3759 connectés
  Black screen an white stripe at Win10 start
n°9912428
djeymusic
Posté le 13-08-2016 à 17:17:31  profilanswer
Hi!
I have some troubles with my MSI GTX970 Gaming 4G.
The story:
Sometimes, usually lauching Overwatch, I get no signal from my GPU and I need to restart.
Here, I got the BIOS screen Gigabyte, the windows logo, then... Black screen with just a horizontal white stripe and few blue dots (see the photo).
Starting on the Intel GPU, there is no problem. I made a clean installation of nVidia drivers and it works back.
I was in Canada for a while and I let my cousin try some stuff on my computer.
And the graphic card fell down. I wasn't here so I couldn't try it right after, but it seems to work properly when I came back.
Nevertheless, since I get back my computer, I have this kind of no signal troubles quite often.
In your opinion, is it a software or a hardware problem?
Friendly
Djey
https://s10.postimg.org/f7hg627rd/IMG_20160813_164323.jpg
Message édité par djeymusic le 13-08-2016 à 17:20:43
n°9912436
Andorria
Posté le 13-08-2016 à 17:25:38  profilanswer
Hello :hello:
Short answer : since the gpu fell down, it is faulty, I suggest you to rma as soon as you can.
Message édité par Andorria le 13-08-2016 à 17:26:25
Probleme Sli 780ti | Win10GTX 1080 + AMD Phenom II X4 965 Black Edition ???
FALCON [ WIN10 - PC GAMER ] GTX 1060 à 1050€Besoin de conseils config gaming + dual screen
Phanteks P400S White & vibrationsScreen tearing deux moniteurs
carte graphique conseiller pour tri-screen 2016Ecran Noir avec KFA2 Geforce GTX 970 EXOC Black Edition
Ecran PC pour triple screen
Plus de sujets relatifs à : Black screen an white stripe at Win10 start
