9003 connectés
  Traitement Audio
  sound card TerraTec Aureon XFire HD 8.0 USB
n°1872205
rodcollare​sbr
Posté le 13-08-2013 à 15:25:00  profilanswer
Hi guys, first time using this forum, so im not sure this is the right place to post it, so excuse me if its not.
So, this is the problem, i have the external sound card TerraTec Aureon XFire HD 8.0 USB, and i also have one headset Razer Tiamat 7.1.
Im trying to make them work together.
Im using Windows 7 64bit sp1 on a dell notebook.
The system recognizes the device, but it also says that it can be started, Error code 10.
I tried to contact the support, and they told me to make sure that the switch under the device was on the U2 position, ok it is. They also sent to me a link to download the driver , already did, nothing happened, same error.
If anyone could help me , that would be great, if guys need more info please contact me.
My skype: rodrigo_cll
Email : rodrigo.collares.ti@gmail.com
Thanks for your help, have you all a great week.
PS: You can answer to me in english,french, spanish or portuguese! =D
  Traitement Audio
[HELP] Pas de son Realtek audio HDComment faire une acquisition video en HD via hdmi
Dac audio sur Freebox Hd V5[Tutoriel] Sauvegardez vos HD DVD avant qu'il ne soit trop tard.
Asrock FM2A85X Extreme4-M Audio HD 7.1Problème son Siberia V2 USB
enceintes / ampli et sound blaster xi-fi HDExiste t'il un DD double tuner TNT HD avec VOD ?
Plus de sujets relatifs à : sound card TerraTec Aureon XFire HD 8.0 USB
