3556 connectés
  CPU
  OC Q9650 Stable ?
OC Q9650 Stable ?
n°2099423
xuan11
Posté le 12-03-2011 à 19:44:54  profilanswer
Bonsoir tout le monde
je voulais savoir si mon OC était sable et bien configuré !
Config :
Intel Core 2 Quad Processor Q9650
CM : XFX nForce 790i Ultra
RAM : 4*2Go OCZ Reaper PC12800
CG : MSI GTX285 OC
Seasonic M12- 700W
Dans mon bios, j'ai :
[System Clocks]
CPU Multiplier [9x]
PCI X16.1 & X16.2 Mhz [101]
PC X16.3 Mhz [101]
SPP <-> MCP Ref clock [auto]
Spread Pectrum Setting
CPU Spread Pectrum [Disabled]
HT Spread Pectrum [Disabled]
PCIe Spread Pectrum (SPP] [Disabled]
PCI Spread Pectrum (MCP) [Disabled]
Sata Spread Pectrum [Disabled]
[FSB & Memory config]
CPU Freq 3600.0
CPU Multi 9x
FSB Memory Clock mode [Unlinked]
FSB Memory ration [auto]
FSB (QDR) Mhz [1600]
Actual FSB(QDR) 1600
MEM (DDR) Mhz [1600]
Actual MEM (DDR) Mhz 1600
P1 [auto]
P2 [auto]
[CPU Configuration]
Limit CPUID Maxval [Disabled]
Intel speedstep [Disabled]
CPU thermal control [Disabled]
CE1 Enhanced haltstate [Disabled]
Execute Disabled bite [Enabled]
Virtualization technology [Enabled]
Cpu Core 0 [Enabled]
Cpu Core 1 [Enabled]
Cpu Core 2 [Enabled]
Cpu Core 3 [Enabled]
[System Voltages]
CPU Core [1.3500] current value 1.28
CPU FSB [1.30] current value 1.30
Memory [auto] current value 1.500
nForce SPP [auto] current value 1.40
nForce MCP [auto] current value 1.500
Sous CPUZ :
http://img219.imageshack.us/img219/1174/cpuzn.png
Sous OCCT :
temp cpu1
http://img862.imageshack.us/img862/853/2011031219h26cpu1.png
temp cpu2
http://img852.imageshack.us/img852/3056/2011031219h26cpu2.png
temp gpu1
http://img197.imageshack.us/img197/9824/2011031219h26gpu1.png
vcore
http://img62.imageshack.us/img62/6061/2011031219h26vcore.png
volt3
http://img819.imageshack.us/img819/1970/2011031219h26volt3.png
volt5
http://img836.imageshack.us/img836/4241/2011031219h26volt5.png
Merci pour vos réponses !
Message édité par xuan11 le 12-03-2011 à 19:52:53
n°2099522
arkrom
note, ca passait c'etait beau
Posté le 13-03-2011 à 13:30:00  profilanswer
OCCT est passé sans erreur , j'ai pas noté de faute manifeste de reglages, tes tensions et  T° sont convenable :jap:
je dit pas que c'est optmimisé mais pour moi c'est correct
il manque pi etre les infos sur la ram pour verifier 2 3 details
Message édité par arkrom le 13-03-2011 à 13:30:12
n°2099529
xuan11
Posté le 13-03-2011 à 13:51:23  profilanswer
Merci de ta réponse, en ce qui concerne la ram je n'ai rien changé (je crois)
http://img822.imageshack.us/img822/3397/rame.png
n°2099531
arkrom
Posté le 13-03-2011 à 13:56:35  profilanswer
ca me semble bien :jap: timing pas degeu vu la frequence
le seul truc un poil strange c'es ta T° GPU qui BAISSE , mais je pari que le ventillo a changé de vitesse au bout de 5 minutes :ange:
n°2099543
xuan11
Posté le 13-03-2011 à 14:15:03  profilanswer
peut-être... passage à 4Ghz avec
FSB (QDR) Mhz [1800]
Actual FSB(QDR) 1800
MEM (DDR) Mhz [1800]
Actual MEM (DDR) Mhz 1800
? ou je vais devoir changer encore les vcore... et autres...
n°2099550
arkrom
Posté le 13-03-2011 à 14:23:11  profilanswer
pour monter a 4000 il te faut un FSB @ ~444, je pense pas que ta RAM vas suivre si facilement, change ton ratio, passe a qlq chose plus pres  de 3/2,
( vieux reflexe de DDR2 :o j'ai pensé a passer en 1:1 direct :lol: c'est sur ta RAM te posera plus de problème de frequence comme ca , mais elle sera totalement sous exploité )
n°2099553
xuan11
Posté le 13-03-2011 à 14:25:09  profilanswer
;) ok merci pour tes réponses ! je vais laisser mon 3.6 comme ça un moment, pour voir si tout roule, c'est pas si mal !
n°2099558
arkrom
Posté le 13-03-2011 à 14:29:31  profilanswer
tes OCZ sont donné pour tenir @1600 mais au dela ca risque de devenir plus raide a faire ; donc si un leger changement de ratio de sauve la vie fonce :jap:
mais bon un ration "entier" c'est toujours mieux
  CPU
  OC Q9650 Stable ?
Probleme d'OC sur Asus P8P67 Pro Help plz :)OC i760 avec carte mere asu p7p55d
OC Q9550 E0OC qui se réinitialise à Stock après la veille
Problèmes OC I5 2500K sur p6P67 proavis resultat 3d mark 2006 changement faible aprés OC
Erreur à la 20eme passe de LinX, c'est stable ? xDPins socket LGA redressés Oc E6850 possible?
Conseil achat ventirad == silence et léger OC == +/- 50€Q6600 rev.B3 + P5K deluxe afinage de L'OC (besoin de guru)
Plus de sujets relatifs à : OC Q9650 Stable ?
