ce couple ventirad+peltier, alimenté par une carte pci, fabriqué par la sociiété Active Cool va etre distribué par thermaltake entre autre
j'avais envoyé un mail en demandant komen sa marchai, les temperatures etc ya un bout de temps et je n'attendais plus de reponses et la j'ouvre ma boite et kes ke je vois ... ?
Dear Mad Cow,
Thank you for your interest in Active Cool cooling systems. You are
correct that it is includes a Peltier element powered by a
high-efficiency power converter on a PCI card. I am attaching a
description of how it works and specifications with test results.
Preliminary results with P4 3.06 GHz are as follows:
Test was run using ThermalTake XaserII case (this is a large case with
good air flow).
CPU BurnIn was run continuously to stress processor (we used to run
SiSoft Sandra, but CPU BurnIn provides considerably more heat
stress--and appears to accurately reflect the most processor-intensive
applications in the marketplace).
Maximum CPU temperature (Intel Monitor--thermal diode inside the CPU):
44°C
Maximum system temperature: 40.5°C
We are very pleased with these results. This definitely appears to
eliminate all overheating or activating Tcc. In the near future, I will
try to convince the laboratory to run the test on a smaller case with a
duct fan and sleeve (modders can easily make these at home). I expect
the results to be similar.
I hope this helps.
Yisrael van Handel, director of marketing
Active Cool Ltd.
tel: +972 (8) 6781771
voila
alors pour un p4 3.06 je sais pas trop si les temp sont si bonnes ke ça ... ils parlaient de 26° dans les 1eres infos ... sa devait etre sur un dudu600 ...
je vous met aussi les pieces jointes ke jai recues avec
http://membres.lycos.fr/hooligames/AC4GDataSheet.pdf
http://membres.lycos.fr/hooligames [...] ochure.pdf
http://membres.lycos.fr/hooligames [...] nNoise.doc
si sa vous laisse aussi perplexe ke moi vous pouvez reagir
et kom on dit ... WAIT AND SEE
Message édité par Mad Cow le 07-12-2002 à 00:56:44
