7227 connectés
Comment jugez-vous cette caméra IP made-in-china à 60€
 Page :   1  2  3  4  5  ..  13  14  15  ..  26  27  28  29  30  31
[Topic Unique] H.264 IPCAM HD WIFI Pan & Tilt + IR-Cut + SDcard
n°734323
Mesfet
Posté le 07-05-2013 à 19:13:08  profilanswer
craym0nk a écrit :
macmpi, you are the master! Removing the cs file stopped the 30 second reboot loop immediately. And thank you for communicating with me in English.
Unfortunately my original problem (since before I loaded 5.53) remains. No matter which firmware I use 5.48, 5.20, if I remove the power cord to restart the camera I end up in recovery mode. I think I have done something to break init.
I was looking around the file system and came across /etc_rc/inittab:
Code :
  1. # cat inittab
  2. ::sysinit:/etc_ro/rcS
  3. ttyS1::respawn:/bin/sh
The script /etc_rc/rcS is called on sysinit. I'm guessing it should only run if the firmware is damaged, I think on my camera it is running every time the power cord is removed. If I log in via telnet and call exec reboot the camera will restart and operate as it should. It is also OK if I reboot from the www interface. Here is the contents of /etc_rc/rcS:
Code :
  1. # cat rcS
  2. #!/bin/sh
  3. mount -a
  4. mkdir -p /var/run
  5. mkdir /tmp/eye
  6. mount -t jffs2 /dev/mtdblock5 /tmp/eye
  7. cat /etc_ro/motd
  8. cd /sbin
  9. internet.sh
  10. sleep 1
  11. ifconfig eth2.1 192.168.1.111
  12. cd /bin
  13. #ftpd&
  14. fd&
  15. telnetd&
  16. wpp&
  17. apploader&
  18. #./cs&
  19. mii_mgr -s -p 0 -r 0 -v 0x3900
  20. mii_mgr -s -p 1 -r 0 -v 0x3900
  21. mii_mgr -s -p 2 -r 0 -v 0x3900
  22. mii_mgr -s -p 3 -r 0 -v 0x3900
  23. #for syslogd
  24. mkdir -p /var/log
This post on Open IP Camera forums talks about an /tmp/eye/init.sh file which I do not have. Are you familiar with it, maybe the cause of my problems? http://www.openipcam.com/forum/ind [...] ml#msg1207
Any ideas what might be wrong?
BAD FRENCH GOOGLE TRANSLATION:
macmpi, vous êtes le maître! Retrait du fichier cs arrêté immédiatement la deuxième boucle 30 de redémarrage. Et merci pour communiquer avec moi en anglais.
Malheureusement, mon problème initial (depuis avant que je chargeais 5,53) demeure. Peu importe le firmware j'utilise 5,48, 5,20, si je retire le cordon d'alimentation pour redémarrer l'appareil photo je me retrouve en mode de récupération. Je pense que j'ai fait quelque chose pour briser initialisation.
Je regardais autour du système de fichiers et suis tombé sur /etc_rc/ inittab: CODE
Le script /etc_rc/rcS est appelé sysinit. Je suppose qu'il ne doit s'exécuter si le firmware est endommagé, je pense que sur mon appareil photo est en marche chaque fois que le cordon d'alimentation est débranché. Si je me connecte via telnet et appelle exec reboot r l'appareil va redémarrer et fonctionner comme il se doit. Il est également OK si je redémarre à partir de l'interface www. Voici le contenu de /etc_rc/rcS: CODE
Ce post sur les forums ouverts Caméra IP parle d'un fichier /tmp/eye/init.sh que je n'ai pas. Êtes-vous familier avec elle, peut-être la cause de mes problèmes? LINK
Des idées ce qui pourrait être le problème?
 I have the same problem !
n°734327
macmpi
Posté le 07-05-2013 à 20:30:10  profilanswer
I've logged all files on several H502W and clones from several users, and such file never appeared in any log.
The post you refer to, may refer to another (older?) model.
Francais:
J'ai fait des log de tous les fichiers des H502W et clones auprès de plusieurs utilisateurs, et n'ai jamais trouvé trace d'un tel fichier.
Je pense que l'article en question doit faire référence à un autre modéle de cam (plus ancien?).
Les informations détaillées sur le logiciel de la cam, et le hacking c'est ICI
n°734334
macmpi
Posté le 07-05-2013 à 22:18:34  profilanswer
Problème de stabilité sur plusieur firmwares, ou juste sur 5.53? Problèmes au reboot soft ou au reboot après coupure d'alim?
Il y a bcps de choses dans le message de craym0nk, donc, pour pouvoir t'aider efficacement, peux-tu expliquer précisément tes problèmes en faisant abstraction de son cas pour le moment?
n°734335
Mesfet
Posté le 07-05-2013 à 22:45:56  profilanswer
en fait depuis toujours j'ai ces memes pb de stabilite lors d'une coupure d'alim mais heureusement je connais par coeur le moyen de la rescuciter. Je n'ai toujours pas trouvé le fautif, je vais creuse du cote du fichie ldr.ini et verifier qu'il est bien present.
Pas constate d'amelioration depuis les dernier fw, au debut je pensais que le 5.53 avait resolu le pb...mais non.
n°734337
macmpi
Posté le 07-05-2013 à 23:07:04  profilanswer
Hum...oui regarde (en telnet sinon tu ne verras rien): passe-moi son contenu en PM si tu veux que je jette un oeil.
Vérifie aussi que cs.def.ini est bien dans app/, que cs a la bonne taille (decompresser le app.bin sur le PC avec mkbin.exe pour vérifier) et les droits d'éxécution (sous telnet dans app/ faire ls -l cs et regarder s'il y a des x dans le champs des droits): au besoin, chmod 755 cs.
Enfin, renommer cs.ini (sous telnet dans app/: mv cs.ini toto), afin de demarrer la cam vierge de tout réglage personnel (on pourra les restaurer plus tard).
Si ca ne règle pas le problème, consulte tes MP ;)
Message édité par macmpi le 08-05-2013 à 23:23:25
n°734414
magnum88
Posté le 08-05-2013 à 20:26:32  profilanswer
Bonjour A tous,
J'ai acheté il y a peux une IPCam
et j'ai bien transférer via FTP
car l upload normal à planter
j'ai essayé, les .bin à la racine,
les rep
les rep + fichiers bin
mais je n'arrive pas à la faire repartir
La Cnx telnet et FTP est active
merci de vos lumière
Ps: voici la cam:
http://thumbs.ebaystatic.com/pict/1509860987114040_1.jpg
Message édité par magnum88 le 08-05-2013 à 20:27:50
n°734416
macmpi
Posté le 08-05-2013 à 20:37:23  profilanswer
magnum88 a écrit :
Bonjour A tous,Ps: voici la cam:
Un peu petite la photo pour se faire une idée précise...
Il serait plus facile d'aider en ayant un peu plus d'info: marque/modèle/lien vers le fabricant/doc, etc...
A ce stade, il n'est même pas évident du tout que cette cam soit de la même famile (visuellement très différente).
Si telnet est possible, peut-on connaitre le contenu des fichiers:
/proc/cpuinfo
/proc/version
Message édité par macmpi le 08-05-2013 à 23:03:51
n°734464
magnum88
Posté le 09-05-2013 à 08:16:27  profilanswer
/proc/cpuinfo
/proc/version
Pour Info:
app: 00002
web:00003
pour le telnet j'ai permission denied
pour les 2 commandes.
pour la marque ,le modele
juste SmartEyes
la boite d'origine en carton est bleu
voici le lien web de l'achat
lien
Merci de votre aide
n°734467
macmpi
Posté le 09-05-2013 à 09:08:57  profilanswer
A la lecture de la spec il apparait clairement que ce n'est pas une camera de la même famille: pas de H264, pas de carte SD, etc
D'après le nom du soft de gestion (IPCMonitor), un coup de Google nous amène sur :http://www.szmorning.com/endownload.asp
Va falloir continuer les recherches afin de trouver un modèle suffisemment proche (regarder les spec, photos, emplacement des ports et connecteurs, etc).
Peut-être un clone d'un modèle Wansview?
En tout cas, elle n'appartient pas à ce fil de discussion.
Bonne chance!
Message édité par macmpi le 09-05-2013 à 09:15:15
n°734469
magnum88
Posté le 09-05-2013 à 09:16:28  profilanswer
Bonne chance!
cela explique PQ,
je n'arrive pas à la faire revivre avec les APP et WWW
merci encore
pour votre Aides
n°734475
Aahem
Posté le 09-05-2013 à 10:52:40  profilanswer
Pour revenir à la famille de la H502W
Nos amis de BTIcam en Pologne semblent savoir ce qu'ils font, mais j'ai un problème de langue avec leur site.
Voici le mail qu'ils viennent de m'envoyer:
"Dear
How to run Pant Tilt direct from SYNOLOGY Surveillance Station Live View  Adding BTICAM BT-H08W-P2p into SYNOLOGY Surveillance Station.
http://webcam4.eu/?p=736"
Une traduction google du Polonais donne à peu prés:
Voici  comment:
1 Exécutez ssh sur le Synology (Panneau de configuration -> Terminal -> tick ssh)
2 Connectez-vous en utilisant le terminal (par exemple mastic) à Synology:
ssh root @ DSM_IP (comme un mot de passe pour l'utilisateur admin)
3 commande:
cd / volume1 / @ appstore / SurveillanceStation / conf /
vi camera_model.conf
4 Dans la [camera * lettre] nous ajoutons les lignes:
BTIC * BT-H08W-P2P-720p = BTIC * generic-720p
BTIC * BT-H08W-P2P-MJPEG = BTIC * générique MJPEG
BTIC * BT-H08W-P2P-cgi = BTIC * generic-cgi
5 Ci-dessous, nous ajoutons sections:
[BTIC * generic-cgi]
port = 81
source vidéo = video.cgi
incliner vers le haut = "moveptz.xml? timeout = 100 & dir = up"
Inclinaison vers le bas = "moveptz.xml? timeout = 100 & dir = down"
vous avez quitté = "moveptz.xml? timeout = 100 & dir = gauche"
'Re droite = "moveptz.xml? Timeout = 100 & dir = right"
etc...
Message édité par Aahem le 09-05-2013 à 10:53:30
n°734485
Bubbah
Real Men Don't Do Backup
Posté le 09-05-2013 à 12:41:22  profilanswer
Je suis en train de tester leur procédure et je ferai une récap sur mon site dès que possible. En gros on active SSH, ou telnet pour accéder au syno en tant que root. La première partie du code s'ajoute au fichier camera_model.conf sous /volume1/@appstore/SurveillanceStation/conf/
et la seconde, plus longue portion de code va dans un nouveau fichier BTICAM.conf qui sera sauvé sous /volume1/@appstore/SurveillanceStation/conf/camera-support
Comme je suis réfractaire à l'éditeur vi, je travaille à partir d'un volume visible comme /volume1/public sur lequel je sauve les fichiers conf, pour pouvoir les récupérer sur mon PC via ftp.
Autre point important, il faut éviter de copier le code à partir d'une page traduite car certaines portions de code risquent d'être altérées.
Bubbah - www.gadgetvictims.com
n°734509
craym0nk
Posté le 09-05-2013 à 14:29:47  profilanswer
macmpi a écrit :
craym0nk,
Please make sure cs.def.ini is properly installed in app/ and that you have ldr.ini in eye/ (check this one with telnet as FTP server hides it). You may cut&paste your ldr.ini content in a PM for me to check-it. Also make sure cs file has correct size (if flash full, it may be truncated) and execute rights (chmod 755 cs   if not)
Also you may copy and remove (or just rename) cs.ini (your settings) to see how it goes with blank user config parameters.
If this does not help, read your PMs. ;)
Thank you Sir,
cs.def.ini is the copy that came bundled with 5.48 firmware inside /tmp/eye/app
cs file is exact same byte count as copy on my PC, assume transfer was 100% complete.
Execute rights look fine, ran chmod just in case.
Removed cs.ini to test, made no difference.
As soon as I remove power cord camera is back to 30sec reboot loop. To recover:
telnet rm -f /tmp/eye/app/cs
ftp and upload cs
telnet exec reboot
And then I can operate camera normally until I remove power cord again.
I will PM my ldr.ini, thank you again.
n°734585
Mesfet
Posté le 09-05-2013 à 22:42:33  profilanswer
hello,
comment faites-vous pour copier ldr.ini de la cam vers la PC. En telnet via la commande CP, je ne retrouve pas le fichier sur mon ordi. Est-ce du au format ? au fait qu'il soit caché ?
n°734587
Mesfet
Posté le 09-05-2013 à 22:46:19  profilanswer
c'est bon j'ai trouvé (mode boulet off)
utiliser cat et copier/coller dans un fichier txt.
Rien de spécial dans sa composition...
n°734588
Mesfet
Posté le 09-05-2013 à 22:47:59  profilanswer
Par contre je n'ai rien après "wifimac". Rien de tout ca :
[oem_smarteye]
enable=1
mac
mac2
mid
pid
sn
se_ddns_svr
se_ddns_port=80
se_ddns_interval=60
se_ddns_name
se_ddns_user
se_ddns_pwd
n°734591
macmpi
Posté le 09-05-2013 à 23:26:26  profilanswer
Ou bien, le copier en le renommant:
cp ldr.ini toto.ini  lorqu'on est dans le répertoire eye
Et là, magie, le client FTP voit toto.ini ! :)  (en fait le serveur FTP de la cam cache spécifiquement les fichiers nommés ldr.ini !)
Du coup on peut aussi faire la réciproque: déposer un fichier par ftp, et après le copier/renommer en ldr.ini  (attention, il est prudent de se garder dans un coin son ldr.ini d'origine)
Message édité par macmpi le 09-05-2013 à 23:31:36
n°734729
Bocal83
Posté le 11-05-2013 à 09:42:22  profilanswer
Salut à tous,
J'ai aussi fait l'acquisition de cette caméra hier.
Je l'ai mise à jour (app + www) bien que la mise à jour www par l'interface n'ai pas marché (fichier incorrect selon la WebUI) alors j'ai carrément supprimé le répertoire www qui était accessible par FTP sur la caméra et remplacé par le nouveau du fichier .bin
Par contre, j'ai un NAS Synology (DS509+) et j'ai modifié le fichier camera_model.conf et créé le fichier BTICAM.conf en SSH comme indiqué dans ce tuto de la page précédente :
http://webcam4.eu/
A partir de Surveillance Station 6, j'ai bien les flèches de mouvement à présent mais la caméra ne bouge pas lorsque je clique sur les boutons.
Est-ce qu'il y a encore une modif à faire ?
Je vous remercie !!
PS : sinon très content pour le moment de cette caméra à prix très correct ! :)
n°734850
Bubbah
Posté le 12-05-2013 à 11:24:16  profilanswer
Bocal83 a écrit :
...A partir de Surveillance Station 6, j'ai bien les flèches de mouvement à présent mais la caméra ne bouge pas lorsque je clique sur les boutons...
J'ai les mêmes résultats: pas de fonction Pan & Tilt, et pas d'audio quelque soit la combinaison de paramètres utilisée.
Du coup le seul avantage sur le Onvif est la haute résolution.
n°734886
Bocal83
Posté le 12-05-2013 à 15:16:35  profilanswer
J'ai réussit à faire fonctionner le Pan & Tilt dans Surveillance Station.
En fait, c'était un problème de caractère à partir du site http://webcam4.eu/
Voici les codes corrects (copy/paste compliant) :
Les trois lignes à rajouter au début dans /volume1/@appstore/SurveillanceStation/conf/camera_model.conf
        BTICAM*BT-H08W-P2P-720p=BTICAM*generic-720p
        BTICAM*BT-H08W-P2P-mjpeg=BTICAM*generic-mjpeg
        BTICAM*BT-H08W-P2P-cgi=BTICAM*generic-cgi
Les lignes à rajouter à la fin du fichier /volume1/@appstore/SurveillanceStation/conf/camera_model.conf
[BTICAM*generic-cgi]
        port=81
        video source=video.cgi
        tilt up="moveptz.xml?timeout=100&dir=up"
        tilt down="moveptz.xml?timeout=100&dir=down"
        pan left="moveptz.xml?timeout=100&dir=left"
        pan right="moveptz.xml?timeout=100&dir=right"
[BTICAM*generic-720p]
        port=81
        video source=video1/h.264/720p.sdp
[BTICAM*generic-mjpeg]
        port=81
        video source=mjpeg.sdp
Le fichier /volume1/@appstore/SurveillanceStation/conf/camera_support/BTICAM.conf
[BTICAM*BT-H08W-P2P-cgi]
api = bticam
channel_list = 1
default_channel = 1
resolutions_mjpeg = 160x120,320x240,640x480,1280x720
resolutions_mpeg4 = 160x120,320x240,640x480,1280x720
resolutions_h264 = 160x120,320x240,640x480,1280x720
default_resolution_mjpeg = 1280x720
default_resolution_mpeg4 = 1280x720
default_resolution_h264 = 1280x720
fps_mjpeg_160x120 = 1,2,3,4,5,10,15,20,25,30
fps_mjpeg_320x240 = 1,2,3,4,5,10,15,20,25,30
fps_mjpeg_640x480 = 1,2,3,4,5,10,15,20,25,30
fps_mjpeg_1280x720 = 1,2,3,4,5,10,15,20,25,30
fps_mpeg4_160x120 = 1,2,3,4,5,10,15,20,25,30
fps_mpeg4_320x240 = 1,2,3,4,5,10,15,20,25,30
fps_mpeg4_640x480 = 1,2,3,4,5,10,15,20,25,30
fps_mpeg4_1280x720 = 1,2,3,4,5,10,15,20,25,30
fps_h264_160x120 = 1,2,3,4,5,10,15,20,25,30
fps_h264_320x240 = 1,2,3,4,5,10,15,20,25,30
fps_h264_640x480 = 1,2,3,4,5,10,15,20,25,30
fps_h264_1280x720 = 1,2,3,4,5,10,15,20,25,30
default_fps_mjpeg_160x120 = 30
default_fps_mjpeg_320x240 = 30
default_fps_mjpeg_640x480 = 30
default_fps_mjpeg_1280x720 = 30
default_fps_mpeg4_160x120 = 30
default_fps_mpeg4_320x240 = 30
default_fps_mpeg4_640x480 = 30
default_fps_mpeg4_1280x720 = 30
default_fps_h264_160x120 = 30
default_fps_h264_320x240 = 30
default_fps_h264_640x480 = 30
default_fps_h264_1280x720 = 30
default_image_quality = 5
mjpeg = rtsp
mpeg4 = rtsp
h264 = rtsp
motion = mjpeg,mpeg4,h264
motion_param = sensitivity,percentage,threshold
audio_format = AAC,AMR,G711,PCM,G726
#default_audio_format = G726
home = yes
pan = yes
tilt = yes
camera_parameters = yes
ntp = yes
ntp_server = Surveillance Station,time.nist.gov,disable
video_mirror = yes
video_flip = yes
exposure_control = 50,60,outdoor
default_exposure_control = 60
osd_timestamp = yes
ptz_continuous_move = yes
preset = 16
alarm_input = 2
alarm_output = 2
[BTICAM*BT-H08W-P2P-720p]
api = bticam
channel_list = 1
default_channel = 1
mjpeg = rtsp
mpeg4 = rtsp
h264 = rtsp
#audio_format = AAC,AMR,G711,PCM,G726
home = yes
pan = yes
tilt = yes
ntp = yes
video_mirror = yes
video_flip = yes
osd_timestamp = yes
preset = 16
alarm_input = 2
alarm_output = 2
[BTICAM*BT-H08W-P2P-mjpeg]
api = bticam
channel_list = 1
default_channel = 1
mjpeg = rtsp
mpeg4 = rtsp
h264 = rtsp
home = yes
pan = yes
tilt = yes
ntp = yes
video_mirror = yes
video_flip = yes
osd_timestamp = yes
preset = 16
alarm_input = 2
alarm_output = 2
Maintenant pour le son je ne sais pas comment c'est géré
Message édité par Bocal83 le 12-05-2013 à 15:22:16
n°735000
Bubbah
Posté le 13-05-2013 à 17:42:42  profilanswer
Bocal83 a écrit :
Bien vu! En effet ça marche mieux: PTZ et HD ok!
n°735066
macmpi
Posté le 14-05-2013 à 09:09:05  profilanswer
Pour info, Dericam a posté leur version 0.41 (sur base 5.53) qui dit régler un problème avec l'enregistrement sur Synology:
http://www.dericam.com.cn/UploadFi [...] 200.41.rar
En fait c'est juste un tout petit changement dans le cs.def.ini du app.bin.
Donc juste mettre à jour le app.bin si vous êtes déjà en 5.53
Readme:
Version 0.41 has following new features:
1.Fix the problem of can't connect to Synology plug-app
"Surveillance 6.0-2383"
Message édité par macmpi le 14-05-2013 à 09:21:08
n°735170
skoubri
Posté le 15-05-2013 à 10:12:13  profilanswer
Dear all, first sorry for English but i don't know French.. only Greek mother languange :)
a big thanks for this useful info on ipcams!... I have also a new ID002A bought from ebay and really stuck in some things.. any help would be very much appreciated!
I received the camera with version 00.00.05.02 and i updated to 00.00.05.39 in the beginning but after strange behavior finally got to 05.53. After this camera seems to work, BUT i have "Invalid License File" and the camera reboots every 10 minutes. tried many times to restore until i completely lost it and managed after many hours to resurrect through FTP...
I only see app & www folders and never existed any license or other files in there except the known ones... Of course no support from seller as it was bought from ebay :(
So i wonder.. has anyone managed to find what is the story with HID authentication? ( my UID field was empty from the beginning)...
And also if anyone has backed up the version 05.02 which was my original to test...
THANK YOU VERY MUCH
n°735171
skoubri
Posté le 15-05-2013 à 10:15:51  profilanswer
P.S. In my app folder and cs.log file i always find messages like this: [2013.05.14 22:06:24]::[reboot for invalid auth file](/mnt/work/board/cs/core/mainapp.cpp:769)
n°735180
macmpi
Posté le 15-05-2013 à 11:12:26  profilanswer
Please try to install 5.49 from maygion site http://www.maygion.com/downloads/2 [...] h.264).rar (will report 5.48 once installed), and let know if it is more stable.
If you can, log into the cam with telnet, and do:
cp /tmp/eye/ldr.ini /tmp/eye/app/toto.ini
And then download toto.ini via FTP to your PC, and cut&paste its content to a PM to me.
Message édité par macmpi le 15-05-2013 à 11:45:35
n°735191
skoubri
Posté le 15-05-2013 à 13:30:29  profilanswer
Thank you very much for your answer (an in English too!) Meanwhile i have tested ver 4 (5.53) from dericam and version 5.28 from Bubbah's blog. Now i am going to install 5.49 as you said and let you know. The other problem is that my camera is ID002A and has no directory /tmp/eye !!... i can see only /app , /www and /sd and also only accessible through FTP, not telnet... My only extra info is the cs.ini file which produced and says this message about authorization.. One other strange thing is that once it was authorized (ver 05.02). i DIDN"T erased ANY files... just updated... i really want to break it!!! :fou:  .. can i somehow have "deeper" access maybe?
THANK YOU!
n°735192
skoubri
Posté le 15-05-2013 à 13:49:35  profilanswer
ok, just did it but nothing changed :( Every ten minutes still reboots!! Somekind of watchdog!... Have tried to disable DDNS, Upnp, alams, recordings, ntp but nothing changed... i am afraid its a matter of authorization but know nothing on that!!! And the more silly part.. the ebay seller said that contacted the "factory" and they don't have any firmware!!!... probably he doesn't know even what he sells!!.. Do you think these Ralink chips to come preprogrammed? :) :)
P.S. @macmpi, do you think somehow i could enable telnet so i have more control?
Message édité par skoubri le 15-05-2013 à 13:50:56
n°735255
macmpi
Posté le 16-05-2013 à 10:39:22  profilanswer
Yes, most probably. Check PM
n°735428
macmpi
Posté le 18-05-2013 à 10:46:59  profilanswer
Merci à skoubri (et Bubbah) pour ce partage d'expérience qui a permis de rafiner la compréhension du rôle du fichier de license board.dat.
J'ai mis à jour mon post sur le logiciel de la cam en conséquence.
http://forum.hardware.fr/hfr/Hardw [...] tm#t705043
English: Thanks skoubri (and Bubbah) for your contribution for a better understanding of board.dat license file role. I updated my post on cams software to reflect this.
Message édité par macmpi le 18-05-2013 à 14:37:56
n°735471
azazel673
Posté le 18-05-2013 à 17:10:10  profilanswer
Merci pour ce post récapitulatif très intéressant ;)
n°735724
macmpi
Posté le 21-05-2013 à 11:21:15  profilanswer
De nombreux témoignages d'utilisateurs semblent indiquer que la mise à jour 5.53 peut rendre le HID non authentifié (altération du fichier board.dat ou bug d'évaluation). La cam pouvant devenir instable quel que soit le firmware installé ensuite.
Un conseil, éviter la 5.53 pour le moment, ou, au moins, sauvegarder le board.dat AVANT la mise à jour 5.53 ! (http://IP:PORT/board.dat )
Message édité par macmpi le 22-05-2013 à 18:21:44
n°736991
Mesfet
Posté le 03-06-2013 à 20:58:43  profilanswer
salut,
rencontrez-vous les problemes suivants sur ce modele de cam:
1-allumage intempestif des led IR meme lorsqu'elles sont sur off  !!
2- en raccordement filaire, une seconde connexion est initié avec des adresses mac completement farfelues. mon routeur a loggué differentes connexions depuis la cam avec des interfaces «virtuelles»
et toujours les problemes d'instabilite lorsque le courant est coupe ou lors d'une perte de connexion reseau.
a+
n°737000
macmpi
Posté le 03-06-2013 à 22:51:57  profilanswer
Pour les les IR, je ne sais pas.
En ce qui concerne les adresses MAC, ca peut venir du ldr.ini qui peut avoir les champs mac et wifimac vides sur les anciens modèles: lorsque l'appli caméra est lancée, elle prend alors des adresses MAC un peu random.
Ta cam est connectée comment au réseau?
- ethernet via routeur
- wifi via routeur
- les 2 (via le même routeur ou différent routeur)
n°737002
Mesfet
Posté le 03-06-2013 à 23:47:00  profilanswer
en wifi pas de pb. par contre en filaire sur mon routeur, l'interface lan recupere bien son adresse ip du routeur mais, en parallelle, il y a une seconde interface virtuelle (qui change d'adresse mac) qui intie des connexions classiques pour le ntp comme le fait l'interface normale. bizarre, pas grave mais bizarre.
n°737003
Mickou45
Posté le 03-06-2013 à 23:48:37  profilanswer
Et en étant relier en ethernet et ayant pris soin de désactiver le wifi de la dericam ?
Le problème persiste t'il toujours ?
n°737047
paillassou
Posté le 04-06-2013 à 14:02:13  profilanswer
coucou la compagnie ;)
@ux pros:
je mets quoi comme dernier firmware ?
merci d'avance à tous :)
n°737052
macmpi
Posté le 04-06-2013 à 14:52:42  profilanswer
A priori 5.53 pour le moment, mais...
Primo vérifier si le HID est authentifié sur la page d'information système et sauvegarder le board.dat en le téléchargeant :
S'il fait 2048 octets, et qu'il est binaire (ininterpretable avec un éditeur de texte), il y a de bonnes chances qu'il soit valide et bon pour le service en 5.53.
Auquel cas la 5.53 ne devrait pas poser de problème.
Si avec la 5.53 il y a des reboot fréquents, consulter le cs.log dans app/: en général ces reboot sont dus à une license (board.dat) invalide: seul maygion ou les manufacturiers peuvent en générer un valide.
Juste un truc qd même: ne PAS connecter simultanément la cam en ethernet direct sur le PC et le wifi: sinon un "bug" de 5.53 cause des reboot toutes les 1'40'' environ... Sur les versions précédentes ca ne reboote pas, mais fait qd même perdre la connexion internet wifi.
(si ethernet et wifi sont sur le même routeur, pas de problème)
Si trop de soucis en 5.53, la précédente 5.48 marche bien.
Message édité par macmpi le 05-06-2013 à 09:43:47
n°737139
paillassou
Posté le 05-06-2013 à 14:16:37  profilanswer
MERCI beaucoup macmpi !
je check ça dès que possible.
Bye @ tous ;)
n°737269
Mesfet
Posté le 06-06-2013 à 23:38:08  profilanswer
La version 05.56 est sorti sur le site Cybernova. Installés mais pas de changelog donc je ne sais pas ce qu'elle ajoute ou améliore comme fonctionnalités
n°737432
wLZ
Posté le 09-06-2013 à 01:14:44  profilanswer
Bonjour à tous, je possède cette caméra depuis quelques semaines et une chose m'étonne : lors de la capture d'image par alarme, la résolution des clichés est en 320x240 quelle que soit la résolution choisie pour la vidéo. Par contre les snapshots sont pris avec la même résolution que la vidéo. Savez vous s'il est possible de régler ça?
n°737497
bardiel
Debian powa !
Posté le 09-06-2013 à 21:37:56  profilanswer
Bonjour à tous !
J'ai remarqué chez Carrefour à tout hasard une caméra IP qui ressemble furieusement mais de la marque "Power Star", sous la référence nip 02, à votre avis est-ce la même ou non ?
Ce qui m'intéressait par rapport aux caractéristiques (de l'ancienne version) données en FP c'était la possibilité de récupérer le flux vidéo directement, pratique donc pour une machine sous Linux :D (RTSP avec VLC quoi)
Grippe ? Coronavirus ? Portez votre masque correctement ! :D
Ecran HD avec connection HDMI pour jouer ?Caméra wifi TP-Link TL-SC4171G
Clef usb wifi / livebox[Topic Unique] Ecran Iiyama ProLite B2480HS-1 (24").
[Topic Unique] Cooler Master Storm Sentinel Advance II[Topic Unique] QPAD 5K Limited Edition
module wifi intégré carte mère asus z77[topîc unique] Monitor Samsung SincMaster B2440
Connexion WiFi - Imprimante HP-3070A
Plus de sujets relatifs à : [Topic Unique] H.264 IPCAM HD WIFI Pan & Tilt + IR-Cut + SDcard
