6608 connectés
Sujet : Pour les possesseurs de cartes son Creative (Audigy, SBlive! ...)
Obanon
Ninipc a écrit a écrit :
ca gère les sortie digitales des SB live?
Je crois oui ... mais tout est sur le site :)
Pour les "bases" (copier/coller de la 1ère page du site):
The kX Audio Driver package includes driver system files and setup files as well as a powerful audio mixer application (the kX Mixer), which acts as a Graphical User Interface, providing access to many of the driver's internal functions. The following features are either fully supported or partially supported in the latest release of the kX Audio Driver: Wave Recording & Playback, MIDI Synthesizer (Synth Engine), MIDI UART In/Out, DirectSound 2D, DirectSound 3D (software emulation; 2-speakers mode only), Soundfonts, Full ASIO support, DSP Microcode Loading/Unloading, Full AC97 I/O control, AC3 Software Decoding
Et les limitations actuelles sont :
Under WindowsXP / Windows 2000 kX mixer is accessible only by 'Administrator' account
Windows Media Player may skip files or unexpectedly mute
Lilac skin causes resource and memory leakage
Setting TRAM size to 0 may cause BSODs
Some TV-Tuner software conflicts with kX Driver
Only one SoundFont drum bank is supported
Front and Rear speakers are intentionally swapped by default - explanation why here.
Limitations on SoundFont maximum sample size.
No EAX/EAX2.0/EAX3.0 support.
No Direct3d support (2d emulation only).
Audigy hardware support for some TRAM operations not functioning properly.
Look-up tables not implemented.
Issues with certain AC97 codec versions (including fixes, delays, phases, levels etc...).
WinMM multitrack recording/playback support not yet implemented.
No AC3-passthrough support.
Win2k requires special control panel settings.
No realtime MIDI synth volume control.
Only partial support for SoundFont-aware applications (no load/get/clear preset & load/clear waveform functions).
Stereo soundfont samples not implemented.
Windows mixer volume controls doubled under win98 only.
Phantom CD-Audio control may appear in the Windows mixer.
La suite, sur le site ...
Obanon
Ninipc ca gère les sortie digitales des SB live?
Obanon
interressant :jap:
Bah moi je suis carrément aux anges, j'attendais ça depuis un moment. En plus l'install sous XP n'a posé aucun problème.
Je savais déjà que les drivers Creative étaient des bouses, mais alors là on se rend vraiment compte à quel point :D
Et puis c'est un projet très sérieux, on trouve tout concernant les drivers sur le site, y compris des forums dédiés où les développeurs répondent régulièrement.
Ninipc interressant :jap:
Obanon Si vous avec une carte son Creative et que vous faîtes de la musique, je vous conseille fortement d'aller jeter un oeil là :
http://www.kxproject.spb.ru/
Vous y trouverez des drivers (non officiels) qui permettent d'utiliser toutes les possibilités de la SBLive! ou de l'Audigy.
Le gain le plus spectaculaire concerne le temps de latence qui peut descendre en dessous des 3ms ! (selon Cpu et soft).
Perso avec les "Native Instruments" (par ex.), je suis passé de 50ms à 5ms ! Ces drivers permettent quantité de tweaks, de bricoler les DSP, etc.
Attention, ce sont encore des drivers beta (bien que très avancés) qui ont encore qlqes contraintes, donc lisez bien les recommandations avant de vous lancer. Si vous ne faites pas de musique ça n'a que peu d'intérêt.
PS : je n'assure ni le SAV, ni la hotline ... ;)
