8002 connectés
 Page :   1  2
Page Suivante
Acceleration divx sur les radeon 8500/9000/9100/9200
n°2648577
djuju
Troglotiste en colère
Posté le 07-08-2003 à 11:16:56  profilanswer
et ça : http://www.divx.com/divx/player/optimizations/ :fouyaya:
j'y comprends plus rien moi [:le kneu] le fullstream est integré dans le r200 (mais pas activé pour la 8500)
seule certitude : en dessous la 9500, que dalle :/
n°2648588
djuju
Posté le 07-08-2003 à 11:20:56  profilanswer
d'après l'url de chez ATi :
FULLSTREAM?
The latest advancement in video processing technology, is a hardware accelerated filtering method that improves the performance and visual quality of streaming video playback.
VIDEOSHADER?
RADEON? 9700 VPU continues to provide industry-leading video playback with VIDEOSHADER? technology: a seamless integration of pixel shaders with video. The RADEON? 9700 VPU also offers FULLSTREAM? video de-blocking technology that removes blocky artifacts (noise removal filtering) for captured video and provides sharper image quality.
bon au moins déjà ça, c'est clarifié :)
n°2648598
djuju
Posté le 07-08-2003 à 11:24:18  profilanswer
d'après l'url de divx.com
Optimizing Post Processing with ATI RADEON cards
Applying post-processing to DivX videos using the below ATI hardware (which includes FULLSTREAM? technology) will increase post-processing speed and drop CPU usage up to 20% when using high-levels of post-processing.
Hardware Accelerated Video Post-Processing
The DivX Player supports hardware accelerated video post-processing with selected video hardware. The current version of the Player supports the ATI RADEON? 9500, RADEON? 9600, RADEON? 9700, and RADEON? 9800 video cards. Applying post-processing to DivX videos using ATI's FULLSTREAM? technology (included in the cards) will increase post-processing speed and drop CPU usage up to 20% when using high-levels of post-processing. More information on hardware accelerated post-processing is available.
bref, la confusion regne, et semble limite entretenue volontairement ? :fouyaya:
n°2648668
stef57
Posté le 07-08-2003 à 11:56:02  profilanswer
Je viens de recevoir une reponse d'ATI...faut que je leur ecrive en anglais...
Message édité par stef57 le 07-08-2003 à 11:56:14
Mon Mod Packard Bell
n°2649551
necmaster
Posté le 07-08-2003 à 17:28:23  profilanswer
C clair oui c confus tout ça... :sweat:  Est-ce possible que ce soit chez divx qu'ils patogent ?? :??:  :pt1cable:
en tout cas chez ati c clair d'aprés leur glosaire. Je sais que le fullstream peut marché sur une 8500 à condition de flasher le bios en 9100 donc c que le R200 peut le faire techniquement (plusieurs utilisateurs ont reussis). Pour le videoshader c autre chose encore et à mon humble avis, c'est réservé aux R300 et ses dérivés.
Message édité par necmaster le 07-08-2003 à 17:29:56
n°2649701
chips-disq​ueman
apt-get update
Posté le 07-08-2003 à 18:32:34  profilanswer
D'après ce que j'ai compris, Fullstream ne permet que de prendre en charge le post-processing (20% de baisse CPU d'après DivX.com) alors que VideoShader permet aussi de décoder partiellement (à la manière du motion compensation ?) la vidéo... (et fullstream/=videoshader)
n°2809984
daverc
Posté le 03-11-2003 à 23:25:41  profilanswer
Sur les sites anglais on voit parfois que l'accéleration speciale radeon 9500 du divx player fait tomber la consomation cpu de 40 a 10 % sur un 2 ghz. En plus de filtrer l'image. Malheuresement c'est jamais très détaillé et ca ne marche pas les radeons 9000/9100/9200. Par contre avec Real Player, cocher l'accéleration matérielle lorsqu'on possède n'importe quelle radeon suffit a faire fonctionner le fullstream.
Y a quelqu'un qui peux confirmer ?
n°2810891
tybo
Posté le 04-11-2003 à 15:38:57  profilanswer
A quelle adresse tu leur as écrit??
Moi quand j'envoie des rapports de bugs jamais personne ne me répond!
Moi j'avais cru comprendre que pour le moment ,seul RealOne gérait le fullstream pour les 9100... (et même pas les 9200) et encore moins les 9000
n°2812242
Snagroda
Posté le 05-11-2003 à 08:59:33  profilanswer
bap2703 a écrit :
Ma radeon 8500 est devenue une 9100 => c'est le seul bios plus rapide que j'ai réussi à mettre.
Pour le fullstream je sais pas j'ai jamais eut l'occasion de tester => ca ressemble bien à une amélioration fantome/marketing on dirais
STP tu peux me dire c'est laquelle ta version de bios de t carte 8500?
Ou peut t'on le télécharger?
merci d'avance
Message édité par Snagroda le 05-11-2003 à 09:00:31
n°2824579
daverc
Posté le 13-11-2003 à 00:20:50  profilanswer
up
n°2824668
daverc
Posté le 13-11-2003 à 05:39:04  profilanswer
n°2827121
daverc
Posté le 14-11-2003 à 13:25:20  profilanswer
Quasiment tous les bios ATI.
http://halentech.czweb.org/
Mais c'est pas en francais...
 Page :   1  2
Page Suivante
ATI radeon 9700 3DMark 2003P233MMX + Voodoo3 pour lire 1 divx c possible ?
Gforce 4 MX440 ou FX 5200 ou ATI 9200Ma SUMA PLATINUM RADEON 9600 PRO ne boot pas !! que faire??
Ma SUMA PLATINUM RADEON 9600 PRO ne ve pas booter !! que faire??Transformer une Radeon 8500 128 Mo en Radeon 8500 64 Mo
P233MMX + Voodoo3 pour lire 1 divx c possible ?Méchant freeze WinDVD 4 / Radeon 9600 Pro
[Help Needed] Bug bizarre avec His Radeon 9700...
Plus de sujets relatifs à : Acceleration divx sur les radeon 8500/9000/9100/9200
