilanswer
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/12.jpg
à noter l'orientation extrême des pâles rappelant les scythe slpstream modèles très prisés pour leur excellent rapport rpm/cfm
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/14.jpg
vous pourrez mettre un rad watercooling double puisqu'il y a la place pour 2*120 ou 2* 140mm :
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/17.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/18.jpg
Intérieur
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/19.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/20.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/21.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/22.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/23.jpg
installation des hdd :
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/24.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/25.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/26.jpg
Messatsu !
n°7350274
Fssabbagh
Satsui no Hado
Posté le 03-03-2010 à 09:04:44  profilanswer
l'arrière du Hadès :
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/27.jpg
filtre anti-poussière pour l'alim :
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/28.jpg
le trou d'accès au backplate du ventirad est largement assez large pour y avoir accès :
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/30.jpg
Vue sur le 140mm :
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/31.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/32.jpg
les 200mm n'ont pas 1 mais 2 filtres !
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/33.jpg
Montage d'une configuration :
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/35.jpg
http://www.overclockersclub.com/vimages/nzxt_hades_gaming_case/37.jpg
les 200mm débites 140cfm à fond mais sont dotés d'un potentiomètre chacun
Mon avis personnel est le suivant :
-meilleur que le HAF 922 puisque ventilation plus puissante et plus silencieuse avec le potentiomètre, les filtres sont partout présent
-meilleur que les Element G et Element S puisqu'un filtre est aussi présent sur la porte. et les ventilos sont à connexion 3 pins
seul petit regret : les slots d'expansion sont à vis
n°7350298
Fssabbagh
Satsui no Hado
Posté le 03-03-2010 à 09:18:56  profilanswer
test vidéo :
http://www.youtube.com/watch?v=P8cRKXDmxQo
http://www.youtube.com/watch?v=sTOqDhwAD_8
Message édité par Fssabbagh le 03-03-2010 à 09:26:22
n°7351353
Cizia
Posté le 03-03-2010 à 19:59:54  profilanswer
sympa mais laisse une impression de pas finit ...
Message édité par Cizia le 03-03-2010 à 20:03:13
n°7351904
Fssabbagh
Satsui no Hado
Posté le 04-03-2010 à 08:32:06  profilanswer
comment ça  :??:
n°7362148
3rik
Casse-toi pauv' con
Posté le 11-03-2010 à 21:01:28  profilanswer
très moche :o
VDS Signature 850W, Koss SB49, Ventilos ||| Feed-Back ||| Sauve toi, sauve moi, et tu sauras où l'acheter le courage
n°7362203
morbax
Posté le 11-03-2010 à 21:43:04  profilanswer
la qualité des plastiques sur les vidéo a pas l'air terrible dommage avec une meilleur finition il serait pas mal.
Message édité par morbax le 11-03-2010 à 21:43:23
n°7362985
D4rK-MaRv3​D
Black is Beautiful
Posté le 12-03-2010 à 16:03:44  profilanswer
Comme d'hab, NZXT a les bonnes idées niveau design, mais la finition suit pas. :/
Là rien qu'avec les photos ça fait très cheap je trouve. :o
Feed-Back | ACH/VDS
n°7363216
Cizia
Posté le 12-03-2010 à 19:33:53  profilanswer
leur nzxt panzer box a une bonne finition  :)
(le khaos aussi...  mais coute 400e  :D )
Message édité par Cizia le 12-03-2010 à 19:34:32
n°7414421
_M@DCOW_
Posté le 21-04-2010 à 11:00:30  profilanswer
J'ai eu l'occasion de faire un montage de ce produit, bilan :
-Finition plastique trop légère, pour ne pas dire passable.
-Chassie un peu trop fin à mon goût, le Midgard pour 10€ de moins est bien plus agréable/solide.
-Boutons de réglages ventilos ridicules, heureusement qu'ils disparaissent une fois la façade avant refermée.
Spécial coup de gueule : L'absence d'emplacement 2.5" ou 3.5", et aucun adaptateurs fournit bien entendu! :o
Vous auriez du voir ma tronche, j'avais l'air fin avec le SSD en 2.5" à monter dessus.
Bref, le Asgard à 39€ s'en sort bien mieux!
EDIT : Le matin rigoler ça fait du bien : http://media.bestofmicro.com/5/8/245132/original/NZXT%20Vulcan%20%284%29.jpg
http://www.presence-pc.com/actuali [...] can-39014/
Message édité par _M@DCOW_ le 21-04-2010 à 11:02:28
Hack consoles - Xbox 360 - PS3 - Wii
n°7832826
raiton30
LA chance.
Posté le 15-03-2011 à 18:54:29  profilanswer
quelqu'un à ce boitier, j'ai commander ma cfg avec, la semaine prochaine, je prendrai un bon rad de type noctua u12p ou d14, mais j'ai un trés gros doute si ça rentre dans ce boitier, principalement du au fait du pannel avec son fan qui prends de la place...
si quelqu'un peut m'aider ;)
Fookin hell.
n°7840328
raiton30
LA chance.
Posté le 22-03-2011 à 19:06:32  profilanswer
un petit retour sur ce boitier qui ma plutot surpris .
Niveau performance en cooling, je pense que c'est difficile de faire mieux à ce prix, 21 degrés dans le boitier peut import l'usage, avec deux cg.
ensuite les features sont vraiment bien pour un boitier de ce prix, le gestion du câblages excellente, pas eu besoin d'un alim modulaire, tout est caché dérriere via les passages prévu et avec joints en caoutchouc histoire de les protéger. ensuite les fan sont pré-relier au fan controler, un molex et hop, on les contrôler tous(sauf le boitier du pannel qui est branché sur la cm), ensuite les 3 sondes à placer ou l'on veut, plutot fiable, avec le petit ecran lcd qui affiche les temp !.
sans oublier les filtres à poussières partout
j'ai vu plus haut qu'il n'ayait pas de slot 2.5", surement au début, mais maintenant c 'est livré monté sur le boitier pour deux ssd.
Niveau bruit c'est vraiment pas mal, avant j'avais un twelve hundred c'est un avion à coté, le hades s'en sort pas mal ( le ventilo de la face avant  est quasi inaudible).
Par contre y a un gros point noir, le ventilo 200mm du pannel est gros et mal placé, impossible de cassé des gros rad cpu, il faut enlever le ventilo, et du coup la grille n'est plus fixé = gros trou béant ... il est possible de bricoler c'est sur ( prends un ventilo plus petit avec un adaptateur, coler la grille etc.) mais c'est pas à nous de le faire, surtout que nzxt aurait pu régler ce problème en déplacer le ventilo de 3 cm plus bas ..
sans oublier la "grille" de la façade en plastoque ...
bref un très bon boitier pour ce prix :D
Message édité par raiton30 le 22-03-2011 à 20:38:16
Fookin hell.
  Boitier
ecran noir demarrage win 7 et apres desactivation d'la C.G demarage ok[ Topic Unique ] Super-Flower PSUs.
[Topic-Unique] MSI Big Bang FuzionErreur MEMTEST G.Skill DDR3
[topic unique] Samsung SpinPoint M7PC récent, capricieux au boot... Pb Gigabyte/G.skill ?
[Topic Unique] EVGA X58 SLI / SLI LE[Topic Unique] Crucial MX200/BX100/BX200/MX100/M550/M500/M4/C300
[Topic Unique] HD6000 en préparation chez ATIattention memoire G.skill
Plus de sujets relatifs à : [Topic Unique] NZXT Hadès : concurrent des HAF 922 et Element G
