2409 connectés
  PHP
  Include php et problème menu déroulant
n°1601370
GHammond
Posté le 20-08-2007 à 19:13:09  profilanswer
Salut :D
J'ai 2 petits problèmes.
1) J'ai un menu déroulant de base :
Code :
  1. <select id="Menu" onchange="ChangeUrl(this.form)">
  2.           <option value="" selected="selected">-Acc&egrave;s Rapide-</option>
  3.           <option value="index.php?page=malphabet">Alphabet </option>
  4.           <option value="index.php?page=eecriture">Alphabet 6/7</option>
  5.           <option value="index.php?page=mpoisson">Aquarium</option>
  6.           <option value="index.php?page=mcalendrier">Calendriers</option>
  7.           <option value="index.php?page=mchorale">Chorale</option>
  8.           <option value="index.php?page=mcirque">Cirque</option>
  9.           <option value="index.php?page=ecrique">Cirque 6/7</option>
  10.           <option value="index.php?page=mcoloriage">Coloriages</option>
  11.           <option value="index.php?page=mcomptine">Comptines</option>
  12.           <option value="index.php?page=ecomptine">Comptines 6/7</option>
  13.           <option value="index.php?page=mferme">Ferme</option>
  14.           <option value="index.php?page=eferme">Ferme 6/7</option>
  15.           <option value="index.php?page=mforet">For&ecirc;t</option>
  16.           <option value="index.php?page=eforet">For&ecirc;t 6/7</option>
  17.           <option value="index.php?page=mjardinage">Jardinage</option>
  18.           <option value="index.php?page=ejardinage">Jardinage 6/7</option>
  19.           <option value="index.php?page=mlabyrinthe">Labyrinthes</option>
  20.           <option value="index.php?page=mmathematique">Math&eacute;matiques</option>
  21.           <option value="index.php?page=emath">Math&eacute;matiques 6/7</option>
  22.           <option value="index.php?page=mnoel">No&euml;l</option>
  23.           <option value="index.php?page=mnutrition">Nutrition</option>
  24.           <option value="index.php?page=mphonologie">Phonologie</option>
  25.           <option value="index.php?page=ephonetique">Phonologie 6/7</option>
  26.           <option value="index.php?page=mpoesie">Po&eacute;sies</option>
  27.           <option value="index.php?page=mpoisson">Poissons</option>
  28.           <option value="index.php?page=mrecette">Recettes</option>
  29.           <option value="index.php?page=mson">Sons</option>
  30.           <option value="index.php?page=msorciere">Sorci&egrave;res</option>
  31.           <option value="index.php?page=esorciere">Sorci&egrave;res 6/7</option>
  32.           <option value="index.php?page=mtheatre">Th&eacute;&acirc;tre</option>
  33.         </select>
Déjà est-ce une bonne idées ? Et surtout => Sa marche pas, je n'arrive pas à inclure quoi que ce soit venant de cette liste.
Quelles améliorations puis-je faire ?
2) Ya plein de page sur mon site... Mais je veut quelles soient TOUTES affichées dans index.php qui me sert de "décor", mon squelette :D
Le problème actuellement et que chaque lien doit avoir "index.php?page="
C'est vite.... embetant.
Qu'est ce que je peut optimiser ?
Merci beaucoup :sol:
n°1601591
GHammond
Posté le 21-08-2007 à 09:51:36  profilanswer
up c'est urgent... plzzzz
n°1601629
omega2
Posté le 21-08-2007 à 10:44:17  profilanswer
A un détail près, j'aurais dit "pourquoi pas?" mais là je vois un gros défaut : ils font comment ceux qui ont javascript de désactivé?
Utilise donc le select dans un formulaire classique avec un bouton de validation (que tu rendras invisible si javascript est activé) et quand un élément est sélectionné, tu fais une validation du formulaire.
Ca sera beaucoup mieux au niveau accessibilité.
Ca veut dire quoi "Sa marche pas"? Tu n'as pas de changement de page? Ton include est foireux? T'as une erreur javascript dans ton navigateur? Une erreur php quand tu changes de page?
Faute d'informations précises, on ne peut pas te dépanner.
Message édité par omega2 le 21-08-2007 à 10:45:23
n°1601676
leflos5
On est ou on est pas :)
Posté le 21-08-2007 à 13:08:26  profilanswer
Moi je passerais en valeur que celle de la page :whistle:
Après tu vois ça dans ta fonction JS pour rajouter le index.php?page=
Et en effet peut être que des liens seraient plus adaptés ici?
  PHP
PROBLEME D'AFFICHAGE DE DATE DE HEURE EN TEMPS REELCompilation: probleme ajout de librairies
probleme SELECT en MATCH avec du HTML...probleme d'image sur un titre (html+css)
Problème d'erreur: Can't connect to local MySQLsous menu flash
probleme pattern pour eregi_replace()[JS]Problème d'execution de fction sur onchange() avec IE7
Menu de menus de menusProbleme marge IE et objet COM
Plus de sujets relatifs à : Include php et problème menu déroulant
