3698 connectés
  Alimentation
  alim corsair VX 550w?
n°5707819
raptor-swa​t
Raptor-fr38
Posté le 10-08-2007 à 18:39:49  profilanswer
salut
est ce que vous connaissez cette alim ?
peut on déjà la trouver en france?
http://www.corsairmemory.com/products/vx.aspx
 [:athome] pour vos infos
n°5709983
raptor-swa​t
Raptor-fr38
Posté le 12-08-2007 à 00:16:42  profilanswer
[:alex684]
pas de feedback?
n°5714957
sanson
Posté le 14-08-2007 à 18:28:03  profilanswer
A t'elle les circuits indépendants ?
n°5715001
delatruel
Posté le 14-08-2007 à 18:51:53  profilanswer
vous avez au moins déjà fait un tour sur le site du fabricant ?
n°5715021
sanson
Posté le 14-08-2007 à 19:02:24  profilanswer
Oui
n°5715650
tita2249
OC-Team
Posté le 15-08-2007 à 00:25:49  profilanswer
Extrait de http://www.corsairmemory.com/products/vx.aspx :
Corsair VX Series Features:
Supports the latest ATX12V v2.2 standard and is backwards compatible with ATX12V 2.01 systems.
Ultra-quiet 120mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying the RPM in response to temperature.
Double-forward switching circuitry design offers maximum efficiency, up to 85% under wide load range.
99% Active Power Factor Correction provides clean and reliable power to your system.
Universal AC input 90~264V automatically scans and detects the correct voltage. No more hassle of flipping that tiny red switch!
Dedicated single +12V rail offers maximum compatibility with latest components.
Over Current/Voltage/Power Protection, Under Voltage Protection, and Short Circuit Protection provide maximum safety to your critical system components.
High quality Japanese capacitors provide uncompromised performance and reliability.
6 Serial ATA connectors
Extra long cables support full tower size chassis.
Standard ATX PS/2 size: 5.9"(W) x 3.4"(H) X 5.5"(L); 150mm(W) x 86mm(H) x 140mm(L)
MTBF: 100,000 Hours
Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick.
Lol il faut bien lire   :ange:
Message édité par tita2249 le 15-08-2007 à 00:28:11
Asus Crossair VI Hero - AMD Ryzen 7 1700@3.9 - G.Skill Flare X@3466CL16 - SLI ASUS GTX770 - Samsung 960 Pro - Corsair HX1000i - Evga DG-87 - Watercooling full custom
n°5716934
raptor-swa​t
Raptor-fr38
Posté le 15-08-2007 à 19:58:15  profilanswer
j'arrive pas à trouver de revendeurs et une idée du prix?
n°5717008
tita2249
OC-Team
Posté le 15-08-2007 à 20:37:42  profilanswer
Pas encore dispo dans la plupart des magasins, il  faut encore attendre un petit peu ;)
n°5717094
delatruel
Posté le 15-08-2007 à 21:25:16  profilanswer
la 450 se trouve à 70€ en allemagne la 550 devrait être dans les 90/100€  ~
n°5717169
raptor-swa​t
Raptor-fr38
Posté le 15-08-2007 à 22:22:21  profilanswer
très intéressant dans si c'est bien dans cette fourchette de prix!! :bounce:
 [:athome]
n°5717807
sanson
Posté le 16-08-2007 à 11:08:33  profilanswer
MTBF: 100,000 Hours
Merci.
Le double forward switching circuitry correspond-il bien à l'indépendance des circuits de conversion 12V et 5V ? Car toutes les Seasonic S12II l'ont alors que les modulaires et les energy ont en plus des dual magnetic amplifiers (mag-Amp) qui pour moi étaient ces fameux circuits indépendants.
n°5836476
rosco
Posté le 18-08-2007 à 17:52:10  profilanswer
Non, le double forward est la topologie employée entre l'étage de découpage et le transfo, c'est la manière d'envoyer la puissance dans le transfo en gros. Rien à voir avec la régulation qui se trouve encore après, c'est une régul couplée classique sur ces modèles là. Les magamps sont des éléments qui permettent d'avoir une régulation indépendante (un sur le 3.3 V et un sur le 5 V).
n°5839441
sanson
Posté le 20-08-2007 à 10:17:41  profilanswer
Merci, voilà qui lève toute ambiguïté.
Pour info, il y a un test ici http://www.silentpcreview.com/article751-page1.html.
  Alimentation
Alim suffissante (420 W) pour config X1950 XTX ?Alim pour nouvelle config?
Alim seasonic S12 et A7n8x : compatible ?550w suffisent-ils pour cette config ?
changer mon alim ou pas ?alim Advance ??
Msi 7600Gs Agp , tout marche sans brancher alim sur connecteur?[alim] claquement fortron
Quel upgrade après CM et alimAlimentation 550W EPS pour rack 3U 19"
Plus de sujets relatifs à : alim corsair VX 550w?
