8474 connectés
  Nouveaux catalyst 9.1!
n°6821581
fodger
ARRRACHHEE TTAAA FFFOUUFFOUNE!
Posté le 29-01-2009 à 17:03:27  profilanswer
http://game.amd.com/us-en/drivers_catalyst.aspx
Voici les changements :
Code :
  1. New Features
  2. This section provides information on new features found in this release of the
  3. Radeon™ Display Driver. These include the following:
  4. • Full OpenGL™ 3.0 support
  5. Full OpenGL™ 3.0 support
  6. This release of ATI Catalyst™ provides full OpenGL™ 3.0 extension support.
  7. The following is a list of OpenGL™ 3.0 extensions added in Catalyst 9.1:
  8. • ARB_framebuffer_object
  9. • ARB_half_float_vertex
  10. • ARB_texture_rg
  11. • EXT_texture_array
  12. • EXT_texture_integer
  13. AMD Chipset Product Support
  14. AMD Chipset Product Support
  15. ATI Radeon™ HD 3300 Series
  16. ATI Radeon™ HD 3200 Series AMD 690 Series Chipset
  17. ATI Radeon™ HD 3100 Series AMD 580X Series Chipset
  18. ATI Radeon™ HD 3000 Series ATI Radeon™ Xpress 1150 Series
  19. ATI Radeon™ HD 2100 Series ATI Radeon™ Xpress 1100 Series
  20. ATI Radeon™ X1250 Series ATI Radeon™ Xpress 200 Series
  21. ATI Radeon™ X1200 Series ATI Radeon™ Xpress 1250 Series
  22. Note: When installing the Catalyst™ Vista driver for Windows Vista,
  23. the user must be logged on as Administrator or have Administrator
  24. rights in order to successfully complete the installation of the Catalyst™
  25. Vista driver.
  26. ATI Catalyst™ Release Note 5
  27. • EXT_transform_feedback
  28. • NV_conditional_render
  29. • WGL/GLX_create_context (for new 3.0 contexts)
  30. • GLSL 1.3
  31. • ARB_color_buffer_float
  32. • ARB_vertex_array_object
  33. • EXT_draw_buffers2
  34. Resolved Issues for Windows Vista and Windows XP
  35. Operating Systems
  36. • “Move to Monitor” option does not work for some Open GL application
  37. • Playing back MPEG2 files may fail to respond when task switching between
  38. virtual desktops in extended desktop mode
  39. • Restoring to factory default, Catalyst Control Center may become unresponsive
  40. when multidesktop is enabled
  41. • Catalyst Control Center: display index number are not the same as Displays
  42. Manager in Graphics Settings
  43. • Catalyst Control Center: Some Catalyst text labels may be missing “General
  44. Settings Option” under Windows Traditional Chinese
  45. • Catalyst Control Center: System may become unresponsive when uninstalling
  46. Hydravision package with all HV aspects checked in multi adapter configurations
  47. • Catalyst Control Center: Enabling "Enable Desktop Manager" and "Enable
  48. Multi Desktop" will cause the following to be displayed in the Windows Task
  49. Manager HydraDM64 and HydraMD64
  50. • Catalyst Control Center: Preparing Help dialog window will come up in
  51. English on other localized Windows operating systems
  52. • About Catalyst Control Center window may display some text corruption,
  53. when launched from the system tray
  54. • Catalyst Control Center stops working when skin is changed to Quicksilver
  55. Resolved Issues for the Windows Vista Operating
  56. System
  57. This section provides information on resolved issues in this release of the ATI
  58. Catalyst™ Software Suite for Windows Vista. These include:
  59. • With some ATI Radeon adapters and Windows Vista 64 systems with more
  60. than 4 GB of system memory the display driver may fail to load and report a
  61. code 43 error
  62. • Some video performance playback may be noticed when using the latest version
  63. of Pixela
  64. • Video combing effects may be noticed during movie playback while fast forwarding
  65. or rewinding
  66. ATI Catalyst™ Release Note 6
  67. • Catalyst Control Center: some screen corruption may be noticed after
  68. enabling 1080p HDMI support and adjusting the scaling options
  69. • Video may not fill secondary display when playing back HD 1080i content
  70. with Overlay Theater Mode enabled
  71. • Launching Medal Of Honor Allied Assault Spearhead game demo may result
  72. in a system stopped working error
  73. • Unable to extend the display to a secondary adapter until the system has been
  74. restarted after enable/disable CrossFire™
  75. • Reinstalling the display driver using the INF method on a multi-display (ATI
  76. Radeon HD 3870 X2, Radeon HD 3870) system may cause the operating system
  77. to fail
  78. • Playing Picture-in-Picture on a DVD with PowerCinema or PowerDVD may
  79. cause the system to halt.
  80. • System may become unstable when mode switching during playback of
  81. blu-ray content using WinDVD
  82. • System becomes unresponsive exiting Windows Media Center while playing
  83. high definition content
  84. • DXVA2 Video Decoder DDI Test failures on R7xx ASICs on Windows Vista
  85. Systems
  86. • Some interlacing may be noticed when fast forwarding a DVD playback
  87. • Catalyst Control Center: system may fail to boot after disabling CrossFire™
  88. with dual ATI Radeon HD 48xx adapters
  89. • System unresponsive on reboot after installing the Catalyst 8.12 driver on ATI
  90. Radeon HD 4800 Series CrossFire™
  91. Resolved Issues for the Windows XP Operating System
  92. This section provides information on resolved issues in this release of the ATI
  93. Catalyst™ Software Suite for Windows XP. These include:
  94. • Catalyst Control Center Runtime does not restart automatically after HydraVision
  95. installation in Windows XP
  96. • Catalyst Control Center: Hydravision tab is not shown in limited user
  97. accounts for Windows XP 64 bit
  98. • Test corruption may be noticed when display is rotated to 'Left (90 ccw)' in
  99. resolutions greater than 1600 x 1200
  100. • Playing back some HD MPEG2 videos will either shows black or show a
  101. reduced Overlay Theater mode on the secondary display
  102. • TV may fail to display an image after installing the display driver with an
  103. HD-TV connected using DVI-HDMI adapter
  104. • Video corruption may be noticed with some DVI monitors during a mode
  105. switch
  106. • On some systems the following ATI warning dialog may be displayed after a
  107. system restore “Not enough displays to enable driver. Add another display
  108. device and try again.
  109. ATI Catalyst™ Release Note 7
  110. • Unable to install SMBus driver on ATI Radeon HD 3200 Graphics with ATI
  111. graphic card and integrated graphics disabled
  112. Known Issues Under the Windows Vista Operating
  113. System
  114. This section provides information on known issues that may be experienced under
  115. the Windows Vista operating system with the latest version of Catalyst™. These
  116. include:
  117. • The ATI Avivo video transcoder does not currently use GPU acceleration
  118. under Windows Vista 64-bit edition
  119. • Catalyst Control Center: error message 'CCC Host Application' may be displayed
  120. when cancelling a transcoding process
  121. • Video combing effects may be noticed during movie playback while fast forwarding
  122. or rewinding
  123. • When using PowerDVD to play certain Blu-ray DVD titles, the lower portion
  124. of the player window may intermittently appear shaky when playing Special
  125. Features
  126. • The Catalyst Control Center 3D settings option, Anisotropic Filtering does
  127. not currently work when running DirectX 10 applications – Anisotropic Filtering
  128. must be enabled within the application
  129. • Some video tearing may be noticed when playing back some DVD titles on
  130. WinDVD with all hardware acceleration options enabled
  131. • Random flashes or some bright pixels/lines may be observed during playback
  132. of some blu-ray titles
  133. • Some flickering in the playback of a Blu-ray title may be noticed when moved
  134. to the extended desktop
  135. • Catalyst Control Center, CrossFire™ Overdrive, changing the GPU Clock and
  136. Memory Clock from the default settings may cause a failure in the “Test Custom
  137. Clocks” test
  138. • With Anti Alias enabled Doom3 will fail to launch on a CrossFire™ system.
  139. • Cyberlink may stop responding and terminate when playing back some H.264
  140. content
  141. • Resuming from suspend mode while playing an HD or Blu-ray title on a system
  142. containing an ATI Radeon HD 46x0 series of product may intermittently
  143. result in a Time-out Detection and Recovery (TDR)
  144. Known Issues Under the Windows XP Operating
  145. System
  146. The following section provides a summary of open issues that may be experienced
  147. under the Windows XP operating system in the latest version of Catalyst™. These
  148. include:
  149. • Only 2 channel audio is heard when playing back multichannel (Dolby
  150. 5.1.DTS) audio through HDMI connector
  151. ATI Catalyst™ Release Note 8
  152. • Corruption may be noticed when running overfly.exe in screensaver mode
n°6821602
bolc
Métal liquide, coule à flots !
Posté le 29-01-2009 à 17:11:49  profilanswer
heeh j'ai regardé ya une ou deux heures, étaient pas encore là. cool :D
n°6821606
littleone
In 64 bits we trust
Posté le 29-01-2009 à 17:12:36  profilanswer
Cool, je vais tester ça ce soir. On verra si ça passe mieux sur Mirror's Edge...  :)
n°6821640
marijuo
Posté le 29-01-2009 à 17:27:07  profilanswer
Bon bah pour ton ceux qui sont en 9.1, et qui joue a GTA 4, changement ou pas ?
Fractal Meshify C / Asrock Z370 Gaming K6 / Intel Core i9 9900K / 4*8Go G.Skill Trident Z RGB@3200 c16/ GeForce RTX 3080 FTW3/ Creative SB Z / Corsair RM750i / Samsung 9801To + 860 Evo 1To /Barracuda 3To
n°6822079
fodger
Posté le 29-01-2009 à 20:21:36  profilanswer
Un petit bench?
n°6822084
chriskenob​y
Que la force soit avec vous
Posté le 29-01-2009 à 20:25:36  profilanswer
[:and garfunkel]
n°6838459
christian
Tout n'est qu'illusion
Posté le 09-02-2009 à 13:31:54  profilanswer
j'ai pas encore testé la 3D mais j'ai déja un bug sur la 2D :(
dans "scaling option" l'underscan/overscan est par défaut à 7-8%
si je le règle à 0% (l'optimum pour mon diffuseur) impossible de sauveagarder ce réglage dans un profil; dés que je change de profil il revient à 7-8% :(
j'en ai marre de devoir retourner dans le CCC dés que je change de profil  :fou:
hd4870x2 + catalyst 8.12assemblage nouveaux pc 2009
catalyst 8.12 powerdvd 8 ultra problemesAvivo Video Converter Catalyst 8.12
nouveaux drivers catalyst 5.13[Topic Unique] Radeon™ Software Adrenalin 2020 Edition ● CG & APU !
Nouveaux pilotes ATI Catalyst 3.0 ICI !nouveaux drivers ATI [catalyst 2.5] vous etes satisfais ou pas?
Nouveaux pilotes catalyst 2.4 a c... !!!Nouveaux pilotes Catalyst 2.4
Plus de sujets relatifs à : Nouveaux catalyst 9.1!
