5346 connectés
  ATI Catalyst 3.4
ATI Catalyst 3.4
n°2447531
Gnaag
Posté le 16-05-2003 à 00:52:36  profilanswer
New Drivers from ATI & NVIDIA
Both ATI and NVIDIA provided us with new drivers for this review; ATI gave us their new Catalyst 3.4 drivers while NVIDIA provided us with their new Detonator FX drivers (44.03).
The Catalyst 3.4 drivers provided us with a couple of problems, the most noticeable ones were the following:
1) Performance under Doom3 was horrible, significantly lower than the older Catalyst 3.2 drivers. These drivers would also cause the game to crash in a repeatable fashion.
2) There were serious lighting issues in Splinter Cell as well as degraded performance, an example of the lighting issues can be seen below:
Note that you should not see the light from the window below through the character's head which is what this picture shows
NVIDIA's Detonator FX drivers will be publicly available on May 14th and will improve performance across the board for all FX cards, we will be following up with a performance article later this week entailing the exact performance improvements you can expect from the Detonator FX drivers. We encountered no issues with the drivers, and we're glad NVIDIA finally changed their anisotropic filtering quality settings to match up with ATI's (as well as fix the image quality issues we've been griping about all this time):
Anandtech.
n°2447575
Alpha Lead​er
Do, or do not. There's no try.
Posté le 16-05-2003 à 02:39:56  profilanswer
oui je sais ;) Clubic.com :)
n°2447578
Antar
Ritualiste Cosmogone /...\
Posté le 16-05-2003 à 02:58:03  profilanswer
n°2447581
Tetedeienc​h
Head Of God
Posté le 16-05-2003 à 03:05:29  profilanswer
  ATI Catalyst 3.4
Problème ATI 9600Pro et Drivers CatalystATI Catalyst versus non Catalyst
ATI Rage Pro 128, quels Catalyst ?==> Probleme Driver ATI (catalyst 2.5, 3.0, Omega ect..)
[ATi Radeon & Catalyst] : où est passée la fonction rotation ?Nouveaux pilotes ATI Catalyst 3.0 ICI !
ATI Catalyst et Radeon MobilityNoob Ati : Catalyst ET panels Hercules ?
New Driver ATI CATALYST 3.0
Plus de sujets relatifs à : ATI Catalyst 3.4
