1517 connectés
  Hardware - Périphériques
  Webcam / Caméra IP
  Caméra sous auvent : extérieure ou intérieure ?
n°746575
begoodtech
Posté le 01-10-2013 à 11:50:01  profilanswer
Je voudrais installer une caméra dehors mais sous un auvent.
A priori elle sera protégée des précipitations.
Est-ce que du coup je peux me contenter d'une caméra intérieure ?
Si vous avez en passant une reco, suis preneur.
Besoin Wifi, compatible Synology et budget < 200€
Merci pour votre avis.
n°746597
Misssardon​ik
prévisible a posteriori
Posté le 01-10-2013 à 15:41:57  profilanswer
tu vas pas être protégé de l'humidité ni des fortes variations de température, à mon avis prends une extérieure.
Que va-t-il se passer cette gelgamar ? vous le découvrirez janamont à 20h
n°746611
theuberove​rlord
Posté le 01-10-2013 à 18:50:34  profilanswer
begoodtech a écrit :
IMHO. Unless you are going to place an indoor camera in a sealed dome, you should use a outdoor camera.
This is because. Over time, you will be dealing with humidity, even if the camera is protected from rain.
I don't have enough fingers and toes to count the number of camera owners who have placed a indoor camera outside. Without a dome. Usually, within 6 months most have issues, again more so because of humidity than anything else.
When you use a dome for an indoor camera outside. You will also need to use an External IR light source. But you can place desiccant packets in the dome to avoid humidity issues.
If you were to open these cameras up. You would see that the smallest drop of water forming on the PCBs ("Printed Circuit Boards" ) inside these cameras can short camera components. By placing desiccant packets inside the dome. This resolves this. Whereas. The Outdoor cameras have rubber rings around the seals of the camera. Indoor cameras don't have these seals. This is why this is an issue.
Here is an example of a dome that can protect indoor cameras when they are placed outside. You still need to place desiccant packets in the dome as well:
http://foscam.us/products/dome-enclosure.html
Don
CV - About Me: Français English Conseils et exemples gratuits pour vos Camera IP Live IP Cam Demos
n°746613
krystyan
Posté le 01-10-2013 à 19:11:39  profilanswer
Attention même à l'abris les caméras intérieures n'aiment pas trop le froid et l'humidité
Voici un montage avec une Dlink 930 et un boitier de spot halogène à 5€ qui la protège efficacement
http://img405.imageshack.us/img405/5289/pjp1.jpg
Uploaded with ImageShack.us
Message édité par krystyan le 01-10-2013 à 19:16:06
n°746630
matt-91
Posté le 01-10-2013 à 21:35:48  profilanswer
Bonsoir à tous,
je suis nouveau sur le fofo j'ai fait la même chose avec ma trendnet IP 551IW sauf que j'ai mis un plexiglas opaque avec un trou pour l'objectif à la place de la vitre et ça na jamais bouger depuis 1 an.
si vous voulez une photo pas de souci.
d'ailleurs je viens de faire l’acquisition d'une nouvelle caméra HD 1080 pour une autre maison mais jai un souci je n'arrive pas à la connecter correctement...
si quelqu’un à une idée je suis vraiment preneur.
voici mon post.
http://forum.hardware.fr/hfr/Hardw [...] 1373_1.htm
n°746951
Jean-Charl​es71
La sécurité ne s'improvise pas
Posté le 04-10-2013 à 23:47:17  profilanswer
Bonjour
theuberoverlord a raison.
Pour l'extérieur il vaut mieux utiliser une caméra prévue pour l'extérieur. C'est une question de températures de fonctionnement été et hiver et surtout d'humidité.
Bien sûr vous pouvez en installer une dans un coffret ou un boîtier de spot. Ça va fonctionner mais avec quelle durée et quelle qualité d'images ?
Bien cordialement
Jean-Charles71
n°776118
tolunq
Posté le 30-07-2014 à 19:43:11  profilanswer
il est quand même dommage que l'on n'arrive pas a trouver des camera exterieure comme celle ci :
http://nsa34.casimages.com/img/2014/07/30/14073008014768260.jpg
ou celle ci :
http://nsa33.casimages.com/img/2014/07/30/140730080214919525.jpg
car elles sont quand même (à mon avis) plus discrete à poser que ça :
http://nsa34.casimages.com/img/2014/07/30/140730080538307601.jpg
et d'après vous pour une exterieure, il vaut mieux une motorisée ou  non ? une hd ou non ? (les hd exterieures coute encore cher)
Message édité par tolunq le 30-07-2014 à 19:57:57
n°778437
lisa lacro​ix
Posté le 12-08-2014 à 17:25:50  profilanswer
http://nsa34.casimages.com/img/201 [...] 768260.jpg
ou celle ci :
http://nsa33.casimages.com/img/201 [...] 919525.jpg
http://nsa34.casimages.com/img/201 [...] 307601.jpg
De manière générale pour des questions de température et d'humidité je déconseille de prendre une caméra intérieure.
Pour l'extérieure tout dépend de ce que tu veux en faire, si c'est pour une levée de doute une caméra non hd suffi si c'est pour voir qui passe ds ton jardin il te faut absolument une HD.
J'ai trouvé des foscam FI9805W (hd 1.3mp) neuves à moins de 140€ sur des sites spécialisés
  Webcam / Caméra IP
Camera - P-iris - resolutionCaméra IP sur réseau 3G ?
Caméra Wansview NCM 624W Images de mauvaise qualitéaide au fontionnement de camera de surveillance
[résolu]Cherche mini caméra détection de mouvement pour porte entréeconfigurer mon routeur pour contrôler ma caméra ip à distance
Camera adresse IP invisible sur router freebox v6Camera IP: Vidéo fluide dans IE mais pas dans VLC ni dans iSPy
Caméra en streaming
Plus de sujets relatifs à : Caméra sous auvent : extérieure ou intérieure ?
