3838 connectés
  Avec quel logiciel peut-on creer une fondu noir a la fin d'un .avi??
n°323194
JediK
Posté le 26-08-2002 à 14:46:53  profilanswer
tt ds la question!!! :hello:
Ressentir les sentiments présents dans la music constitue le premier envol vers la liberté.[:jedik]
n°323200
dbreaker
Posté le 26-08-2002 à 14:53:16  profilanswer
Premiere
On n'est pas le meilleur parce qu'on le CROIT....on l'est parce qu'on le SAIT.
n°323202
JediK
Posté le 26-08-2002 à 14:54:57  profilanswer
Dbreaker a écrit a écrit :
Premiere
????comment ca Premiere????
n°323243
Suesser
Posté le 26-08-2002 à 15:24:44  profilanswer
Seconde! Le compte est bon... :)
Avec les filtres avisynth  FadeOut / FadeOut2
FadeOut / FadeOut2
FadeOut(clip, int frames)
FadeOut2(clip, int frames)
FadeOut and FadeOut2 cause the video stream to fade linearly to black at the end. The sound track (if present) also fades linearly to silence. The fading affects only the last number-of-frames frames of the video. The last frame of the video becomes almost-but-not-quite black. An additional perfectly black frame is added at the end, thus increasing the total frame count by one.
FadeOut2 works similarly, except that two black frames are added at the end instead of one. The only purpose of this is to work around a bug in Windows Media Player. All the WMP versions that I've tested fail to play the last frame of an MPEG file--instead, they stop on the next-to-last frame when playback ends. This leaves an unsightly almost-but-not-quite-black frame showing on the screen when the movie ends if you use FadeOut. FadeOut2 avoids this problem.
FadeOut(clip,n) is just a shorthand for Dissolve(clip,Blackness(clip,n+1),n) (or n+2 instead of n+1 for FadeOut2). There is no corresponding FadeIn command, but you can get the same effect by reversing the arguments to Dissolve: Dissolve(Blackness(n+1,clip),clip,n).
n°323257
FRACTAL
Posté le 26-08-2002 à 15:37:30  profilanswer
c un logiciel de montage de adobe je crois (pas sur)
n°323261
JediK
Posté le 26-08-2002 à 15:39:11  profilanswer
si je comprend bien je dois telecharger avisynth et rajouter les plug-in fadeout!!Mais avisynth c un logiciel???
Message édité par JediK le 26-08-2002 à 15:39:54
ameliorer la qualite d'un .avi avec quel un logiciel???Y a t'il un logiciel pour gerer au mieux un casque audio a frequence??
où trouver une aide en français pour le logiciel reason 1.0 de propellRIP DVD et encodage DivX: quel est le meilleur logiciel ?
Logiciel pour se constituer sa base perso de CD audio ?conversation par casque/micro en lan; quel logiciel utiliser?
logiciel pour virer les paroles des chansonsSondage: Quel logiciel utilisez vous pour lire des DVD sur votre PC?
problem pour creer un dvd avec des fichier datsortie noir et blanc
Plus de sujets relatifs à : Avec quel logiciel peut-on creer une fondu noir a la fin d'un .avi??
