2123 connectés
  PHP
  ou mettre ce Order by?
n°1737246
francescu
youpee !!
Posté le 26-05-2008 à 15:11:38  profilanswer
j ai ceci sur ma page de recherche,
je voudrai trier par prix mais je ne sais pas ou mettre ce "Order by"  :pt1cable:
Je sais que le order vient apres le where, j ai donc fais des tests mais en vain.
Code :
  1. if(isset($action)) {
  2. //--------------------- recuperation des enregistrements ---------
  3. $tab_champs = array("type","type_bien","nb_piece", "surface" );
  4. $query = "select * from bien  where";
  5. $i=0;
  6. $ajouter_and = false;
  7. foreach($rechercher as $champs) {
  8.   if($champs!="0" ) {
  9.   if($ajouter_and) {
  10.    $query .= " and ";
  11.   } else {
  12.    $query .= " ";
  13.   }
  14.   $ajouter_and = true;
  15.  if($i==3){
  16.   if($champs!="0" ) {
  17.   $condition = '';
  18.   switch ($champs)
  19.   {
  20.      case 20:
  21.     $condition = "surface >= '0' AND surface <= '20'";
  22.     break;
  23.      case 50:
  24.     $condition = "surface > '21' AND surface <= '50'";
  25.     break;
  26.      case 75:
  27.     $condition = "surface > '51' AND surface <= '75'";
  28.     break;
  29.      case 100:
  30.     $condition = "surface > '76' AND surface <= '100'";
  31.     break;
  32.    case 150:
  33.     $condition = "surface > '101' AND surface <= '150'";
  34.     break;
  35.      case 200:
  36.     $condition = "surface > '151' AND surface <= '200'";
  37.     break;
  38.      case 250:
  39.     $condition = "surface > '201' AND surface <= '250'";
  40.     break;
  41.      case 300:
  42.     $condition = "surface > '251' AND surface <= '300'";
  43.     break;
  44.     case 301:
  45.     $condition = "surface > '300'";
  46.     break;
  47.    }
  48.   }
  49.   $query .= $condition;
  50.  } else {
  51.   $query .= $tab_champs[$i]."='".$champs."'";
  52.  }
  53.  }
  54.  $i++;
  55. }
  56. if($ajouter_and==false)  $query .= " 1";
  57. $result = mysql_query($query);
  58. $nb_bien = mysql_num_rows($result);
  59. }
merci de votre aide :)
Bien a vous
n°1737249
skeye
Posté le 26-05-2008 à 15:13:19  profilanswer
c'est pas du php, c'est du sql.
Lis une doc sql sur order by.
Can't buy what I want because it's free -
n°1737257
francescu
youpee !!
Posté le 26-05-2008 à 15:28:36  profilanswer
je t assure : if, else, foreach etc c'est bien du php...
Effectivemet c est dans la requete sql que je bloque, et j ai deux bouquins sous les yeux mais ils ne font pas de conditions assez poussées.
n°1737258
flo850
moi je
Posté le 26-05-2008 à 15:32:13  profilanswer
tu as raison de lui expliquer, il débute
nan , mais serieusement le problème c'est que tu ne sais pas construire dune requete SQL [:proy]
tu trouevra las yntaxe complete de SELECT dans la doc de mysql http://dev.mysql.com/doc/refman/5.0/fr/select.html
n°1737260
skeye
Posté le 26-05-2008 à 15:33:20  profilanswer
[:bertie wooster]
n°1737417
francescu
youpee !!
Posté le 26-05-2008 à 20:51:44  profilanswer
merci,
mais je connais la syntaxe du select...
seulement je ne sais pas rajouter le order by dans cette condition en ph.... euh en c++ :)
Message édité par francescu le 26-05-2008 à 20:53:39
n°1737418
couak
Posté le 26-05-2008 à 20:55:24  profilanswer
francescu a écrit :
merci,
bah justement non, tu sais pas où placer le ORDER BY
francescu a écrit :
seulement je ne sais pas rajouter le order by dans la condition en ph.... euh en c++ :)
en C, en php ou en Borland Z++, du SQL reste du SQL
Il faut déjà arriver à faire correctement du SQL avant d'essayer de le construire avec du code, car sinon il se retrouve noyé dans le code source et tu t'y perds
n°1737419
flo850
moi je
Posté le 26-05-2008 à 20:55:49  profilanswer
francescu a écrit :
merci,
nan, je pense pas
n°1737433
francescu
youpee !!
Posté le 26-05-2008 à 21:29:27  profilanswer
ok merci
Message édité par francescu le 26-05-2008 à 21:32:45
n°1737440
couak
Posté le 26-05-2008 à 21:39:41  profilanswer
essaies déjà de faire ta requete SQL avec le ORDER BY, je pense que tu comprendras mieux la syntaxe, surtout quand tu sais que ca se palce après le WHERE
  PHP
Mettre la date sous forme jj-mm-aaaa sous DOSmettre une seule virgule sur delphi
[html / css] Mettre une image en bordureplusieurs ORDER BY
VBScript : mettre une image dans un fichiermettre des puces dans un message
Mettre en place un cookie[CSS] Mettre l'image background du body au 1er plan
mettre à jour une table à partir d'un dragdrop YUI
Plus de sujets relatifs à : ou mettre ce Order by?
