J'ai un problème de crash du je pense à ma carte graphique.(Card name: Intel(R) HD Graphics 4000 Nvidia Geforce GT650M) En effet de temps en temps au bout d'un certain moment mon jeu crash( wow ) avec un bruit sourd qui sort de mes enceintes et il m'affiche le message d'erreur comme quoi j'ai perdu le pilote et il a été retrouvé ou bien tout simplement un crash du pc avec ces erreurs:
*Crash Dump Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Fri 21/11/2014 17:51:37 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\112114-49312-01.dmp
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF80166221B67)
Bugcheck code: 0xD1 (0xFFFFF80100000008, 0xE, 0x0, 0xFFFFF80166221B67)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\WINDOWS\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 344.75
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 344.75
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 344.75 , NVIDIA Corporation).
Google query: NVIDIA Corporation DRIVER_IRQL_NOT_LESS_OR_EQUAL
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x1B6B67)
On Thu 20/11/2014 11:14:52 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\112014-41359-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14F1A0)
Bugcheck code: 0x133 (0x0, 0x501, 0x500, 0x0)
Error: DPC_WATCHDOG_VIOLATION
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Avez vous une idée du problème rencontré?
merci d'avance !
System Information
Time of this report: 11/21/2014, 19:18:39
Operating System: Windows 8.1 64-bit (6.3, Build 9600) (9600.winblue_r3.140827-1500)
Language: French (Regional Setting: French)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: N56VZ
BIOS: N56VZ.215
Processor: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz (8 CPUs), ~2.4GHz
Memory: 16384MB RAM
Available OS Memory: 16270MB RAM
Page File: 3295MB used, 29358MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 120 DPI (125 percent)
System DPI Setting: 120 DPI (125 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_21031043&REV_09
Display Memory: 1792 MB
Dedicated Memory: 32 MB
Shared Memory: 1760 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: LGD02D9
Native Mode: 1920 x 1080(p) (59.906Hz)
Output Type: Internal
