4485 connectés
  SQL/NoSQL
  Probleme requête alter table
n°1958439
masseur
Posté le 17-01-2010 à 14:37:26  profilanswer
Bonjour.
Voici la bdd qui a été générée par doctrine (je suis sous mysql 5.1).
Code :
  1. CREATE TABLE sf_guard_forgot_password (id BIGINT AUTO_INCREMENT, user_id BIGINT NOT NULL, unique_key VARCHAR(255), expires_at DATETIME NOT NULL, created_at DATETIME NOT NULL, updated_at DATETIME NOT NULL, INDEX user_id_idx (user_id), PRIMARY KEY(id)) ENGINE = INNODB;
  2. CREATE TABLE sf_guard_group (id BIGINT AUTO_INCREMENT, name VARCHAR(255) UNIQUE, description TEXT, created_at DATETIME NOT NULL, updated_at DATETIME NOT NULL, PRIMARY KEY(id)) ENGINE = INNODB;
  3. CREATE TABLE sf_guard_group_permission (group_id BIGINT, permission_id BIGINT, created_at DATETIME NOT NULL, updated_at DATETIME NOT NULL, PRIMARY KEY(group_id, permission_id)) ENGINE = INNODB;
  4. CREATE TABLE sf_guard_permission (id BIGINT AUTO_INCREMENT, name VARCHAR(255) UNIQUE, description TEXT, created_at DATETIME NOT NULL, updated_at DATETIME NOT NULL, PRIMARY KEY(id)) ENGINE = INNODB;
  5. CREATE TABLE sf_guard_remember_key (id BIGINT AUTO_INCREMENT, user_id BIGINT, remember_key VARCHAR(32), ip_address VARCHAR(50), created_at DATETIME NOT NULL, updated_at DATETIME NOT NULL, INDEX user_id_idx (user_id), PRIMARY KEY(id)) ENGINE = INNODB;
  6. CREATE TABLE sf_guard_user (id BIGINT AUTO_INCREMENT, first_name VARCHAR(255), last_name VARCHAR(255), email_address VARCHAR(255) NOT NULL UNIQUE, username VARCHAR(128) NOT NULL UNIQUE, algorithm VARCHAR(128) DEFAULT 'sha1' NOT NULL, salt VARCHAR(128), password VARCHAR(128), is_active TINYINT(1) DEFAULT '1', is_super_admin TINYINT(1) DEFAULT '0', last_login DATETIME, created_at DATETIME NOT NULL, updated_at DATETIME NOT NULL, INDEX is_active_idx_idx (is_active), PRIMARY KEY(id)) ENGINE = INNODB;
  7. CREATE TABLE sf_guard_user_group (user_id BIGINT, group_id BIGINT, created_at DATETIME NOT NULL, updated_at DATETIME NOT NULL, PRIMARY KEY(user_id, group_id)) ENGINE = INNODB;
  8. CREATE TABLE sf_guard_user_permission (user_id BIGINT, permission_id BIGINT, created_at DATETIME NOT NULL, updated_at DATETIME NOT NULL, PRIMARY KEY(user_id, permission_id)) ENGINE = INNODB;
  9. CREATE TABLE sf_guard_user_profile (id BIGINT AUTO_INCREMENT, user_id INT NOT NULL, email VARCHAR(255), hash VARCHAR(32), validate bool, INDEX user_id_idx (user_id), PRIMARY KEY(id)) ENGINE = INNODB;
  10. ALTER TABLE sf_guard_forgot_password ADD CONSTRAINT sf_guard_forgot_password_user_id_sf_guard_user_id FOREIGN KEY (user_id) REFERENCES sf_guard_user(id) ON DELETE CASCADE;
  11. ALTER TABLE sf_guard_group_permission ADD CONSTRAINT sf_guard_group_permission_permission_id_sf_guard_permission_id FOREIGN KEY (permission_id) REFERENCES sf_guard_permission(id) ON DELETE CASCADE;
  12. ALTER TABLE sf_guard_group_permission ADD CONSTRAINT sf_guard_group_permission_group_id_sf_guard_group_id FOREIGN KEY (group_id) REFERENCES sf_guard_group(id) ON DELETE CASCADE;
  13. ALTER TABLE sf_guard_remember_key ADD CONSTRAINT sf_guard_remember_key_user_id_sf_guard_user_id FOREIGN KEY (user_id) REFERENCES sf_guard_user(id) ON DELETE CASCADE;
  14. ALTER TABLE sf_guard_user_group ADD CONSTRAINT sf_guard_user_group_user_id_sf_guard_user_id FOREIGN KEY (user_id) REFERENCES sf_guard_user(id) ON DELETE CASCADE;
  15. ALTER TABLE sf_guard_user_group ADD CONSTRAINT sf_guard_user_group_group_id_sf_guard_group_id FOREIGN KEY (group_id) REFERENCES sf_guard_group(id) ON DELETE CASCADE;
  16. ALTER TABLE sf_guard_user_permission ADD CONSTRAINT sf_guard_user_permission_user_id_sf_guard_user_id FOREIGN KEY (user_id) REFERENCES sf_guard_user(id) ON DELETE CASCADE;
  17. ALTER TABLE sf_guard_user_permission ADD CONSTRAINT sf_guard_user_permission_permission_id_sf_guard_permission_id FOREIGN KEY (permission_id) REFERENCES sf_guard_permission(id) ON DELETE CASCADE;
  18. [B]ALTER TABLE sf_guard_user_profile ADD CONSTRAINT sf_guard_user_profile_user_id_sf_guard_user_id FOREIGN KEY (user_id) REFERENCES sf_guard_user(id) ON DELETE CASCADE;[/B]
J'ai une erreur au niveau de la ligne en gras et je ne comprends pas ou est le problème!!!!
J'obtiens ceci comme erreur.
#1005 - Can't create table 'xxxxxxxx.#sql-884_50' (errno: 150)
Merci par avance pour votre aide
Message édité par gilou le 18-01-2010 à 09:00:59
n°1958488
MagicBuzz
Posté le 18-01-2010 à 09:59:55  profilanswer
question : l'ensemble des tables est-il créé ? (outre les contraintes que tu tentes de créer ensuite)
En effet, vu l'erreur, c'est pas la dernière ligne qui plante, mais la création d'une table.
Vu que c'est pas transactionnel la création de tables, la table qui plante ne doit pas être crée, mais les autres qui sont déjà passées le sont.
Si y'en a aucune, ça sent le requêteur pourri qui ne supporte pas le ";" comme séparateur d'instruction.
Essaie alors de lancer les requêtes une à une.
n°1958536
gilou
Modosaurus Rex
Posté le 18-01-2010 à 14:39:31  profilanswer
A tout hasard, avec BIGINT à la place, ça passerait pas mieux? vu que le contrainte porte entre ce champ et sf_guard_user(id) qui lui est un BIGINT, si j'ai bien compris.
A+,
There's more than what can be linked! --  Le capitaine qui ne veut pas obéir à la carte finira par obéir aux récifs. -- Il ne faut plus dire Sarkozy, mais Sarkozon -- (╯°□°)╯︵ ┻━┻
  SQL/NoSQL
Zend partial() Problème de cheminProblème de charge CPU mysqld, sans aucune requete ...
Probleme de chargement de module PHP 5.3 PHP_SNMP.DLL[SHELL] Connexion base DB2 + lancement requête dans fichier .sql
[RESOLU] Problème d'affichage d'une deuxième fenêtreprobleme avec htaccess
Problème d'organisation des fenêtre de mon logiciel[résolu] Probleme alignement menu sous Firefox
Plus de sujets relatifs à : Probleme requête alter table
