2538 connectés
  [Topic Unique] ABIT AN7 (Nforce2 Ultra 400)
 Page :   1  2  3  4  5  ..  29  30  31  32  33  34
Page Précédente
n°2966743
stique7
Posté le 24-01-2004 à 23:21:34  profilanswer
L' Abit AN7 est la petite soeur de la NF7-S, identique entres elle a part le µguru sur l' AN7 qui permet de modifier certaines option du bios sous Windows.
DESCRIPTION
Voici ces Specifications
CPU
Supports AMD-K7 Socket A 266/333/400 MHz FSB CPU
CHIPSET
NVIDIA nForce2 Ultra 400 chipset with MCP-T
Integrated 128-bit memory controller
Supports Advanced Configuration and Power Management Interface (ACPI)
Accelerated Graphics Port connector supports AGP 8X/4X (0.8V/1.5V)
MEMORY
Three 184-pin DIMM sockets
Supports 3 DIMM Un-buffered DDR 266/333
Supports 2 DIMM Un-buffered DDR 400
ABIT Engineered
ABIT μGuru? Technology
ABIT SoftMenu? Technology
ABIT FanEQ? Technology
ABIT MaxFID? Technology
ABIT CPU ThermalGuard? Technology
ABIT FlashMenu?
SATA 150 RAID
On board SATA PCI Controller
Support 2 channels SATA 150 RAID 0/1
Audio
6-Channel AC 97 CODEC on board
Professional digital audio interface supports optical S/P DIF In/Out
NVIDIA SoundStormTM Technology with real-time Dolby Digital 5.1 encoder
LAN
On board Realtek 10/100 LAN
IEEE 1394
3 ports IEEE1394 Supports 400 Mb/s data transfer rate
Internal I/O Connectors
1 AGP 8X/4X slot, 5 PCI slots
Floppy Port supports up to 2.88 MB
2 x Ultra DMA 33/66/100/133 Connectors
2 x SATA 150 Connectors
2 x USB headers, 1 x IEEE 1394a header, 2 x CD-IN
Back Panel I/O
1 x PS/2 Keyboard, 1 x PS/2 mouse
1 x Serial Port connectors, 1 x Parallel Port connector
1 x S/P DIF Input, 1 x S/P DIF Output
Audio connectors (Front Speaker, Line-in, Mic-in, Center/Sub, Surround Speaker)
2 x USB, 1 x IEEE1394 Connector
2 x USB, 1 x RJ-45 LAN Connector
Miscellaneous
245 x 305mm ATX form factor
http://www.abit.com.tw/page/en/mot [...] ifications
Quelques photos
Comparaison entre l'AN7 et la NF7-S
http://stique7.free.fr/Ftp/An7/an7.jpg
http://stique7.free.fr/Ftp/An7/nf7-s.jpg
Avantages
- La carte mére permet de selectionner un FSB jusque 300
- Jusque 2.3V de Vcore
Inconveniant
- Cette carte mère a un petit problémes pour la lecture des températures des processeurs "Ahtlon XP Palamino 0.18
- Ne fonctionne pas avec les puces mémoires samsung TCC4 (pc3200 cl2.0)
Astuces
- Je me suis aperçu que plusieurs personnes n'avaient pas de son lorsqu'elles installaient les 3.13, en fait il faut installer les pilote du CD, puis, aprés avoir redémarré, installer les 3.13 :D
DOWNLOAD
Drivers nforce2
Actuelle
http://download.nvidia.com/Windows [...] rivers.exe Drivers 4.24 Nforce avec le son, IDE. Tout En 1
Ancien
ftp://ftp.abit.com.tw/pub/downloa [...] in2kxp.exe (obligatoire pour avoir le son)
http://download.nvidia.com/Windows [...] tional.exe ( Derniere version 3.13 international 25.4 MB)
http://download.nvidia.com/Windows [...] nglish.exe ( Derniere Version 3.13 anglaise 12.9 MB )
Drivers SATA
ftp://ftp.abit.com.tw/pub/downloa [...] /10028.exe
ftp://ftp.abit.com.tw/pub/downloa [...] disk12.exe (pour la D7 de drivers demandé quand on installe windows sur un DD sata)
Bios
1.5 ftp://ftp.abit.com.tw/pub/download/bios/an7/an715.exe
1.4 ftp://ftp.abit.com.tw/pub/download/bios/an7/an714.exe
1.3 ftp://ftp.abit.com.tw/pub/download/bios/an7/an713.exe
1.2 ftp://ftp.abit.com.tw/pub/download/bios/an7/an712.exe
AWDFLASH v8.24F  ftp://ftp.abit.com.tw/pub/downloa [...] ash824.exe
Bios Moded
http://forum.abit-usa.com/attachme [...] tid=342587 Bios moded (merci VydoLL )
Autre
 MBM compatible AN7 http://files.savagenews.com/MBM5366.exe
Test
http://www.cpu3d.com/modules.php?n [...] ent&id=129
http://envynews.com/index.php?ID=618#start
http://www.hard-h2o.com/public/har [...] /abitan7-1
http://www.hexus.net/content/revie [...] 19JRD02ODE
http://www.legionhardware.com/html/doc.php?id=273
http://www.motherboards.org/articl [...] 283_1.html
http://www.overclockers.com.au/article.php?id=239628
Ps Aidez moi a l'améliorer
Message édité par stique7 le 09-06-2004 à 21:10:25
n°2966750
stique7
Posté le 24-01-2004 à 23:24:22  profilanswer
Reserved
n°2966751
stique7
Posté le 24-01-2004 à 23:24:29  profilanswer
reserved
n°2966848
stique7
Posté le 25-01-2004 à 00:00:18  profilanswer
reserved
n°2966966
ZOLKMAT
demain, promis
Posté le 25-01-2004 à 01:18:04  profilanswer
moi j'ai un petit probleme !
pour configuré me seagate SATA avec cette petite carteMére
Le Dur est bien formater (il marche nikele en hotplug sur une IC7-G) mais pas moyen de le configuré pour l'an7
il est bien reconu sous le raid (ctrl+S) mais c'est tout..
help me pour configuré sa :D  Bios d'origine (pas de lecteur disquette de dispo...)
Merci  :jap:
n°2968486
stique7
Posté le 25-01-2004 à 19:17:53  profilanswer
ttu narrive pa a installé windows?
n°2968680
stique7
Posté le 25-01-2004 à 20:35:25  profilanswer
Je recherche les photo de cm avec les coup de cuter
si kkun les retrouve..
n°2968745
stique7
Posté le 25-01-2004 à 21:02:09  profilanswer
Merci  :jap:
du 9?
n°2988474
tomati
Posté le 03-02-2004 à 19:44:55  profilanswer
ici
n°2995568
mowgly
Posté le 06-02-2004 à 20:29:36  profilanswer
j'hesite entre l'AN7 et la NF7-S V2 on ma dit que la AN7 n'etait pas aboutit vous en pensez quoi ?
Mon feedback
n°2996277
ipfix2
Posté le 07-02-2004 à 09:46:38  profilanswer
be mo je voulais une an7 et j ai eu une nf7s y en avais plus o magasin, mais franchement ca marche un petit barton 2500+ @ 3200+ et de la ran samsung en ddr400 ca me change la vie
n°3008595
xanthe739
Posté le 12-02-2004 à 21:31:02  profilanswer
T'as pas un test en français ?
Ma nf7-s rev 1.0 déconne. Elle repart en sav (ça va être chaud, la garantie expire demain et je l'ai signalé aujourd'hui). Si je dois en racheter une, j'hésite. La durabilité limitée de ma nf7-s me déçoit, d'autant plus que je n'avais pas overclocké. L'AN7 me tente assez mais bon, je me méfie des premières révisions sorties.
A t'elle des bugs connus (comme la prise micro de la nf7) ?
n°3008810
mowgly
Posté le 12-02-2004 à 22:59:05  profilanswer
va voir la : http://forum.hardware.fr/hardwaref [...] 4145-1.htm
personnellement j'ai choisie la NF7-S V2 car l'an7 est encore un peut juste et m'apporte pas grand chose de plus ( 2 usb 1 firewire a l'arriere connecteur alin et IDE déplacé )
Mon feedback
n°3008981
xanthe739
Posté le 13-02-2004 à 01:25:32  profilanswer
Moui, apparemment, le son est amélioré et il y'a cette possibilité de profil.
Mais je sors d'une galère et pour une fois j'aimerais du matos qui marche à peu près bien du premier coup.
n°3009926
stique7
Posté le 13-02-2004 à 15:40:24  profilanswer
Merci pour la photo
Je voudrais améliorer la presentation de la CM
Astuce ETc si on pe maidé
n°3009929
VydoLL
Cat Killer 0_-
Posté le 13-02-2004 à 15:41:29  profilanswer
n°3009970
sgreg
Gné ?!???
Posté le 13-02-2004 à 16:13:44  profilanswer
Le connecteur d'alim m'a géné pour l'installation de mon Giant 2, le rad dépasse de 3mm en plein dessus. Un petit coups de dremel et ça passe.
Achetée fin décembre, j'ai juste eu un petit problème de boot une fois, et depuis rien, je la trouve stable et performante. Il n'y a que la temp CPU que je trouve basse à mon goût.
n°3009989
wakestorm
Posté le 13-02-2004 à 16:24:11  profilanswer
C'est tout propre, tout beau, manque plus que mon drapal :D
n°3010048
xanthe739
Posté le 13-02-2004 à 16:49:08  profilanswer
stique, tu ne pourrais pas mentionner les principaux problèmes rencontrés, comme dans le topic de la nf7, genre le coup de cutter, le code 90, les eventuels problèmes de compatibilité avec tel matériel (par ex disque dur WD je crois) ou avec tel ventilo, qu'il faut limer ?
Tu pourrais peut être aussi indiquer ce qu'elle apporte par rapport à la nf7, meilleur son (658 au lieu de 650) et mguru, même si ce n'est pas énorme.
Enfin, indiquer les perfs max et moyennes en overclocking.
Bon, ça fait du boulot ces 3 rubriques supplémentaires, mais quand on veut créer un topic unique .... Et puis ça apporterait quelque chose de plus que l'autre topic sur an7 qui ne veut pas devenir le topic unique.
n°3010058
VydoLL
Cat Killer 0_-
Posté le 13-02-2004 à 16:54:20  profilanswer
Sans parler des liens des forums abit, les possible solutions pour recuperer son bios endommagé etc etc..... :)
n°3010104
xanthe739
Posté le 13-02-2004 à 17:26:39  profilanswer
tout à fait thierry
tu peux d'ailleurs reprendre intégralement certains posts, notamment de vydoll.
Pour moi c'est le principal intérêt d'un topic unique, cette première page qui fait le tour du sujet, actualise les connaissances dessus et renvoie vers d'autres ressources.
n°3010223
stique7
Posté le 13-02-2004 à 18:31:50  profilanswer
oki si vous voulez faire des petit article
Je ne suis pas contre
( cmon anniversaire ce soir :D )
n°3010536
wakestorm
Posté le 13-02-2004 à 20:38:30  profilanswer
Joyeux naniversaire alors :D (comme cadeau, t'as le droit de travailler sur le topic jusqu'à minuit, comme Cendrion :o) :D
n°3011045
xanthe739
Posté le 14-02-2004 à 05:16:30  profilanswer
mais mais mais tu vas bosser feignant
un topic unique ça se mérite
n°3011845
stique7
Posté le 14-02-2004 à 16:36:59  profilanswer
jle modif
Donné moi ces avantage et incovenien pliz :D
n°3011918
cafard
Posté le 14-02-2004 à 17:10:54  profilanswer
elle supporte les athlon 1.4ghz et les dudu 800?
n°3011959
cafard
Posté le 14-02-2004 à 17:30:23  profilanswer
up
n°3012003
stique7
Posté le 14-02-2004 à 17:55:52  profilanswer
Ben ui je pense
confirmer les otre
(tu peut selectionner FSB100 ds le bios donc..
n°3012031
cafard
Posté le 14-02-2004 à 18:09:43  profilanswer
j'ai un athlon 1.4ghz fsb 133.je voudrais avoir la confirmation que ca passe en attendant un 3400+.
autrement,avec mon athlon 1.4 fsb 133 je peut mettre la memoire à 200 mhz si je met le coeff*7? 7*200=1400mghz
n°3012123
stique7
Posté le 14-02-2004 à 18:37:10  profilanswer
tu peut metre ton proco a 133 et ta mémoire a 200
mais je doute ke ton proco tiendra en FSB 200 5(00)
n°3012233
stique7
Posté le 14-02-2004 à 19:16:16  profilanswer
Bon j'ai modif le1er post
Envoyer moi ce que vous savez de Lan7 pour les catégorie vide (voir le 1er msg)
n°3012286
cafard
Posté le 14-02-2004 à 19:33:42  profilanswer
je me suis goure,je voulais dire 133*10.5
n°3012322
xanthe739
Posté le 14-02-2004 à 19:46:01  profilanswer
Inconveniant
Astuces
J'ai apercu que plusieur personne n'avait pas de son lorsqu'il installait les 3.13, enfet il faut mettre les pilote du CD et aprés avoir redémarer, mettre les 3.13
17 fautes en 3 lignes, tu cherches à figurer dans le guinness book ?  :lol:
Inconvenients
Astuces
Je me suis aperçu que plusieurs personnes n'avaient pas de son lorsqu'elles installaient les 3.13, en fait il faut installer les pilote du CD, puis, aprés avoir redémarré, installer les 3.13.
n°3012347
stique7
Posté le 14-02-2004 à 19:57:31  profilanswer
a ué qunad méme ^^
tu veut faire le correcteur du topic :D
n°3013333
stique7
Posté le 15-02-2004 à 13:43:33  profilanswer
Je voudrait faire un sondage à propos des température de l'AN7
Si vous avez lan7
pouvez vous mindiquez les temperature Proco , Systeme , PWn et le nom de votre proco ainsi que sa frequence (si oc)
n°3013429
cafard
Posté le 15-02-2004 à 14:19:05  profilanswer
une petite question,peut ton faire du raid 0 avec 2 disques ide avec une an7?
n°3014106
stique7
Posté le 15-02-2004 à 18:33:50  profilanswer
théoriquement oui
n°3014126
Osana
Posté le 15-02-2004 à 18:40:17  profilanswer
je viens d'acheter une AN7 mais impossible d'installer windows donc de m'en servir. c incompréhensible !
le chargement des fichiers executifs windows se fait puis plus rien, je n'arrive pas sur l'ecran bleu du choix d partitions ou installer windows d'ou l'impossibilité de l'installer.
g fait cette manip avec un windows xp pro ainsi qu'avec un windows 2000 pro pour le meme resultat.
c la premiere fois ke j vois une chose pareil, peut etre que cela vient d'un probleme de compatibilité (g 2 dd ibm/hitachi de 120 go, hercule 9800 pro, athlon xp 2400+, graveur yamaha et dvd NEC) mais la je coince grave !!
si quelqu'un a connaissance de la maniere de resoudre ce prob ..
merci d'avance
n°3014307
stique7
Posté le 15-02-2004 à 19:31:27  profilanswer
oui si tu les met en SATA
sinon tu peut le faire par windows je crois
n°3014309
stique7
Posté le 15-02-2004 à 19:32:00  profilanswer
Osana
Ta mémoire peut etre ?
Page Précédente
Pb nfs underground + nforce2 + R9700pro catalyst 4.1 ?Asus 9600 XT vs Asus 5700 ultra
pb hdd maxtor 160 go avec CM ABIT NF7-STransformer une 5900 en 5950 Ultra
Flasher le Bios d'une KT7 RAID ABIT ??"Topic Unique"Boitier Aspire X-Superalien
abit nf7s rev2CM MSI KT333 Ultra ARU de luxe + XP 2000+ Ça vaut quoi et combien
Comment exploiter au mieux la FX 5700 Ultra ?peut on booter sur une carte promise Ultra 133 TX2
Plus de sujets relatifs à : [Topic Unique] ABIT AN7 (Nforce2 Ultra 400)
