5088 connectés
Sujet : Tags MP3
Neurone MP3 Tag studio
Y en a plein sur winamp.com je crois
Aschrack pas de quoi
vaudoo Merci beaucoup
Aschrack et c'est entierement gratuit
Aschrack URL ftp://ftp.tu-darmstadt.de/pub/mac [...] ggermp.exe
Commentaires TaggerMP
- by David Katski
TaggerMp is a very simple utility that renames MP3 files and can automatically fill an MP3 tag. This allows you to fill the tag with specific song information, such as artist, album title and song title, plus provides you with the ability to use your MP3 files on a wide range of players.
The program is very simple in form and function, although it may be a little hard to understand. The help file information is not adequate to properly understand the operation of some of the features or as to why you would need to use them. TaggerMP will re-curse folders and does provide drag and drop support, however, trying to understand the format behind extracting MP3 tag information is a little complicated. There is a wizard that guides you through the building of a format, but even that doesn't explain the process very well.
I give TaggerMP 2 smileys. The program has good operation and an interface that is easy to navigate, yet really doesn't give good reason for why you need to change MP3 file names or tag information.
URL Page http://www.rocketdownload.com/cgi- [...] rmp.exe&r=
vala, moi jlai down cet aprem jlai essayé et ca marche plutôt bien jdois dire
gURuBoOleZZ
redridinghood a écrit a écrit :
ah grilled   :D
 :sol:
Pour tag and rename : tu as trente jours d'essais gratuits, sans que rien sois bridé - à utiliser en toute légalité. En faisant vite...
redridinghood ah grilled   :D
redridinghood tag&rename est tres tres bien, mais c un shareware
gURuBoOleZZ Tag and rename, Renatager, Tag
Pour les liens, google.
vaudoo J'ai transféré beaucoup de mes CD en format MP3 ces dernières années, mais je n'ai pas toujours utilisé la même méthode de nommage, et j'ai parfois des fautes de frappes.
J'aimerais savoir s'il existe un logiciel qui renommerait chaque MP3 à partir de son nom de fichier, et ce pour tout un ensemble de répertoires / sous-répertoires.
