5745 connectés
  Carte graphique 8800 compatible ?
n°7867377
luapol
Bien le bonjour !
Posté le 16-04-2011 à 11:38:03  profilanswer
Bonjour, j'aimerais juste savoir si cette carte graphique pourrais marcher et être compatible avec ma configuration =D
http://www.priceminister.com/offer [...] hique.html
Voilà ma config
Carte mère ->
Property Value
Manufacturer FUJITSU SIEMENS
Model P5SD1-FM2
Version Rev 1.xx
Serial Number MB-1234567890
North Bridge SiS 649 Revision 10
South Bridge SiS 965 Revision 10
CPU Intel(R) Celeron(R) CPU 2.93GHz
Cpu Socket Socket 775 LGA
System Slots 4 PCI
Memory Summary
Maximum Capacity 4096 MBytes
Memory Slots 2
Error Correction None
Ma carte graphique ->
Property Value
PAUL (FUJITSU SIEMENS P5SD1-FM2)
Video Adapter NVIDIA GeForce 6200SE TurboCache(TM)
Video Processor GeForce 6200SE TurboCache(TM)
Adapter DAC Type Integrated RAMDAC
PCI ID 0x10DE / 0x0162 (Nvidia Corp / GeForce 6200SE TurboCache(TM))
PCI sub ID 0x107D / 0x5A39 (Leadtek Research)
Memory 256 MBytes
Performance Level 3D Applications
Core Clock 350 MHz
Memory Clock 500 MHz
BIOS String Version 5.44.02.24.68
BIOS Date 04/28/05
PnP Device Id PCI\VEN_10DE&DEV_0162&SUBSYS_5A39107D&REV_A1\4&797C7A&0&0008
Video Mode Description 1152 x 864 x 4294967296 couleurs
Driver Version 6.14.12.7051
Driver Date 2011-03-26 08:34:00
Core Temperature 82 °C  (179 °F)
DirectX DirectX 9.0
CPU ->
Property Value
Summary
Number of Logical Processors 1
Number of Physical Processors 1
CPU #1 Intel Celeron 341
CPU Name Intel(R) Celeron(R) CPU 2.93GHz
CPU Code Name Prescott
Vendor GenuineIntel
Number of Bits 64
Instruction Set MMX, SSE, SSE2, SSE3, ET64
Platform Name Socket 775 LGA
Revision E0
Technology 90 nm
Original Clock 2933 MHz
Original System Clock 133 MHz
Original Multiplier 22.1
CPU Clock 2941 MHz
System Clock 133.4 MHz
FSB 533.4 MHz
Number of Cores 1
Core #1
Speed 2933.8 MHz
Multiplier 22.0
Virtual Technology Supported No
Hyper Threading Supported Yes
Cache
L1 Data Cache 16 KBytes
L1 Trace Cache 12 Kµops
L2 Cache 256 KBytes
n°7867506
chermositt​o
Posté le 16-04-2011 à 13:29:00  profilanswer
attention les GTS il y en a avec seulement 320mo de mémoire. Bien prendre celle avec 640mo.
Votre processeur sera surement largué. Achetez sur Ebay un Pentium série 9 à 3ghz au minimum. Genre 930, 940, 935.  Le 3,2 ghz reste abordable. le 3,4 ou 3,6 sont chers pour ce que c'est. Ca dépend de combien de temps vous voudriez gardez encore ce pc. Si vous choppez un pentium D @3,4 à 45 euros c'est cher mais c'est vous qui voyez.
Maintenant va se poser le problème de l'alim. C'est sur   qu'elle ne supportera  tout ce changement.
J'ai vu deux trois fujitsu-siemens. C'est pas trop pourri mais c'est quand même le minimum syndical dans tous les domaines.
Mais à ce compte , mettons que vous commencez par changer le processeur, en admettant que votre carte mère le permettent, la question sera après : qu'elle est la CG la meilleure que l'on peut mettre sans être limité par le CPU. Or actuellement le cpu est très très insuffisant.
Donc voyez le proce et ensuite la CG. Sinon changez tout.
Proce 45€
CG 100€
Alim : 55€
C'est moins cher qu'une config complète mais c'est le maximum et en fin de vie. Vous ne pourrez plus faire évoluer votre PC après. Alors peut-être une nouvelle carte mère + proce , par rapport au votre il n'y aura pas photos quel qu'il soit + CG à 100€ ou moins selon vos finances.
Il y a des licences Seven 64 bits pro sur Ebay à 70 euros.
Là vous pouvez prendre une cm pas trop chère un bon processeur et une cg correcte d'occase , quitte à en changer dans un an ou deux.
Rester sur la base fujistu c'est une impasse quand même.
Message édité par chermositto le 16-04-2011 à 13:39:40
Fonctionnement carte graphique et RAM (allocation)video HD sous linux + jeux : quelle carte moyenne gamme ?
probleme carte graphiqueChangement carte mère
Choix d'une carte mère pour i7 2600La meilleur carte graphique compatible pour mon ordinateur
Plus de sujets relatifs à : Carte graphique 8800 compatible ?
