5010 connectés
  Les pilotes de la Sound Blaster Audigy Player...
n°198490
RephleX
Posté le 04-02-2002 à 09:58:05  profilanswer
Hello all,
Je voulais savoir ce qu'apporte l'update que l'on peut trouver là(http://fr.europe.creative.com/support/drivers/welcome.asp) des drivers concernant la carte son Sound Blaster Audigy Player.
Merci et A+ :hello:
"The easy underground listening sound..."
n°198636
RephleX
Posté le 04-02-2002 à 13:42:59  profilanswer
[:belgarion_cer]
n°198707
RephleX
Posté le 04-02-2002 à 15:00:32  profilanswer
:bounce:
n°199352
gladi4tor
Posté le 05-02-2002 à 09:43:47  profilanswer
ben tu lis c ecris non ...??
New sequencer, more convenient, ability to view pattern changes in the sequencer and to add tags to your song.
Storm is smoother for other applications running on the same system.
Improved VST mode: better management of plugin connection problems, tested with Cubase 5.0, Logic 4.7.
MIDI control of the drum machines (works both in standalone and in VST mode)
Re-designed audio engine. You can change the audio and MIDI drivers without leaving the composition screen. You can also dynamically setup the latency setting while processing.
Multiple output connections: on multiple-output ASIO sound cards, or in VST mode with Cubase, you can dynamically connect the synthesizer's outputs tothe different outputs of the audio card. (Only available in the full version)
Windows XP now supported.
New and faster audio export feature. You can also choose the compression rate (bitrate) of your mp3 file when exporting.
ACID WAV file format now supported (tempo and tonality).
Un player gratuit qui lit presque tous les formats....ter unsujet peu être déjàposté:(Rack Audigy?
Sorties numériques SB AUDIGYPb Real Player sous WinXP
PROBLEME prog SBLASTER audigy.........Maxi Sound fortissimo 1 : Altec 54 + Casque ? help !
Cherche possesseur WinXP, carte Audigy chargeant de grosse soundfontSVCD player ?
Changer de Player sous XPQui aurait l'installation de Windows media player 6.4.09 pour Win 2000
Plus de sujets relatifs à : Les pilotes de la Sound Blaster Audigy Player...
