3276 connectés
  Traitement Vidéo
  Impossible de lire une au format mkv
n°1120924
eben
Posté le 24-08-2006 à 10:21:02  profilanswer
Bonjour a tous
Voila j ai une video avec l extension mkv et il ai impossible pour moi de la lire, j ai pourtant telecharger et installer Matroska_Pack_Lite_v1.0.3.exe avec comme lecteur Media Player Classic de K-lite.
Au lancement du fichier j ai le son mais pas d image...
voila l erreur que mon lecteur m annonce
Media Player Classic could not render some of the pins in the graph, you may not have the needed codecs or filters installed on the system.
Media Type 0:
Video: RealVideo 4 720x576 30.00fps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
subtype: Unknown GUID Name {30345652-0000-0010-8000-00AA00389B71}
formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA}
bFixedSizeSamples: 0
bTemporalCompression: 0
lSampleSize: 1
cbFormat: 146
VIDEOINFOHEADER:
rcSource: (0,0)-(0,0)
rcTarget: (0,0)-(0,0)
dwBitRate: 0
dwBitErrorRate: 0
AvgTimePerFrame: 333333
VIDEOINFOHEADER2:
dwInterlaceFlags: 0x00000000
dwCopyProtectFlags: 0x00000000
dwPictAspectRatioX: 720
dwPictAspectRatioY: 576
dwControlFlags: 0x00000000
dwReserved2: 0x00000000
BITMAPINFOHEADER:
biSize: 40
biWidth: 720
biHeight: 576
biPlanes: 0
biBitCount: 0
biCompression: RV40
biSizeImage: 0
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0020: 00 00 00 00 00 00 00 00 15 16 05 00 00 00 00 00 ................
0030: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@...
0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð...
0050: 40 02 00 00 00 00 00 00 52 56 34 30 00 00 00 00 @.......RV40....
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070:|00 00 00 22 56 49 44 4f 52 56 34 30 02 d0 02 40 ..."VIDORV40.Ð.@
0080: 00 0c 00 00 00 00 00 1e 00 00 01 48 10 20 40 00 ...........H. @.
0090: 80 00                                           €.
Media Type 1:
AM_MEDIA_TYPE:
formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A}
lSampleSize: 1
cbFormat: 122
VIDEOINFOHEADER:
dwBitRate: 0
dwBitErrorRate: 0
BITMAPINFOHEADER:
biSize: 40
biWidth: 720
biHeight: 576
biPlanes: 0
biBitCount: 0
biCompression: RV40
biSizeImage: 0
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
0030: 28 00 00 00 d0 02 00 00 40 02 00 00 00 00 00 00 (...Ð...@.......
0040: 52 56 34 30 00 00 00 00 00 00 00 00 00 00 00 00 RV40............
0050: 00 00 00 00 00 00 00 00|00 00 00 22 56 49 44 4f ..........."VIDO
0060: 52 56 34 30 02 d0 02 40 00 0c 00 00 00 00 00 1e RV40.Ð.@........
0070: 00 00 01 48 10 20 40 00 80 00                   ...H. @.€.
Voila merci par avance pour vos reponses.
n°1120934
eben
Posté le 24-08-2006 à 11:05:21  profilanswer
Merci j ai trouvé la solution
n°1121218
nina2004
shinèèèèèèèèèè!!!!!!!!!!!!!!!
Posté le 24-08-2006 à 20:58:51  profilanswer
et c'était quoi au juste la soluce?
n°1121243
kaxxymo
Posté le 24-08-2006 à 21:35:42  profilanswer
je n'ai jamais installé de codec pour les mkv et media player classic me lit tous le fichiers de ce type
n°1339266
jmbjmb
Posté le 21-12-2007 à 23:35:42  profilanswer
 Bonjour pourriez vous me communiquer la solution, j'ai exactement le même problème et je ne parviens pas à m'en sortir.
n°1339345
sedhl1
Posté le 22-12-2007 à 11:47:13  profilanswer
Installe Real Alternative
Convertir vos Vidéos
n°1339797
_guix_
Posté le 23-12-2007 à 19:10:43  profilanswer
+1  :jap:
Le pack MKV doit être accompagné du Real Alternative pour fonctionner correctement.
www.m4ng.fr - Encodage, Re-encodage, DVD, Mux/Demux, etc... | www.guix.fr - Codec, Tutos, Tout sur la Vidéo Numérique.
  Traitement Vidéo
Aide format WMVimpossible de lire des video
AviSynth : comment ouvrir un format DV ?films format DV vers DVD salon (montage)
Cherche comment changé le format d'un montage (VSP) en format vidéo???Meilleur format video portable de qualité
Video en format "CD1"erreur: counldn't locate decompressor for M4S2 format ?
Impossible de lire un divx format XCT avec BSPLAYERimpossible de lire le format windows media audio v2 :(
Plus de sujets relatifs à : Impossible de lire une au format mkv
