5517 connectés
  PHP
  Probleme pour installer un livre d'or
n°1903443
playboy
Oo
Posté le 08-07-2009 à 09:44:58  profilanswer
Bonjours, je suis en train de crée un site internet et je l'herberge avec le ftp de 10giga de free.
Le probleme et que j'ai toujours des problemes comme:
Warning: main(./include/config_default.inc.php) [function.main]: failed to open stream: No such file or directory in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 183
Warning: main() [function.include]: Failed opening './include/config_default.inc.php' for inclusion (include_path='/mnt/147/sda/4/4/anomalie13/include:.:/usr/php4/lib/php') in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 183
Warning: main(./include/constants.php) [function.main]: failed to open stream: No such file or directory in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 185
Warning: main() [function.include]: Failed opening './include/constants.php' for inclusion (include_path='/mnt/147/sda/4/4/anomalie13/include:.:/usr/php4/lib/php') in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 185
Warning: main(./include/functions.inc.php) [function.main]: failed to open stream: No such file or directory in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 186
Warning: main() [function.include]: Failed opening './include/functions.inc.php' for inclusion (include_path='/mnt/147/sda/4/4/anomalie13/include:.:/usr/php4/lib/php') in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 186
Warning: main(./admin/include/functions.php) [function.main]: failed to open stream: No such file or directory in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 187
Warning: main() [function.include]: Failed opening './admin/include/functions.php' for inclusion (include_path='/mnt/147/sda/4/4/anomalie13/include:.:/usr/php4/lib/php') in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 187
Warning: main(./admin/include/functions_upgrade.php) [function.main]: failed to open stream: No such file or directory in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 188
Warning: main() [function.include]: Failed opening './admin/include/functions_upgrade.php' for inclusion (include_path='/mnt/147/sda/4/4/anomalie13/include:.:/usr/php4/lib/php') in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 188
Fatal error: Call to undefined function: get_languages() in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 198
D'ou vien ce probleme? J'ai des procleme pour installer nimporte quel script php. Quelle est la chose que je fait mal?
n°1903462
infoman64
JE SUIS LA POUR TOI MON AMI
Posté le 08-07-2009 à 10:29:21  profilanswer
soit tu as mal configurer ton application(chemin par exemple)
soit il te manque des fichiers.
et tu sur que dans tes include tu passe le bon chemin?
n°1903470
playboy
Oo
Posté le 08-07-2009 à 10:41:01  profilanswer
Le script a été téléchargé donc il est bon.
Les fichiers sont tous la mais peu etre qu'il faut que je cree des dossiers.
Esqu'il faut que je cree: ./admin/include/ ou il se creéra tout seul?
n°1903484
infoman64
Posté le 08-07-2009 à 11:00:43  profilanswer
ben les fichiers ils sont a quel niveau?
ils sont au même niveau que le fichier que tu appele?
si c'est le cas regarde si tu as une pas configuration de ton script,
sinon oui tu dois ranger tous tes fichiers dans chaque dossier comme il faut, ou changer le chemin de tes includes!!
bizarre ton script si tu dois ranger ou modifier tous les chemins!!!
n°1903511
playboy
Oo
Posté le 08-07-2009 à 11:45:23  profilanswer
Je suis novice en php. Comment fait t'on pour savoir le nom de tout les dossiers et pour savoir quel fichier va dans tel dossier?
Quand je telecharge un script tout les fichiers sont dans le meme dossier.
n°1903566
infoman64
Posté le 08-07-2009 à 13:03:17  profilanswer
tu peut pas savoir dans quel dossier va t'elle fichier, c'est impossible a savoir sauf si tu as 2 ou 3 fichiers ou si c'est toi qui a crée le script
mais je pense avoir compris ton probleme, le script que tu as telechargé n'est pas zippé par hasard?
Message édité par infoman64 le 08-07-2009 à 13:03:54
n°1903621
playboy
Oo
Posté le 08-07-2009 à 14:40:28  profilanswer
Oui il est zippé.
n°1903630
infoman64
Posté le 08-07-2009 à 14:54:21  profilanswer
je pense que tu as du utilisé winzip( il te met a plat tous les fichiers)
utilise winrar , et tu fais extraire vers un dossier,
tu verra tes fichiers seront rangés dans les dossiers correctement.
n°1903650
playboy
Oo
Posté le 08-07-2009 à 15:22:03  profilanswer
Ha ca m'apprendra a laisser une chance a winzip pour une fois! Je réinstal winrar desuite.
Merci je vais tester ca!
n°1903753
aideinfo
Posté le 08-07-2009 à 16:24:35  profilanswer
Tu dois avoir une option dans WinZip pour décompresser en respectant l'arborescence.
http://www.aideinfo.com/  Whois adresses IP/domaines le plus évolué !!  FAQ Free Mobile
n°1903892
z0rglub
Posté le 09-07-2009 à 00:30:16  profilanswer
Je suis le créateur de Piwigo (une alerte Google m'a amené sur ce forum qui a accompagné les premiers pas du projet il y a 7 ans).
Un livre d'or ? Piwigo n'est pas un livre d'or mais un galerie photo. Enfin, ce n'est pas le problème.
Est-ce que tu as essayé la NetInstall qu'on a sortie en 2.0 ? Il n'y a qu'un script PHP à transférer sur ton site et ensuite il s'occupe de télécharger le zip Piwigo, de le dézipper, mettre les bons droits et lance la procédure d'installation.
Bon sinon je confirme les suppositions de aideinfo, c'est très probablement ton "désarchiveur" qui a aplatit l'arborescence de répertoires inclut dans le zip.
  PHP
probleme de communication sériePL/SQL : Problème d'apostophes dans génération de liste de valeurs
problème de jointure dans ma requette[java] Problème d'optimisation de traitements batch
Problème rafraichissement JTable[RESOLU] Problème de vérouillage dans ma feuille excel
[OK] problème d'éxécution du PHP sur mon serveur apache (sous centos)au secours probleme joomla et Internet Explorer
[résolu] probleme fopen : php_network_getaddresses[imagemagick] problème pour récuperer la valeur d'un pixel
Plus de sujets relatifs à : Probleme pour installer un livre d'or
