1630 connectés
  Python
  Problème de configuration MySQL sur Django
n°1950602
Magg27
Posté le 15-12-2009 à 17:27:32  profilanswer
J'ai installé le framework Django, j'ai paramétré le fichier settings.py pour qu'il puisse utiliser ma base SQL :
Code :
  1. # Django settings for bcgw project.
  2. DEBUG = True
  3. TEMPLATE_DEBUG = DEBUG
  4. ADMINS = (
  5.     # ('Your Name', 'your_email@domain.com'),
  6. )
  7. MANAGERS = ADMINS
  8. DATABASE_ENGINE = 'mysql'           # 'postgresql_psycopg2', 'postgresql', 'mysql', 'sqlite3' or 'oracle'.
  9. DATABASE_NAME = 'bcgw'             # Or path to database file if using sqlite3.
  10. DATABASE_USER = 'admin'             # Not used with sqlite3.
  11. DATABASE_PASSWORD = 'xxxxx'         # Not used with sqlite3.
  12. DATABASE_HOST = ''             # Set to empty string for localhost. Not used with sqlite3.
  13. DATABASE_PORT = ''             # Set to empty string for default. Not used with sqlite3.
Et lorsque je lance la commande
Code :
  1. python manage.py runserver
j'ai ce message d'erreur :
Code :
  1. Validating models...
  2. Unhandled exception in thread started by <function inner_run at 0x2a994a0320>
  3. Traceback (most recent call last):
  4.   File "/usr/local/lib/python2.5/site-packages/django/core/management/commands/runserver.py", line 48, in inner_run
  5.     self.validate(display_num_errors=True)
  6.   File "/usr/local/lib/python2.5/site-packages/django/core/management/base.py", line 249, in validate
  7.     num_errors = get_validation_errors(s, app)
  8.   File "/usr/local/lib/python2.5/site-packages/django/core/management/validation.py", line 22, in get_validation_errors
  9.     from django.db import models, connection
  10.   File "/usr/local/lib/python2.5/site-packages/django/db/__init__.py", line 41, in <module>
  11.     backend = load_backend(settings.DATABASE_ENGINE)
  12.   File "/usr/local/lib/python2.5/site-packages/django/db/__init__.py", line 17, in load_backend
  13.     return import_module('.base', 'django.db.backends.%s' % backend_name)
  14.   File "/usr/local/lib/python2.5/site-packages/django/utils/importlib.py", line 35, in import_module
  15.     __import__(name)
  16.   File "/usr/local/lib/python2.5/site-packages/django/db/backends/mysql/base.py", line 13, in <module>
  17.     raise ImproperlyConfigured("Error loading MySQLdb module: %s" % e)
  18. django.core.exceptions.ImproperlyConfigured: Error loading MySQLdb module: /root/.python-eggs/MySQL_python-1.2.3c1-py2.6-linux-i686.egg-tmp/_mysql.so: cannot open shared object file: No such file or directory
Je suis sous RedHat EL 4
Avez-vous une idée de la solution ?
Merci   :)
n°1950612
Magg27
Posté le 15-12-2009 à 18:07:00  profilanswer
En fait j'ai ma petite idée, en recherchant sur le net j'ai vu qu'il fallait installé MySQL-python-1.2.3c1. Mais lorsque je lance la commande
Code :
  1. python setup.py build
j'ai plein d'erreurs. En voici un bout :
Code :
  1. _mysql.c: At top level:
  2. _mysql.c:2487: error: syntax error before '*' token
  3. _mysql.c:2490: warning: function declaration isn't a prototype
  4. _mysql.c: In function `_mysql_ConnectionObject_setattr':
  5. _mysql.c:2491: error: `v' undeclared (first use in this function)
  6. _mysql.c:2502: error: `name' undeclared (first use in this function)
  7. _mysql.c:2503: error: `self' undeclared (first use in this function)
  8. _mysql.c: At top level:
  9. _mysql.c:2512: error: syntax error before '*' token
  10. _mysql.c:2515: warning: function declaration isn't a prototype
  11. _mysql.c: In function `_mysql_ResultObject_setattr':
  12. _mysql.c:2516: error: `v' undeclared (first use in this function)
  13. _mysql.c:2527: error: `name' undeclared (first use in this function)
  14. _mysql.c:2528: error: `self' undeclared (first use in this function)
  15. error: command 'gcc' failed with exit status 1
n°1951417
Remigio
Radio Flip, 72.8
Posté le 18-12-2009 à 10:00:42  profilanswer
tu peux pas le faire avec easy_install ?
Everybody can succeed, all you need is to believe
n°1951438
Magg27
Posté le 18-12-2009 à 11:03:45  profilanswer
j'ai essayé mais ça marche pas ... En plus je n'ai pas la possibilité d'avoir Internet sur le PC (pour des raison de sécurité l'entreprise où je bosse l'a interdit). Mais ce n'est pas grave, du coup je ne vais pas utiliser Django. Merci bien quand même !!
  Python
probleme avec dreamweaver en mode affichage creéationNotice Index : je n'arrive pas à résoudre le probleme
PHP SQL probleme ORDER BY , GROUP BY...probleme affichage suite a une requete
probleme de gravureConfiguration de wamp
Problème de redimensionnement image en javascriptprobleme liste deroulante
Problème de modélisation PowerDesignerProbleme de double dans un JTextField
Plus de sujets relatifs à : Problème de configuration MySQL sur Django
