5505 connectés
  [How to] Lire un Stepping de processeur amd
n°899733
Magicpanda
Pushing the envelope
Posté le 22-10-2003 à 07:40:03  profilanswer
Color of CPU core blue - copper interconnects
green - aluminium interconnects
CPU name Duron
Athlon
CPU family AMD - Athlon XP mobile
AMP - Athlon MP
AX - Athlon XP
AXD - Athlon XP model 10
AXM - Athlon XP mobile
A - Athlon
D - Duron
Power consumption A - Desktop CPU
L - Low Power CPU
HD - High Performance Desktop
HM - High Performance Mobile
HL - High Performance Low Power [Cool'N'Quiet OEM series]
MS - ?? (AXMS)
MD - ?? (AXMD)
MSN - Mechanical sample
0700 - core frequency value in MHz BUT:
Athlon XP/MP use QuantiSpeed rating scheme:
3200 - 2.20GHz (FSB400)
3000 - 2.10GHz (FSB400)
3000 - 2.17GHz (FSB333)
2800 - 2.08GHz (FSB333)
2700 - 2.17GHz (FSB333)
2600 - 2.13GHz (FSB266)
2500 - 1.83GHz (FSB333)
2400 - 2.00GHz
2200 - 1.80GHz
2100 - 1.73GHz
2000 - 1.67GHz
1900 - 1.60GHz
1800 - 1.53GHz
1700 - 1.47GHz
1600 - 1.40GHz
1500 - 1.33GHz
Athlon 4 uses QuantiSpeed rating scheme:
1900 - 1.6GHz
1800 - 1.5GHz
1600 - 1.4GHz
1500 - 1.3GHz
Mobile Athlon XP uses QuantiSpeed rating scheme:
2200 - 1.66GHz (FSB333)
2000 - 1.66GHz
1900 - 1.60GHz
A - package type A - PGA / CPGA
D - OPGA
M - Card module
F - ??
S - core voltage Q - 1.45V
L - 1.50V
(S - 1.5V)
W - ??
K - 1.65V
U - 1.6V
P - 1.7V
M - 1.75V
N - 1.8V
T - die temperature Q=60° C
X=65° C
R=70° C
Y=75° C
K=80° C
W=80° C
V=85° C
Z=85° C
T=90° C
S=95°C
1 - L2 cache size 1 - 64 KByte
2 - 128 KByte
3 - 256 KByte
4 - 512 KByte
5 - 1024KByte
6 - 2048KByte
7 - 4096KByte
8 - 8192KByte
B - max FSB A - 200MHz
B - 200MHz
C - 266MHz
D - 333MHz
W - ?
X - ? P - currently unknown but doesn't vary
Y - ?
Z - ? W - currently unknown but doesn't vary
AKAA - stepping Duron - Spitfire core
AKAA <700MHz
AKBA <700MHz
AKCA ANCA AMCA ANDA >=800MHz
Duron - Morgan core
AHHAA AHLCA >1000MHz
Athlon - Thunderbird core
ADEA ADFA AEEA AFEA AHEA AJFA <900MHz
AGGA AQGA ARGA ASHA
AVFA BVFA AVIA AVHA BVHA
AXIA BXIA AXHA BXHA
Athlon - Palomino core
AYHJA EYHJA
AYHJAR AXIAR [9]
AXIAR [Y]
Athlon XP - Palomino core
AGKDA >1200 (low power)
AGKGA AGNGA AGOGA AGOIA >2000
AROIA >1600 (green PCB)
Athlon 4
AGDCA
Athlon MP
AGBC
AGFC
Athlon XP - Thoroughbred core
AIQAA >1700 [6-8-0]
AIPCA AIRCA AIRDA >2100 [6-8-0]
AIRGA >2100 [6-8-0]
AIUAB AIUCB AIUGB >2400 [6-8-1]
Athlon XP - Barton core
AIUAA [6-10-0]
AQUCA AQXDA [6-10-0]
JIUCB [6-10-0]
0022 00 year of manufacture
22 week of manufacture
ES Engineering sample (not on final versions)
" Quel est le but du capital ? Le but du capital c'est produire pour le capital. L'objectif, lui, est illimité. L'objectif du capital c'est produire pour produire." - Deleuze || André Gorz - Vers la société libérée
n°899751
Noooky
Posté le 22-10-2003 à 09:27:21  profilanswer
la diff de couleur entre les interconnections cuivre et alu ca change kkchose ?
n°899845
Posté le 22-10-2003 à 13:57:53  answer
Le cuivre est meilleur, à priori, pour les hautes fréquences et les hauts voltages.
n°899925
VW Seb
Who's the Boss !!
Posté le 22-10-2003 à 16:46:23  profilanswer
c normal que je n ai pas tout compris ou c moi ???
n°899945
nikopop
凸(`0´)凸
Posté le 22-10-2003 à 17:03:26  profilanswer
ça m'étonne vraiment ça :
AYHJA EYHJA
AYHJAR AXIAR [9]
AXIAR [Y]
Votre Installation Home-Cinema ici : installations-home-cinema.eu
n°899949
missilius
Posté le 22-10-2003 à 17:05:35  profilanswer
Complément :
H=1.55v
Q=1.45v
V=1.4v
J=1.35v
X=1.25v
T=1.2v
W=1.3v
Q=100°
 [:fifou63]
et
Athlon mobile 0.13 :
AXMS/AXMD/AXDH
0.18
AHM
DURON:
D/DHD/DHM/DHL
Message édité par missilius le 22-10-2003 à 17:12:47
n°899953
Posté le 22-10-2003 à 17:11:10  answer
Et un core rose çà correspond à quoi :??:
n°899954
Magicpanda
Posté le 22-10-2003 à 17:11:18  profilanswer
AYHJA EYHJA
AYHJAR AXIAR [9]
AXIAR [Y]
en effet c'est tbird core j'ai mem pas remarqué :D
edit ! il doit s'agir des premiers  palomino 1.2 qui etait des thunderbird mp
Message édité par Magicpanda le 22-10-2003 à 17:12:20
n°899955
Posté le 22-10-2003 à 17:12:25  answer
J'ai un Thoroughbred KIUHB aussi :D
n°899956
nikopop
凸(`0´)凸
Posté le 22-10-2003 à 17:13:01  profilanswer
:heink: ça donne koi en o/c?
n°899957
Posté le 22-10-2003 à 17:14:53  answer
Profil :wahoo: !
CM et refroidissement pas powa mais bien pour ce que j'en fait :jap:
Message édité par Profil supprimé le 22-10-2003 à 17:15:44
Help mon processeur se prend pour un 3200+2600+ et stepping ??
Quel processeur INTEL le plus overclockable ?A lire absolument avant fermeture
[AVIS] Reference de ce processeur bonne ou pas pour overclocker ??[BDD] All Best Stepping AMD "$Open Bar$"
[AMD] Quel est le meilleur processeur pour l'overclocking ?[Bon Stepping?!?]
stepping dun xp 2000+
Plus de sujets relatifs à : [How to] Lire un Stepping de processeur amd
