6022 connectés
  Petit soucis technique
n°8526687
shard135
Posté le 26-11-2012 à 09:50:25  profilanswer
Bonjour , d' abord désolé si je me suis planter de section.
J' ai du reformater récement mon pc et j' ai eu deux petits soucis pour lesquels j' aurais besoin de votre aide
1) Lorsque le pc passait en veille la tour s' éteignait mais lorsque je rappuyais sur le bouton d' alimentation le pc se relancais avec la session ouverte : j' en ai déduit que ca venais de la veille hybride je l' ai désactivée ais-je bien fait ?
2) Mon pc crash et m' affiche pas mal de blue screen ces temps ci voici un rapport de whocrashed , que dois-je faire ?
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Mon 26/11/2012 08:18:23 GMT your computer crashed
crash dump file: C:\Windows\Minidump\112612-23166-01.dmp
This was probably caused by the following module: atikmpag.sys (atikmpag+0x79C8)
Bugcheck code: 0x116 (0xFFFFFA800B406240, 0xFFFFF88003E709C8, 0x0, 0x2)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\atikmpag.sys
product: AMD driver
company: Advanced Micro Devices, Inc.
description: AMD multi-vendor Miniport Driver
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmpag.sys (AMD multi-vendor Miniport Driver, Advanced Micro Devices, Inc.).
Google query: Advanced Micro Devices, Inc. VIDEO_TDR_ERROR
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: atikmpag.sys (0xFFFFF88003E709C8)
product: AMD driver
On Mon 26/11/2012 07:49:34 GMT your computer crashed
crash dump file: C:\Windows\Minidump\112612-32370-01.dmp
Bugcheck code: 0x116 (0xFFFFFA800BEC64E0, 0xFFFFF88003E599C8, 0x0, 0x2)
product: AMD driver
On Sun 25/11/2012 08:45:13 GMT your computer crashed
crash dump file: C:\Windows\Minidump\112512-28969-01.dmp
Bugcheck code: 0x116 (0xFFFFFA800756C4E0, 0xFFFFF88003EC29C8, 0x0, 0x2)
product: AMD driver
On Sun 25/11/2012 08:19:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\112512-25162-01.dmp
Bugcheck code: 0x116 (0xFFFFFA8007350010, 0xFFFFF88003E4F9C8, 0x0, 0x2)
product: AMD driver
Conclusion
5 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
D' avance merci a vous pour l' aide
n°8526690
Xenon19
Ubuntu for Human.
Posté le 26-11-2012 à 09:53:48  profilanswer
Tu n'aurais pas Avast d'installé ?
Asus Mini Transformer - Intel Atom X5 X8350 1.44 GHz, 1.92 GHz Turbo - Intel HD 400 - 4 GB memory - 128 GB eMMC - Windows 10.
n°8526693
knives49
Posté le 26-11-2012 à 09:59:43  profilanswer
tes crash vienne d'AMD/ATI, met a jour tes pilotes graphique.
n°8526702
Xenon19
Ubuntu for Human.
Posté le 26-11-2012 à 10:11:22  profilanswer
Non pas forcément j'ai eu le même soucis que lui la semaine dernière et ceci venait de Avast.
n°8534022
shard135
Posté le 02-12-2012 à 17:15:26  profilanswer
Je réup parceque mes soucis ne partent pas
Le problème de la tour qui s' éteind sans vraiment s' éteindre après une unitilisation prolongée ne pars pas : la tour et les néons s' éteignent mais lorsque je rappuye sur l' allimentation ma session se réouvre
Et pour l' autre soucis toujours des petits crash mais les drivers sont a jour
je tien a préciser que je l' avais reformater suite a une infection par un fake logiciel antivirus qui était en fait un virus , lorsque je l' ai remove mon pc se rebootais et crashais sur le bureau
Quequel petit renseignement .configuration gamer a petit prix: aidez moi svp
[Résolu] Soucis sur i3-2370 m plus que 3 thread ??? Lenovo E330Carte graphique petit prix fanless
config amd pour petit joueurPetit test VTX3D HD7870 v2
Nouvelle config gamer après gros,soucis PcSoucis HD7970 Vapor-X
Soucis sur config neuve -HELP-Soucis de mémoire vive / Memtest
Plus de sujets relatifs à : Petit soucis technique
