4964 connectés
Sujet : transformer sa geforce en nvidia quadro
zorg cpu duron 700@1030 (pour 3dmark) mais 1040 stable tout partout ailleur.
3DMark Result 6426 3D marks
CPU Speed 521 CPU 3D marks
Game 1 - Helicopter - Low Detail 125.1 FPS
Game 1 - Helicopter - Medium Detail 93.7 FPS
Game 1 - Helicopter - High Detail 49.5 FPS
Game 2 - Adventure - Low Detail 142.5 FPS
Game 2 - Adventure - Medium Detail 77.5 FPS
Game 2 - Adventure - High Detail 47.1 FPS
Fill Rate (Single-Texturing) 461.8 MTexels/s
Fill Rate (Multi-Texturing) 904.2 MTexels/s
High Polygon Count (1 Light) 13878 KTriangles/s
High Polygon Count (4 Lights) 11019 KTriangles/s
High Polygon Count (8 Lights) 6513 KTriangles/s
8MB Texture Rendering Speed 325.6 FPS
16MB Texture Rendering Speed 300.4 FPS
32MB Texture Rendering Speed 198.4 FPS
64MB Texture Rendering Speed 104.7 FPS
Bump Mapping (Emboss 3-pass) 218.2 FPS
Bump Mapping (Emboss 2-pass) 285.3 FPS
Bump Mapping (Emboss 1-pass) 352.4 FPS
Bump Mapping (Environment) N/A FPS
Avec une 2MX => quadro 2 MXR
zoub iiiiiiiiiiii comtrole c et v foire
zoub et voila sur ma [#f00e00]G[#0046b8]orce 2 GTS
teste sur [#0000e2]3[#0000f0]MARK 2001
3DMark Result
(3D marks)  0
3942
Game 1 - Car Chase - Low Detail
(FPS)   Not available
67.9
Game 1 - Car Chase - High Detail
(FPS)   Not available
24.0
Game 2 - Dragothic - Low Detail
(FPS)   Not available
66.7
Game 2 - Dragothic - High Detail
(FPS)   Not available
26.6
Game 3 - Lobby - Low Detail
(FPS)   Not available
83.7
Game 3 - Lobby - High Detail
(FPS)   Not available
37.4
Game 4 - Nature
(FPS)   Not available
 Not available
(MTexels/s)   Not available
586.1
950.8
(MTriangles/s)   Not available
19.6
3.6
Environment Bump Mapping
(FPS)   Not available
 Not available
DOT3 Bump Mapping
(FPS)   Not available
79.6
Vertex Shader Speed
(FPS)   Not available
37.2
Pixel Shader Speed
(FPS)   Not available
 Not available
Point Sprite Speed
(MSprites/s)   Not available
10.0
 :hot: dite mois plizzzzz  :gun:
gmmatt non je suis pas dans paris
et le prix est trop elevé
MLC Hum...fer à souder, pardon...
MLC Bon, j'ai un JBC 26W avec une panne qui a plus de 6 ans (pas mal oxydée...).
Barruckello a fait la gueule en la voyant mais j'ai réparé plein de trucs avec...
Et puis ce faire à souder à pas mal d'experience en modifs PC ;)
J'habite à Montmartre mais demain j'suis en vadrouille!
Donc j'peux passer si t'es sur Paris même...
Voilà voilà!
gmmatt MLC je suis interessé pour t'on offre de faire la modif
car j'ai pas de fer a souder comme il faut
tu as quoi comme fer a souder?
tu habite ou dans paris ?
touk tu pourrais me l'envoyer aussi :bounce: :bounce: :bounce:
j'ai une :bic: prophet2 GTS en quadro
touk@free.fr
merci :jap: :jap: :jap:
zoub Apas sur ma Gforce 2 gts mais sur Gforce256 sdram 32 mo
zoub re teste avec cpu 7 * 133 @ 933Mhz
3DMark Result 6252 3D marks
CPU Speed 454 CPU 3D marks
Game 1 - Helicopter - Low Detail 130.0 FPS
Game 1 - Helicopter - Medium Detail 93.4 FPS
Game 1 - Helicopter - High Detail 45.5 FPS
Game 2 - Adventure - Low Detail 131.6 FPS
Game 2 - Adventure - Medium Detail 75.1 FPS
Game 2 - Adventure - High Detail 45.4 FPS
Fill Rate (Single-Texturing) 307.3 MTexels/s
Fill Rate (Multi-Texturing) 550.0 MTexels/s
High Polygon Count (1 Light) 13151.6 KTriangles/s
High Polygon Count (4 Lights) 7588.2 KTriangles/s
High Polygon Count (8 Lights) 4045.0 KTriangles/s
8MB Texture Rendering Speed 358.7 FPS
16MB Texture Rendering Speed 314.8 FPS
32MB Texture Rendering Speed 196.6 FPS
64MB Texture Rendering Speed 103.3 FPS
Bump Mapping (Emboss 3-pass) 378.8 FPS
Bump Mapping (Emboss 2-pass) 227.6 FPS
Bump Mapping (Emboss 1-pass) 174.8 FPS
 :bounce: bios dorigine evorvclok core 145 memoi.. 175  :hot:
MLC Steff57, t'as vraiment un problème!!!
3000?!? t'es sûr qu'on parle du même 3D mark, à savoir le "2000"?!?
steff57 Comment tu fais avec un DURON pour avoir autan a 3DMARK ??
Moi j'ai 1 TBIRD 900 et je suis k'a 3000, j'ai aussi 192 Mo de RAm et 1 GTS 2 pro 32Mo....
T'as kel OS?
zoub :bounce: cool la modiffff avant 5528 avec modiffff
3DMark Result 6191 3D marks
CPU Speed 438 CPU 3D marks
Game 1 - Helicopter - Low Detail 126.9 FPS
Game 1 - Helicopter - Medium Detail 93.3 FPS
Game 1 - Helicopter - High Detail 46.9 FPS
Game 2 - Adventure - Low Detail 134.5 FPS
Game 2 - Adventure - Medium Detail 71.4 FPS
Game 2 - Adventure - High Detail 43.0 FPS
Fill Rate (Single-Texturing) 323.4 MTexels/s
Fill Rate (Multi-Texturing) 556.0 MTexels/s
High Polygon Count (1 Light) 12918.1 KTriangles/s
High Polygon Count (4 Lights) 7626.8 KTriangles/s
High Polygon Count (8 Lights) 4050.8 KTriangles/s
8MB Texture Rendering Speed 373.0 FPS
16MB Texture Rendering Speed 312.7 FPS
32MB Texture Rendering Speed 185.2 FPS
64MB Texture Rendering Speed 97.8 FPS
Bump Mapping (Emboss 3-pass) 395.5 FPS
Bump Mapping (Emboss 2-pass) 237.9 FPS
Bump Mapping (Emboss 1-pass) 183.4 FPS
cool
steff57 Et je regle koi d'autre a part le FSB...
Car il y a aussi le PCI clock,
Fast CPU  commande decode?
CPU drive Strenght?
Enhance chip Performance?
Force 4 way Interleave?
Enable 4K-Page Mode?
Dram clock?
Et le voltage on fait koi avec (Core et I/O)
zorg pour UT, pas encore tester, HL ça m'énerve, demain j'aurai le mod counterstriker ça va pt^te me donner envie de jouer. Par contre à Q3, les graphismes sont meilleurs, j'ai l'impression de jouer en 32bits alors que je suis en 16.
Pour ce qui est de 3dmark, j'utilise encore le 2000 et je fais 6402pts après la modif et avant 5627pts, ça vaut le coup non :bounce:  :bounce:  :bounce:
MLC pas grave que t'habites pas à Paris...
Bon, tu devrais plutôt essayer de mettre une FSB >133MHz (t'as une KT7 A, autant l'utiliser!).
Commence par un p'tit 7*133=931MHz puis essaie 7.5*133=1GHz (Sait on jamais :??: ).
Voilà...
steff57
MLC a écrit a écrit :
Steff57, t'habites à Paris?
Si c'est le cas, j'fais toute sorte de modif dont le passage en Quadro.
Au passage, j'peux zieuter ton p'tit TB (914MHz... Hum, ça fait pas des masses tout ça!).
Voilà, @+!
Ben non pas à paris, désolé.... Dis moi à koi tu toucherais ds le bios.... car à chaque fois que je touche au FSB et que je le monte au dessu de 104, je dois effacer le CMOS???
steff57 Et dans les jeux type UNREAL, Quake 3 ou HALFLIFE ou les appli type Photos shop??
MLC Steff57, t'habites à Paris?
Voilà, @+!
CommissaireMoulin ça pète pas tout, niveau perf tu gagnes pas un seul petit point !! C juste pour les apps 3d comme 3dsmax ... Et il faut bouger deux résistances sur ta carte graph !!
Mais putain svp répondez moi pour le BIOS !!!!!!!!!!!!!!!!!!
steff57 Moi j'ai un TBird 900@914, 192 Mo, GTS 2 pro 32Mo, ABIT KT7a-raid
Je fais 2891, mais je suis sur de pouvoir faire mieux, mais je maitrise pas l'OC.... Si quelqu'un as des parma de bios a me donnés je prends....
Surtout comment on fait pour passer 1 GTS 2 pro en L'autre truc là qui à l'air de tout péter???
CommissaireMoulin Alors personne qui sait pour l'histoire du bios ??
hub_hs
Zorg a écrit a écrit :
au q3 rien en perf mais en qualité d'image en tout cas chez moi par contre à 3dmark j'ai gagné 800 pts, pas mal non :D
oum pas mal tu fais du combien a 3dmark
moi 2032 :D sans modif maioc a 135/180
steff57 Mais c koi une QUADRO....
Moi j'ai 1 GTS 2 pro.... ca marche aussi....et surtout ca change koa...
Il faut modifier physiquement la carte?
zorg au q3 rien en perf mais en qualité d'image en tout cas chez moi par contre à 3dmark j'ai gagné 800 pts, pas mal non :D
hub_hs etl on gagne environ combien en perf  dans les bench stile 3dmark ou Q3
CommissaireMoulin J'ai modifié ma carte en quadro 2 mxr y a déjà au moins 3 mois et j'ai jamais trouvé de bios mxr pour carte msi, normal msi ont pas fait de bios mxr puisqu'ils ont jamais fait de carte mxr ...
Alors j'avais déjà posé cette question, mais personne m'a répondu, je voudrai savoir si c possible de mettre un autre bios qu'un msi et si qqun l'a déjà fait ...
Merci d'avance !! ;)
zOU
1- le seul moyen d'être sur, c'est d'essayer,
2- pas forcément, j'ai gagner 800 point à 3dmark 2000 et j'ai vu une réelle différence dans les jeux.
3- pas besoin de reflasher, elle est tout de suite reconu.
4- oui, il faut modifier physiquement (déplacer des résistances) mais pas le bios ou chipset.
5- les fréquences reviennent à l'origine et faut re o/c.
voili voulou. :D
merci milles fois ... là c'est tout de suite plus clair que 457 pages de topic avec des [HS] partout !!!
merci encore.
ricobanane salut
et les gars il y à eu un topic
identique il y à 8 jours    :(
RIco
zorg 1- le seul moyen d'être sur, c'est d'essayer,
voili voulou. :D
zOU j'ai bien envie de faire la modif mais:
1- je suis pas trop sur de moi
2- j'ai bien compris que le gain n'est reel que dans les softs spécifiques (3DSmax,...)
3- je n'ai pas compris s'il fallait refalsher le BIOS avec un spécifique Quadro
4- je n'ai pas compris s'il fallait modifier PHYSIQUEMENT (soudure...) le bios et/ou chipset
5- je n'ai pas compris si les fréquences changeaient en auto après la modif ou si (voir point 3/4)
merci d'avance
mrnegre
XK a écrit a écrit :
non mais tu peux la transformer en Quadro MXR :D
attend, sérieux :??: c koa une Quadro MXR :??:
XK
MrNEGRE a écrit a écrit :
euh! z'avez pas un truc pour transformer ma GeForce2MX en GeForce3 tout court :(
mrnegre euh! z'avez pas un truc pour transformer ma GeForce2MX en GeForce3 tout court :(
MLC Et voilou!
gt2i ok, c'est trop gentil !
merci !!!
MLC :hello:
GT2i, si tu veux, j'peux t'envoyer les Bios Gloria3 (normal, SBA et Gloria3 "Pro" avec les fréquences "officielles" 250/410.
pour ce dernier, laisse tomber (résérvé aux possesseurs de GTS2 Ultra).
Sur mo ex Creative GTS2, le Bios Gloria3 SBA marchait impecc (au démarrage, y'a un beau Gloria 3 d'affiché ;))
gt2i ah cool que je tombe sur toi bjone, ou on trouve les BIOS geforce ?
J'ai une creative geforce 2 GTS mais pas de bios pour l'upgrader en quadro 2. Et bientot watercool + peletier dessus !
bjone laisse le bios d'origine...
le bios sgi, j'y crois pas trop,
j'ai modifié ma gf 1 ddr creative en quadro et ça tourne très bien avec le bios creative, le bios de 3dprophet ddr-dvi, et le bios de référence de nvidia (trouvable sur l'ancien site de zoiah).
neokortex j'ai transformé ma geforce 256 en nvidia quadro comme y disent sur le www.3dvf.com j'ai flashé le bios avec celui d'une quadro SGI qui a fait les meme modife ? y a t'il d'autrs bios celui ci m'as pas l'air super ,faut-il mettre les drivers sgi avec ca??
en direct 3d j'ai 3200 au lieux de 3000 mais sous 3dsmax ca a l'air de pulsé beaucoup plus..
je voudrai un autre bios lequel je peux mettre j'ai une leadtek winfast 256
un petit conseil pour le faire ne pas boire de café avant sinon vous allez etre en position du lapin qui broutte a chercher les resistances dans la moquette :D
