8868 connectés
  VB/VBA/VBS
  pb script VBA sous Word pour export feuilles - laisse 1 page
n°2333760
nicolasmey​er
Si je peux aider...
Posté le 21-05-2019 à 11:53:21  profilanswer
J'ai effectué un publipostage à partir d'une base de données excel sur Word (via l'aide de certaines personnes ici, encore grand merci) (https://forum.hardware.fr/hfr/WindowsSoftware/Securite/recupere-fichier-document-sujet_351116_1.htm#t3343552),
Puis, j'ai utilisé une macro VBA pour exporter toutes les feuilles séparément,
par contre, ca laisse toujours une page en plus. Que faire? Une idee?   :hello:  :hello:  :ouch:  :ouch:  :pt1cable:
voici le code que je mets :
Sub SplitIntoPages()
Dim docMultiple As Document
Dim docSingle As Document
Dim rngPage As Range
Dim iCurrentPage As Integer
Dim iPageCount As Integer
Dim strNewFileName As String
Application.ScreenUpdating = False 'Makes the code run faster and reduces screen flicker a bit.
Set docMultiple = ActiveDocument 'Work on the active document (the one currently containing the Selection)
Set rngPage = docMultiple.Range 'instantiate the range object
iCurrentPage = 1
'get the document's page count
iPageCount = docMultiple.Content.ComputeStatistics(wdStatisticPages)
Do Until iCurrentPage > iPageCount
If iCurrentPage = iPageCount Then
rngPage.End = ActiveDocument.Range.End 'last page (there won't be a next page)
Else
'Find the beginning of the next page
'Must use the Selection object. The Range.Goto method will not work on a page
Selection.GoTo wdGoToPage, wdGoToAbsolute, iCurrentPage + 1
'Set the end of the range to the point between the pages
rngPage.End = Selection.Start
End If
rngPage.Copy 'copy the page into the Windows clipboard
Set docSingle = Documents.Add 'create a new document
docSingle.Range.Paste 'paste the clipboard contents to the new document
'remove any manual page break to prevent a second blank
docSingle.Range.Find.Execute Findtext:="^m", ReplaceWith:=""
'build a new sequentially-numbered file name based on the original multi-paged file name and path
strNewFileName = Replace(docMultiple.FullName, ".doc", "_" & Right$("000" & iCurrentPage, 4) & ".doc" )
docSingle.SaveAs strNewFileName 'save the new single-paged document
iCurrentPage = iCurrentPage + 1 'move to the next page
docSingle.Close 'close the new document
rngPage.Collapse wdCollapseEnd 'go to the next page
Loop 'go to the top of the do loop
Application.ScreenUpdating = True 'restore the screen updating
'Destroy the objects.
Set docMultiple = Nothing
Set docSingle = Nothing
Set rngPage = Nothing
End Sub
merci par avance de votre aide.
Nicolas
  VB/VBA/VBS
Script qui récupère données fichier Excel vers documentExport mails dans Excel
VBA - Erreur ExécutionAfficher le contenu d'un fichier log dans une page HTML
macro vba/word concaténer 2 paragraphesAide vba word choix dans une liste
Affichage variable selon page webRecherche script PHP pour créer des bases de données
Copier tableau Excel sous Word page définie
Plus de sujets relatifs à : pb script VBA sous Word pour export feuilles - laisse 1 page
