6681 connectés
Sujet : Hollywood + , Dolby Digital SbLive et Win2k je comprend plus rien
Profil supprimé Certes c'est interessant mais je t'assure que j'ai 4 voix differentes(je ne suis pas audiophile mais la scene sur le toit de l'immeuble dans Matrix est assez probante!)
VilCoyote Si tu as des drivers > 1.8, c'est la meme chose qu'a l'avant qui sort a l'arriere ...
Sinon, tu peux essayer :
As with Magnifik, my machine also crashes when using 1.8 older drivers.
I tried to use 1.7 ones as they have 4 speaker support but they crashed a lot,
so here are the workarounds I made.ss
First attempt, objective was using 1.82 drivers with dowmixing to 4 speaker.ss
At first seemed to work while playing some vob files I had in the HD but after
trying to view a DVD it crashed on my machine.ss
Anyway this is what I did (perhaps it works ok for you).
I uninstalled the H+ drivers and software.ss
Then I installed 1.7 drivers and then I made a copy of a file calledss
WAVIFACE.DLL temporary folder: (that file is in C:windowssystem)ss
(wavefiface.dll can be found here
Then remove the drivers (make sure they are removed correctly) and then installedss
1.82 drivers and 1.82 DVD Station. Then I copied WAVIFACE.DLL from the temp folder
to C:WINDOWSSYSTEM, finally I used DVDGenie (version 3.75)
and enabled the output thru soundcard and 4 speaker option.ss
That worked for me while playing VOB files from the HD but no DVD discs (shit!).
----------ss
Second attempt, with 1.82 drivers installed, I made a copy of the following files to a temp folder:ss
(they are in C:windowssystem too)
RMPNPQ.VXD
RMQUASAR.VXD (which was the file that always crashed on 1.7 on me)
Then I uninstalled all (DVDStation and drivers) installed 1.7 drivers.ss
After that I copied that 2 files on the C:WINDOWSSYSTEM overwriting the ones
that already there (which are from 1.7 version). Then installed the 1.82 DVD Station andss
finallly I ran DVDGenie (version 3.75) and selected the output thru soundcard and 4 speaker option.
Je comprend + la...
J'ai dl la demo Dolby Digital Jungle. Je la fait tourner avec la station realmagic et en prenant soin de laisser la sblive decoder le son(DVDGenie). La je me retrouve avec 4 voix différentes, donc a priori du DD. Mais je croyais que ces drivers ne supportait plus le decodage DD pour cause de license??!! Mais alors, qu'est ce qui sort de mes enceintes, si ce n'est pas du DD??? une emulation creative?
