4603 connectés
Sujet : Les pilotes de la Sound Blaster Audigy Player...
gladi4tor ben tu lis c ecris non ...??
New sequencer, more convenient, ability to view pattern changes in the sequencer and to add tags to your song.
Storm is smoother for other applications running on the same system.
Improved VST mode: better management of plugin connection problems, tested with Cubase 5.0, Logic 4.7.
MIDI control of the drum machines (works both in standalone and in VST mode)
Re-designed audio engine. You can change the audio and MIDI drivers without leaving the composition screen. You can also dynamically setup the latency setting while processing.
Multiple output connections: on multiple-output ASIO sound cards, or in VST mode with Cubase, you can dynamically connect the synthesizer's outputs tothe different outputs of the audio card. (Only available in the full version)
Windows XP now supported.
New and faster audio export feature. You can also choose the compression rate (bitrate) of your mp3 file when exporting.
ACID WAV file format now supported (tempo and tonality).
RephleX :bounce:
RephleX [:belgarion_cer]
RephleX Hello all,
Je voulais savoir ce qu'apporte l'update que l'on peut trouver là(http://fr.europe.creative.com/support/drivers/welcome.asp) des drivers concernant la carte son Sound Blaster Audigy Player.
Merci et A+ :hello:
