2929 connectés
  Linux et OS Alternatifs
  Installation
  installation logiciel source
n°918679
progre
Posté le 02-06-2007 à 13:58:30  profilanswer
slt je voudrais installer un logiciel a partir des fichiers source car la version rpm est introuvable dans un SE linux mandriva 2007 spring.
voila ce que la console m'affiche:
[root@localhost kdewebdev-3.5.6]# ls
acinclude.m4  configure.files   INSTALL.docs      Makefile.am     stamp-h.in
aclocal.m4    configure.in      kdewebdev.lsm     Makefile.am.in  subdirs
admin/        configure.in.bot  kfilereplace/     Makefile.cvs    TODO
AUTHORS       configure.in.in   kimagemapeditor/  Makefile.in     VERSION
ChangeLog     COPYING           klinkstatus/      NEWS
config.h.in   COPYING-DOCS      kommander/        PACKAGING
config.log    doc/              kxsldbg/          quanta/
configure*    INSTALL           lib/              README
[root@localhost kdewebdev-3.5.6]# ./configure --prefix=/usr/
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking for -p flag to install... yes
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for kde-config... /usr//bin/kde-config
checking where to install... /usr/ (as requested)
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking dependency style of g++... none
checking whether gcc is blacklisted... no
checking whether g++ supports -Wmissing-format-attribute... no
checking whether gcc supports -Wmissing-format-attribute... yes
checking whether g++ supports -Wundef... no
checking whether g++ supports -Wno-long-long... no
checking whether g++ supports -Wno-non-virtual-dtor... no
checking how to run the C++ preprocessor... /lib/cpp
configure: error: C++ preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details.
[root@localhost kdewebdev-3.5.6]# make
make: *** Pas de cibles spécifiées et aucun makefile n'a été trouvé. Arret.
pouvez vous m'expliquer ces resultats?
Message édité par progre le 02-06-2007 à 14:01:12
n°918681
mikala
Souviens toi du 5 Novembre...
Posté le 02-06-2007 à 14:12:57  profilanswer
kdwebdev est disponible sous mandriva 2007.1 Spring cf ce  lien démontrant l'existence du dit paquet
Il me semble que les médias de ta mandriva 2007.1 Spring soit mal configuré.
Un petit tour ici devrait un peu t'aider : http://wiki.mandriva.com/fr/Configurer_Mandriva_Linux
Message édité par mikala le 02-06-2007 à 14:13:26
Intermittent du GNU
n°918883
supfrs31
Grettings Pr falken.
Posté le 03-06-2007 à 10:55:45  profilanswer
avant de lancer un configure il faut lire le INSTALL
probablement qu'il etait prevu pour lancer un make install directement ou une autre methode encore du genre entrer dans un repertoire avant de lancer make et make install sans lancer le configure
il ne faut pas lancer a l'aveuglette configure make et make install par habitude...
beaucoup de softs reservent ce genre de cas... en particulier les softs et outils de developpement
Merci @+
n°918950
progre
Posté le 03-06-2007 à 17:19:09  profilanswer
merci mais meme en lisant le install je ne comprend tjrs pas quelqu'un pourrait aussi telecharger le fichier sur: http://quanta.kdewebdev.org/releases.php
l'installer chez lui et me montrer la marche a suivre? ca me serais d'une grande aide merci
n°918960
l0ky
Posté le 03-06-2007 à 17:50:29  profilanswer
Et sinon tu as lu le post de mikala au dessus ? s'il est présent dans ta disribution quel est l'intéret de passer par les sources ? tu as des besoins précis ?
n°918962
supfrs31
Posté le 03-06-2007 à 17:56:17  profilanswer
au fait j'avais pas vu au debut mais ton probleme est la :
tant que ca n'est pas corrige inutile de lancer un make !!!!
test :
EST-FRSP:~/Desktop # cd kdewebdev-3.5.6/
TEST-FRSP:~/Desktop/kdewebdev-3.5.6 #  ls
TEST-FRSP:~/Desktop/kdewebdev-3.5.6 #   vi README INSTALL
donc
sh  ./configure
blablabla et la ca passe sur ce check et ca va au bout j'ai donc pu lancer le make sans probleme.
Merci @+
n°918963
supfrs31
Posté le 03-06-2007 à 17:57:31  profilanswer
en fait tu ne dois lancer le make que si tu as ca a la fin du configure :
config.pl: fast created 146 file(s).
config.status: creating config.h
config.status: executing depfiles commands
Good - your configure finished. Start make now
Merci @+
n°918966
ory
Posté le 03-06-2007 à 18:14:35  profilanswer
prends le paquet au lieu de compiler les sources !
n°918996
supfrs31
Posté le 03-06-2007 à 20:39:02  profilanswer
[avis perso]
packet = emmerdes ne jamais en utiliser tant qu'un source est dispo ...
[/avis perso]
Merci @+
n°919003
l0ky
Posté le 03-06-2007 à 20:52:10  profilanswer
supfrs31 a écrit :
[avis perso]
[/avis perso]
Surtout évite bien d'argumenter :heink:
Message édité par l0ky le 03-06-2007 à 20:57:16
n°919004
Fork Bomb
Obsédé textuel
Posté le 03-06-2007 à 20:53:27  profilanswer
supfrs31 a écrit :
[avis perso]
[/avis perso]
C'est pas venderdi, hein  :sarcastic:
Décentralisons Internet-Bépo-Troll Bingo - "Pour adoucir le mélange, pressez trois quartiers d’orange !"
n°919028
supfrs31
Posté le 03-06-2007 à 22:05:55  profilanswer
c'est tres simple a partir du moment ou le risque de conflits de version ou de dependances existe la methode est mauvaise et a proscrire donc toute usage de packet hormis ceux du media d'installation est a proscrire.
Avec les sources chacun a la maitrise absolue de ce qu'il installe. choix de version choix d'options d'install et de setup (ce qui n'existe pas non plus dans le systeme de packaging) j'en passe et des meilleures.
Enfin de ma propre experience j'ai sans arret ete embette chaque fois que j'ai voulu utiliser des packages et ce depuis plus de 10ans a present...
Le sourcing c'est plus complexe a gerer certes mais ca c'est un autre debat qui n'entre pas en ligne de compte sur la question de l'interet entre le choix source et le choix package.
Merci @+
n°919047
mikala
Posté le 03-06-2007 à 22:39:04  profilanswer
Et maintenant si tu débutais ton argumentation :o
Intermittent du GNU
n°926290
Sly Angel
Architecte / Développeur principal
Posté le 23-06-2007 à 14:53:18  profilanswer
Putain il sort d'où celui là pour débiter autant de conneries sur les différents topics du forum ? :o
10 ans d'expérience, on dirait plutôt 10 mois tout au plus...
n°926292
RiderCrazy
Posté le 23-06-2007 à 15:06:24  profilanswer
[:cerveau shay] [:cerveau screampsycho] et encore, la liste pourrait être longue pour qualifier mon expression tout au long de ce topic... (et pourtant, j'suis encore loin des 10 d'expérience en administration système) :o
  Installation
pb ubuntu a l'installationUBUNTU: Soucis Oracle 10g Express Edition aprés installation
installation gcc g++ avec librairie sous ubuntuinstallation quanta plus sous mandriva 2007
installation quanta plus sous mandriva 2007logiciel professionnel
analyseur de trames sans installation[réglé] Installation Debian
Installation sles 10 et disquette[ Apache- PHP sous Linux] installation et lancement
Plus de sujets relatifs à : installation logiciel source
