3619 connectés
  Pb avec les jeux en D3D
n°5922146
reno5
Posté le 01-10-2007 à 12:50:38  profilanswer
bonjour
voila depuis la reinstallation totale du mon PC j ai un pb avec les jeux utilisant le D3D
j'ai a priori un PC a jour avec un driver CM nforce2 a jour , un driver Radeon X800GTO a jour et un directx à jour
mais ca marche pas sur des jeux recents comme HL2 (HLife1 marche)
ci joint mon dxdiag
merci de votre aide
System Information
Time of this report: 9/30/2007, 23:58:44
       Machine name: RENO
   Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
           Language: French (Regional Setting: French)
System Manufacturer: ASUSTeK Computer INC.
       System Model: A7N8X2.0
               BIOS: Phoenix - AwardBIOS v6.00PG
          Processor: AMD Athlon(tm) XP 2600+,  MMX,  3DNow, ~2.1GHz
             Memory: 1024MB RAM
          Page File: 812MB used, 1647MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
  DirectX Files Tab: No problems found.
      Display Tab 1: No problems found. Direct3D 7 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x80004005 (Generic failure) Direct3D 8 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code) Direct3D 9 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code)
        Sound Tab 1: No problems found.
          Music Tab: No problems found.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (n/a)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: RADEON X800 GTO
     Manufacturer: ATI Technologies Inc.
        Chip type: ATI Radeon Graphics Processor AGP (0x554F)
         DAC type: Internal DAC(400MHz)
       Device Key: Enum\PCI\VEN_1002&DEV_554F&SUBSYS_1600174B&REV_00
   Display Memory: 256.0 MB
     Current Mode: 1280 x 1024 (32 bit) (85Hz)
          Monitor: Écran Plug-and-Play
  Monitor Max Res: 1600,1200
      Driver Name: ati2dvag.dll
   Driver Version: 6.14.0010.6719 (English)
      DDI Version: 9 (or higher)
Driver Attributes: Final Retail
 Driver Date/Size: 8/22/2007 04:07:59, 268800 bytes
      WHQL Logo'd: Yes
  WHQL Date Stamp: n/a
              VDD: n/a
         Mini VDD: ati2mtag.sys
    Mini VDD Date: 8/22/2007 04:07:39, 2417664 bytes
Device Identifier: {D7B71EE2-160F-11CF-C46E-0A36A1C2CB35}
        Vendor ID: 0x1002
        Device ID: 0x554F
        SubSys ID: 0x1600174B
      Revision ID: 0x0000
      Revision ID: 0x0000
      Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
 Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
         Registry: OK
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
DDraw Test Result: Not run
 D3D7 Test Result: Failure at step 8 (Creating 3D Device): HRESULT = 0x80004005 (Generic failure)
 D3D8 Test Result: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code)
 D3D9 Test Result: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code)
Sound Devices
            Description: Creative Sound Blaster PCI
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: PCI\VEN_1274&DEV_5880&SUBSYS_80011274&REV_04
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: es1371mp.sys
         Driver Version: 5.01.3612.0000 (English)
            WHQL Logo'd: Yes
          Date and Size: 6/3/2002 11:18:32, 40832 bytes
            Other Files:
        Driver Provider: Creative Technology Ltd.
         HW Accel Level: Full
              Cap Flags: 0xF5F
    Min/Max Sample Rate: 4000, 48000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
               Registry: OK
      Sound Test Result: Not run
Sound Capture Devices
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x41
           Format Flags: 0xCCC
DirectMusic
        DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
     DLS Version: 1.00.0016.0002
    Acceleration: n/a
           Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
                  MPU-401, Hardware (Kernel Mode), Input, No DLS, External
                  MPU-401, Hardware (Kernel Mode), Output, No DLS, External
                  Creative Sound Blaster PCI, Software (Kernel Mode), Output, DLS, Internal
                  Mappeur MIDI Microsoft [Émulé], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  SynthÚ. SW table de sons GS Mic [Émulé], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  MPU-401 [Émulé], Hardware (Not Kernel Mode), Output, No DLS, External
                  Creative Sound Blaster MPU-401 [Émulé], Hardware (Not Kernel Mode), Output, No DLS, External
                  MPU-401 [Émulé], Hardware (Not Kernel Mode), Input, No DLS, External
                  Creative Sound Blaster MPU-401 [Émulé], Hardware (Not Kernel Mode), Input, No DLS, External
        Registry: OK
DirectInput Devices
      Device Name: Souris
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Clavier
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
Poll w/ Interrupt: No
         Registry: OK
USB Devices
+ Concentrateur USB racine
| Vendor/Product ID: 0x10DE, 0x0067
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/5/2004 14:00:00, 57600 bytes
| Driver: usbd.sys, 8/5/2004 14:00:00, 4736 bytes
Gameport Devices
+ Bus PCI
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/5/2004 14:00:00, 68608 bytes
+-+ Port jeu standard
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/4/2004 01:08:22, 10624 bytes
PS/2 Devices
+ Clavier standard 101/102 touches ou clavier Microsoft Natural Keyboard PS/2
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/5/2004 14:00:00, 54400 bytes
| Driver: kbdclass.sys, 8/5/2004 14:00:00, 25216 bytes
+ Pilote clavier de Terminal Server
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 00:55:12, 40840 bytes
+ Souris compatible PS/2
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 8/5/2004 14:00:00, 23680 bytes
+ Pilote souris de Terminal Server
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Connexion au réseau local 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 Kbit/s
Voxware SC06 6,4 Kbit/s
Voxware SC03 3,2 Kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 256.3 GB
Total Space: 302.2 GB
File System: NTFS
      Model: SiI RAID 0 Set 0 SCSI Disk Device
      Drive: F:
 Free Space: 1.4 GB
Total Space: 3.0 GB
File System: NTFS
      Drive: D:
      Model: PIONEER DVD-RW  DVR-106D
     Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (French), 8/5/2004 14:00:00, 49536 bytes
      Drive: E:
      Model: HG3041P VCO510J SCSI CdRom Device
System Devices
     Name: Creative AudioPCI (ES1371,ES1373) (WDM)
Device ID: PCI\VEN_1274&DEV_5880&SUBSYS_80011274&REV_04\4&3B1D9AB8&1&4040
   Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (French), 8/4/2004 00:54:30, 4096 bytes
   Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (French), 8/4/2004 00:55:04, 130048 bytes
   Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (French), 8/3/2004 23:15:22, 140928 bytes
   Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
   Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
   Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (French), 8/3/2004 23:08:04, 48640 bytes
   Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 23552 bytes
   Driver: C:\WINDOWS\system32\drivers\es1371mp.sys, 5.01.3612.0000 (English), 6/3/2002 11:18:32, 40832 bytes
     Name: NVIDIA nForce2 Memory Controller
Device ID: PCI\VEN_10DE&DEV_01EF&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&05
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01EE&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&02
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01ED&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&03
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01EC&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&04
   Driver: n/a
     Name: NVIDIA nForce2 Ultra 400 Memory Controller
Device ID: PCI\VEN_10DE&DEV_01EB&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&01
   Driver: n/a
     Name: NVIDIA nForce2 AGP Host to PCI Bridge
Device ID: PCI\VEN_10DE&DEV_01E8&SUBSYS_00000000&REV_C1\3&13C0B0C5&0&F0
   Driver: C:\WINDOWS\system32\DRIVERS\nv_agp.SYS, 4.12.0001.0436 (English), 4/2/2004 15:40:00, 21760 bytes
   Driver: C:\WINDOWS\system32\NVCOG.DLL, 1.00.0000.0015 (English), 4/2/2004 15:40:00, 32256 bytes
     Name: Pont CPU hôte standard PCI
Device ID: PCI\VEN_10DE&DEV_01E0&SUBSYS_00000000&REV_C1\3&13C0B0C5&0&00
   Driver: n/a
     Name: Contrôleurs hôte IEEE 1394 compatible OHCI
Device ID: PCI\VEN_10DE&DEV_006E&SUBSYS_809A1043&REV_A3\3&13C0B0C5&0&68
   Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 61056 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 53248 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 61824 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 60800 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 23:46:40, 6400 bytes
     Name: Pont PCI vers PCI standard PCI
Device ID: PCI\VEN_10DE&DEV_006D&SUBSYS_00000000&REV_A3\3&13C0B0C5&0&60
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (French), 8/5/2004 14:00:00, 68608 bytes
Device ID: PCI\VEN_10DE&DEV_006C&SUBSYS_00000000&REV_A3\3&13C0B0C5&0&40
     Name: Contrôleur hôte PCI vers USB standard étendu
Device ID: PCI\VEN_10DE&DEV_0068&SUBSYS_0C111043&REV_A4\3&13C0B0C5&0&12
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 26624 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 142976 bytes
   Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (French), 8/4/2004 02:54:44, 77312 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 57600 bytes
   Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 7168 bytes
     Name: Contrôleur hôte USB OpenHCD standard
Device ID: PCI\VEN_10DE&DEV_0067&SUBSYS_0C111043&REV_A4\3&13C0B0C5&0&11
   Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/5/2004 14:00:00, 17024 bytes
Device ID: PCI\VEN_10DE&DEV_0067&SUBSYS_0C111043&REV_A4\3&13C0B0C5&0&10
     Name: NVIDIA nForce Networking Controller
Device ID: PCI\VEN_10DE&DEV_0066&SUBSYS_80A71043&REV_A1\3&13C0B0C5&0&20
   Driver: C:\WINDOWS\system32\DRIVERS\NVENET.sys, 4.14.0001.0416 (English), 1/29/2004 01:45:50, 93764 bytes
   Driver: C:\WINDOWS\system32\NVCOE.DLL, 1.00.0000.0014 (English), 1/29/2004 02:22:48, 31744 bytes
     Name: NVIDIA nForce2 ATA Controller (v2.6)
Device ID: PCI\VEN_10DE&DEV_0065&SUBSYS_0C111043&REV_A2\3&13C0B0C5&0&48
   Driver: C:\WINDOWS\system32\DRIVERS\nvatabus.sys, 5.10.2600.0446 (English), 6/3/2004 10:40:46, 79360 bytes
   Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 6/3/2004 10:40:48, 294400 bytes
     Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0064&SUBSYS_0C111043&REV_A2\3&13C0B0C5&0&09
   Driver: n/a
     Name: Pont ISA standard PCI
Device ID: PCI\VEN_10DE&DEV_0060&SUBSYS_00000000&REV_A4\3&13C0B0C5&0&08
   Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (French), 8/5/2004 14:00:00, 36224 bytes
     Name: 3Com 3C920B-EMB Integrated Fast Ethernet Controller
Device ID: PCI\VEN_10B7&DEV_9201&SUBSYS_80AB1043&REV_40\4&35344E25&1&0860
   Driver: C:\WINDOWS\system32\DRIVERS\el90Xbc5.SYS, 4.31.0000.0000 (English), 8/13/2002 21:27:22, 74338 bytes
     Name: Silicon Image SiI 3112 SATARaid Controller
Device ID: PCI\VEN_1095&DEV_3112&SUBSYS_61121095&REV_02\4&3B1D9AB8&1&5840
   Driver: C:\WINDOWS\system32\DRIVERS\SI3112r.sys, 1.00.0056.0000 (French), 1/12/2006 12:56:56, 102528 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\SiWinAcc.sys, 1.00.0000.0011 (French), 11/1/2004 12:21:32, 10368 bytes
   Driver: C:\WINDOWS\system32\SilSupp.cpl, 3.00.0021.0000 (French), 10/19/2005 12:17:00, 77824 bytes
     Name: RADEON X800 GTO Secondary
Device ID: PCI\VEN_1002&DEV_556F&SUBSYS_1601174B&REV_00\4&102AC5BC&1&01F0
   Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6719 (French), 8/22/2007 04:07:39, 2417664 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0012 (English), 8/22/2007 03:13:01, 49152 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 8/22/2007 04:33:04, 46432 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativckxx.vp, 5/30/2007 18:43:05, 2096 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 4/18/2007 14:19:24, 929 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 4/18/2007 14:19:24, 1311202 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativdkxx.vp, 4/18/2007 14:19:50, 2096 bytes
   Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6719 (English), 8/22/2007 04:07:59, 268800 bytes
   Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0350 (English), 8/22/2007 03:11:38, 450560 bytes
   Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 8/22/2007 03:59:04, 26112 bytes
   Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0523 (English), 8/22/2007 03:47:23, 3091392 bytes
   Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0010.0164 (English), 8/22/2007 03:35:39, 1586816 bytes
   Driver: C:\WINDOWS\system32\atiicdxx.dat, 8/14/2007 23:11:53, 156671 bytes
   Driver: C:\WINDOWS\system32\ativvaxx.dat, 8/22/2007 03:35:20, 3107788 bytes
   Driver: C:\WINDOWS\system32\ativva5x.dat, 8/22/2007 03:35:20, 3107788 bytes
   Driver: C:\WINDOWS\system32\ativva6x.dat, 8/22/2007 03:35:20, 972072 bytes
   Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0008 (English), 8/22/2007 03:56:19, 53248 bytes
   Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 8/22/2007 03:17:54, 17408 bytes
   Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 17:01:04, 24064 bytes
   Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4176 (English), 8/22/2007 03:57:14, 487424 bytes
   Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4175 (English), 8/22/2007 03:58:42, 122880 bytes
   Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2522 (English), 8/22/2007 03:59:26, 143360 bytes
   Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0016 (English), 3/23/2007 22:23:23, 77824 bytes
   Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2512 (English), 8/22/2007 03:58:56, 43520 bytes
   Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0064 (French), 8/22/2007 03:19:38, 266240 bytes
   Driver: C:\WINDOWS\system32\atifglpf.xml, 4/12/2007 03:33:47, 7069 bytes
   Driver: C:\WINDOWS\system32\ATIDEMGX.dll, 2.00.2789.38075 (French), 8/22/2007 04:09:12, 352256 bytes
   Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.6847 (English), 8/22/2007 03:21:01, 5435392 bytes
   Driver: C:\WINDOWS\system32\atiok3x2.dll, 6.14.0010.0001 (French), 8/22/2007 03:15:37, 172032 bytes
   Driver: C:\WINDOWS\system32\atioglx2.dll, 6.14.0010.6847 (English), 8/22/2007 03:48:15, 8306688 bytes
   Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4005 (English), 8/22/2007 04:07:22, 307200 bytes
   Driver: C:\WINDOWS\atiogl.xml, 5/3/2007 19:52:52, 11557 bytes
Device ID: PCI\VEN_1002&DEV_554F&SUBSYS_1600174B&REV_00\4&102AC5BC&1&00F0
DirectX Components
   ddraw.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 266240 bytes
 ddrawex.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 27136 bytes
   dxapi.sys: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 10496 bytes
    d3d8.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 1179648 bytes
 d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 8192 bytes
    d3d9.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 1689088 bytes
   d3dim.dll: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 825344 bytes
 d3dramp.dll: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 590336 bytes
   d3drm.dll: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 350208 bytes
  d3dxof.dll: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 34816 bytes
   dplay.dll: 5.00.2134.0001 French Final Retail 8/5/2004 14:00:00 33040 bytes
  dplayx.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 24064 bytes
 dpwsock.dll: 5.00.2134.0001 English Final Retail 8/5/2004 14:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 57856 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 30208 bytes
  dpnsvr.exe: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 18432 bytes
   dpnet.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 3584 bytes
 dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 3584 bytes
 dpvoice.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 213504 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 83456 bytes
  dpvvox.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 116736 bytes
  dpvacm.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 French Final Retail 8/5/2004 14:00:00 54032 bytes
  dinput.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 165376 bytes
 dinput8.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 187904 bytes
   dimap.dll: 5.01.2600.0000 English Final Retail 8/5/2004 14:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 French Final Retail 8/5/2004 14:00:00 395264 bytes
     joy.cpl: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 70144 bytes
   gcdef.dll: 5.01.2600.0000 French Final Retail 8/5/2004 14:00:00 77824 bytes
     pid.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/4/2004 01:08:22 10624 bytes
  dsound.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 1294336 bytes
  dswave.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 19456 bytes
   dsdmo.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 72192 bytes
  dmusic.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 104448 bytes
  dmband.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 61440 bytes
   dmime.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 35840 bytes
 dmstyle.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 105984 bytes
 dmsynth.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 82432 bytes
   dx7vb.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 619008 bytes
   dx8vb.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 1227264 bytes
 dxdiagn.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 2113536 bytes
   mfc40.dll: 4.01.0000.6140 English Final Retail 8/5/2004 14:00:00 924432 bytes
   mfc42.dll: 6.02.4131.0000 English Final Retail 8/5/2004 14:00:00 1028096 bytes
 wsock32.dll: 5.01.2600.2180 French Final Retail 8/5/2004 14:00:00 25088 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/5/2004 14:00:00 70656 bytes
 devenum.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 59904 bytes
  dxmasf.dll: 6.04.0009.1133 French Final Retail 8/24/2006 13:17:20 500278 bytes
mciqtz32.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 35328 bytes
 mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/5/2004 14:00:00 148992 bytes
   msdmo.dll: 6.05.2600.2180 English Final Retail 8/5/2004 14:00:00 14336 bytes
  encapi.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 20480 bytes
    qasf.dll: 9.00.0000.3250 French Final Retail 8/5/2004 14:00:00 237568 bytes
    qcap.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 192512 bytes
     qdv.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 279040 bytes
    qdvd.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 386048 bytes
   qedit.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 563200 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/5/2004 14:00:00 733696 bytes
  quartz.dll: 6.05.2600.2749 French Final Retail 8/30/2005 05:55:43 1293312 bytes
 strmdll.dll: 4.01.0000.3936 French Final Retail 8/24/2006 13:19:40 246814 bytes
 iac25_32.ax: 2.00.0005.0053 English Final Retail 8/5/2004 14:00:00 199680 bytes
  ir41_32.ax: 4.51.0016.0003 English Final Retail 8/5/2004 14:00:00 848384 bytes
 ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/5/2004 14:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/5/2004 14:00:00 338432 bytes
 ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/5/2004 14:00:00 755200 bytes
 ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/5/2004 14:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/5/2004 14:00:00 183808 bytes
   ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/5/2004 14:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 204800 bytes
      ks.sys: 5.03.2600.2180 French Final Retail 8/3/2004 23:15:22 140928 bytes
  ksproxy.ax: 5.03.2600.2180 French Final Retail 8/4/2004 00:55:04 130048 bytes
  ksuser.dll: 5.03.2600.2180 French Final Retail 8/4/2004 00:54:30 4096 bytes
  stream.sys: 5.03.2600.2180 French Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 French Final Retail 8/4/2004 00:58:40 5376 bytes
   mspqm.sys: 5.01.2600.2180 French Final Retail 8/4/2004 00:58:42 4992 bytes
 mskssrv.sys: 5.03.2600.2180 French Final Retail 8/4/2004 00:58:42 7552 bytes
  swenum.sys: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/5/2004 14:00:00 118272 bytes
msvidctl.dll: 6.05.2600.2180 French Final Retail 8/5/2004 14:00:00 1433600 bytes
  vbisurf.ax: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 30720 bytes
   msyuv.dll: 5.03.2600.2180 English Final Retail 8/5/2004 14:00:00 17408 bytes
wstdecod.dll: 5.03.2600.2180 French Final Retail 8/5/2004 14:00:00 51200 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Transformateurs de répartition de données WDM:
Suppresseur d'écho acoustique (Noyau Microsoft),0x00000000,0,0,,
Synthétiseur de table de sons GC noyau Microsoft,0x00200000,1,1,,5.03.2600.2180
Synthétiseur DLS du noyau Microsoft,0x00200000,1,1,,5.03.2600.2180
Filtre de décodeur DRM (Noyau Microsoft),0x00200000,1,1,,5.03.2600.2180
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Codec Intel IYUV,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Vidéo 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
Creative Sound Blaster PCI,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Creative Sound Blaster MPU-401,0x00200000,1,0,quartz.dll,6.05.2600.2749
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Synthé. SW table de sons GS Mic,0x00200000,1,0,quartz.dll,6.05.2600.2749
Périphériques de capture de flux WDM:
,0x00000000,0,0,,
Creative Sound Blaster MPU-401,0x00200000,2,2,,5.03.2600.2180
Creative Sound Blaster PCI,0x00200000,2,2,,5.03.2600.2180
Périphériques de répartition de rendu WDM:
,0x00000000,0,0,,
Périphériques de répartition de mélangeur WDM:
Mélangeur audio Wave de noyau Microsoft,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Creative Sound Blaster PCI,0x00200000,1,0,quartz.dll,6.05.2600.2749
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: Creative Sound Blaster PCI,0x00200000,1,0,quartz.dll,6.05.2600.2749
Périphériques système répartis WDM:
MPU-401,0x00200000,3,2,,5.03.2600.2180
Creative Sound Blaster PCI,0x00200000,10,2,,5.03.2600.2180
n°5922158
G3BO
Posté le 01-10-2007 à 13:02:50  profilanswer
salut
y'a de forte chance que le pb vienne du driver ati si ta carte graphique est en port AGP (catalyst 7.9 ou encore pire le catalyst 7.8 sont non compatible avec l'agp
regardes ce topic, tu devrais t'y retrouver ;)
n°5922163
reno5
Posté le 01-10-2007 à 13:06:54  profilanswer
probleme d'image lors d'un demarrage de jeux Reboot pendant les jeux et vidéos
Configuration dédiée jeuxavis sur cette config : est elle (trés) bonne ? (jeux, 700€)
Plantage Jeux 8800 GTS 320Carte milieu de gamme pour jeux/3D environ 150€
Blocage machine sur les jeuxProbleme avec ATI X200 , impossible de lancer des jeux sur steam
Achat de jeux gamecube allant de 10 a 15E l'unité, proposé!!Probleme de redemarrage lors de jeux en 3d
Plus de sujets relatifs à : Pb avec les jeux en D3D
