3553 connectés
Sujet : calcul de p rating amd
goer
Un logiciel, uAMDtool, vient d'être développé, il permet de connaître la fréquence des processeurs AMD (du Duron aux CPU 64-bit) en fonction du PR Rating ainsi que ses caractéristiques. Toutefois, il est loin d'être parfait.
uAMDtool integrates an accurate AMD Quantispeed PR rating calculator with other commonly used AMD-based tools.
The Quantispeed calculator has full support of Morgan, Palomino, T-Bred, Barton and AMD64 processors, and fully supports overclocked front side bus speeds with unrivalled accuracy for all modes.
Added is a CPU stepping decoder which lists all known details about your specific CPU, a full list of stock AMD AthlonXP and Athlon64 settings so you can see how much performance you're gaining from that higher FSB, and a clutter-free small version which can be invoked from the command line or from the main interface.
download ici ------->http://home.btconnect.com/barneycomputers/amd/tool2a.zip
goer
