2946 connectés
  Linux et OS Alternatifs
  Installation
  Update/upgrade impossible sur kali
n°1386421
gg97469
Posté le 01-02-2016 à 19:13:47  profilanswer
Salut à tous,
J'essaye déséspérément de mettre à jour ma version de Kali mais j'ai le droit à une erreur quand je lance un update ou un upgrade :
apt-get update me donne :
I
Code :
  1. gn http://security.kali.org kali/updates Release.gpg
  2. Ign http://http.kali.org kali Release.gpg
  3. Réception de : 1 http://repo.kali.org kali-bleeding-edge Release.gpg [819 B]
  4. Ign http://security.kali.org kali/updates Release
  5. Ign http://http.kali.org kali Release
  6. Réception de : 2 http://repo.kali.org kali-bleeding-edge Release [11,0 kB]
  7. Err http://repo.kali.org kali-bleeding-edge Release
  8.
  9. Ign http://http.kali.org kali/main Sources/DiffIndex
  10. Ign http://security.kali.org kali/updates/main amd64 Packages/DiffIndex
  11. Ign http://http.kali.org kali/contrib Sources/DiffIndex
  12. Ign http://security.kali.org kali/updates/contrib amd64 Packages/DiffIndex
  13. Ign http://http.kali.org kali/non-free Sources/DiffIndex
  14. Ign http://security.kali.org kali/updates/non-free amd64 Packages/DiffIndex
  15. Ign http://http.kali.org kali/main amd64 Packages/DiffIndex
  16. Ign http://http.kali.org kali/contrib amd64 Packages/DiffIndex
  17. Ign http://http.kali.org kali/non-free amd64 Packages/DiffIndex
  18. Ign http://security.kali.org kali/updates/contrib Translation-fr_FR
  19. Ign http://security.kali.org kali/updates/contrib Translation-fr
  20. Ign http://security.kali.org kali/updates/contrib Translation-en
  21. Ign http://security.kali.org kali/updates/main Translation-fr_FR
  22. Ign http://security.kali.org kali/updates/main Translation-fr
  23. Ign http://security.kali.org kali/updates/main Translation-en
  24. Ign http://security.kali.org kali/updates/non-free Translation-fr_FR
  25. Ign http://security.kali.org kali/updates/non-free Translation-fr
  26. Ign http://security.kali.org kali/updates/non-free Translation-en
  27. Err http://security.kali.org kali/updates/main amd64 Packages
  28.   404  Not Found
  29. Err http://security.kali.org kali/updates/contrib amd64 Packages
  30.   404  Not Found
  31. Err http://security.kali.org kali/updates/non-free amd64 Packages
  32.   404  Not Found
  33. Ign http://http.kali.org kali/contrib Translation-fr_FR
  34. Ign http://http.kali.org kali/contrib Translation-fr
  35. Ign http://http.kali.org kali/contrib Translation-en
  36. Ign http://http.kali.org kali/main Translation-fr_FR
  37. Ign http://http.kali.org kali/main Translation-fr
  38. Ign http://http.kali.org kali/main Translation-en
  39. Ign http://http.kali.org kali/non-free Translation-fr_FR
  40. Ign http://http.kali.org kali/non-free Translation-fr
  41. Ign http://http.kali.org kali/non-free Translation-en
  42. Err http://http.kali.org kali/main Sources
  43.   404  Not Found
  44. Err http://http.kali.org kali/contrib Sources
  45.   404  Not Found
  46. Err http://http.kali.org kali/non-free Sources
  47.   404  Not Found
  48. Err http://http.kali.org kali/main amd64 Packages
  49.   404  Not Found
  50. Err http://http.kali.org kali/contrib amd64 Packages
  51.   404  Not Found
  52. Err http://http.kali.org kali/non-free amd64 Packages
  53.   404  Not Found
  54. 820 o réceptionnés en 8s (96 o/s)
  55. Lecture des listes de paquets... Fait
  56. W: Une erreur s'est produite lors du contrôle de la signature. Le dépôt n'est pas mis à jour et les fichiers d'index précédents seront utilisés. Erreur de GPG : http://repo.kali.org kali-bleeding-edge Release : Les signatures suivantes ne sont pas valables : KEYEXPIRED 1425567400 KEYEXPIRED 1425567400 KEYEXPIRED 1425567400
  57. W: Impossible de récupérer http://repo.kali.org/kali/dists/ka [...] ease
  58. W: Impossible de récupérer http://http.kali.org/kali/dists/ka [...] rces  404  Not Found
  59. W: Impossible de récupérer http://security.kali.org/kali-secu [...] ages  404  Not Found
  60. W: Impossible de récupérer http://http.kali.org/kali/dists/ka [...] rces  404  Not Found
  61. W: Impossible de récupérer http://security.kali.org/kali-secu [...] ages  404  Not Found
  62. W: Impossible de récupérer http://http.kali.org/kali/dists/ka [...] rces  404  Not Found
  63. W: Impossible de récupérer http://security.kali.org/kali-secu [...] ages  404  Not Found
  64. W: Impossible de récupérer http://http.kali.org/kali/dists/ka [...] ages  404  Not Found
  65. W: Impossible de récupérer http://http.kali.org/kali/dists/ka [...] ages  404  Not Found
  66. W: Impossible de récupérer http://http.kali.org/kali/dists/ka [...] ages  404  Not Found
  67. W: Le téléchargement de quelques fichiers d'index a échoué, ils ont été ignorés, ou les anciens ont été utilisés à la place.
Et un update me donne :
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
Pour info, ma sources.list :
# kali repos installed by TARDIS
deb http://http.kali.org/kali kali main contrib non-free
deb-src http://http.kali.org/kali kali main contrib non-free
## Security updates
deb http://security.kali.org/kali-security kali/updates main contrib non-free
deb http://repo.kali.org/kali kali-bleeding-edge main
Quelque chose de pas bon dans mon bazar ?
Merci !
n°1386443
gg97469
Posté le 02-02-2016 à 16:10:35  profilanswer
Personne ?  :cry:
n°1386461
nehoria
Posté le 02-02-2016 à 21:23:42  profilanswer
L'info importante c'est ça :
Je te laisse chercher !
// Guillemin.
  Installation
BIND9 zone DNS inverse en /21 impossibleProblème update Windows10 dualboot linux
Impossible de faire marché ma carte réseauConnexion distante base SQL impossible
Debian - boot IMPOSSIBLE après install (UEFI powa..)Identification impossible après move /home
impossible de mettre linux 64bits sur processeur 64bitsProblème Bluetooth Ubuntu: transfert de fichiers impossible
instalation mysql server impossible[Résolu] impossible de reinstaller nginx sur debian jessie
Plus de sujets relatifs à : Update/upgrade impossible sur kali
