4206 connectés
  Systèmes & Réseaux Pro
  Réseaux
  I have a problem routing inter vlan with HP procuve
n°124783
splouxe
Posté le 08-10-2014 à 19:15:00  profilanswer
Please I have a problem of inter-vlan routing, I have a core and two switches in each room floor.
I created a vlan 11 and I give him an IP address and i enabled the ip routing in the core and in the switches in each room floor and I can not have the router with another VLAN and most all other vlan are not router, please how do ???
Below config core and a switch to floor,
Please, I'am blocked, plz i need help
I can not have access to the other sub networks  with the ip 11.11.1.25
show running-config
Running configuration:
; J4819A Configuration Editor; Created on release #E.11.38
hostname "HP ProCurve Switch 5308xl"
snmp-server contact "test"
mirror-port D11
module 6 type J4907A
module 5 type J4907A
module 4 type J4907A
module 1 type J4878B
module 2 type J4878B
module 3 type J4878B
ip routing
snmp-server community "public" Unrestricted
vlan 1
name "DEFAULT_VLAN"
untagged A1-A4,B1-B4,C1-C4,D15-D16,E1-E16,F3-F4,F6-F9,F11-F16
ip address 172.16.X.1 255.255.0.0
ip address 10.10.X.250 255.255.255.0
no untagged D1-D14,F1-F2,F5,F10
exit
vlan 2
name "WIFI"
untagged F1-F2,F5,F10
tagged A4,B4
exit
vlan 100
name "DMZ"
untagged D6-D7,D13-D14
ip address 192.168.X.254 255.255.255.0
exit
vlan 200
name "INTERNET"
untagged D1-D5,D8-D12
monitor
exit
vlan 3
name "MANAGEMENT"
ip address 172.17.X.1 255.255.0.0
exit
Vlan 11
name "test"
11.11.1.254 255.255.255.0
exit
banner motd "This is a private system maintained by the Allied Widget Corporatio
n.
Unauthorized use of this system can result in civil and criminal penalities !"
spanning-tree
spanning-tree priority 2
router rip
exit
vlan 1
ip rip
ip rip receive V1-only
ip rip send V1-only
exit
vlan 100
ip rip
ip rip send V1-only
exit
floor switch:
ProCurve 2910al-48G-1E-2#
ProCurve 2910al-48G-1E-2# sh running-config
; J9147A Configuration Editor; Created on release #W.14.70
hostname "ProCurve 2910al-48G-1E-2"
module 1 type J9147A
ip routing
vlan 1
name "DEFAULT_VLAN"
untagged 1-48
ip address 172.16.X.5 255.255.0.0
exit
gvrp
banner motd "This is a private system maintained by the Allied Widget Corporation.\nUnauthorized use of this system can result in ci
snmp-server community "public" unrestricted
spanning-tree force-version rstp-operation
password manager
password operator
plz help me
n°124786
Modération
Posté le 08-10-2014 à 20:19:00  answer
no
  Réseaux
Port miroir HP procurvePropagation VLAN Juniper
vlan par adresse macvlan dynamique, restriction switch
Problème de routage inter-VLAN sur Cisco SG300HP procurve : vlan injoignable
Web ssl avec switch HP 2530VLAN pc/téléphonie sur Switch HP Procure
Plus de sujets relatifs à : I have a problem routing inter vlan with HP procuve
