9429 connectés
  kelkes scores a sisoft sandra 2001
n°497014
JOEBAR_91
Dieu le Mecano :)
Posté le 28-05-2002 à 19:48:30  profilanswer
Comments:                             1000 mhz 1.85v 10X100mhz
<<< CPU Arithmetic Benchmark >>>
  < Benchmark Results >
    Dhrystone ALU:                        2754MIPS
    Whetstone FPU:                        1372MFLOPS
  < Test Status >
    SMP Test:                             No
    Total Test Threads:                   1
    SMT Test:                             No
    Dynamic MP/MT Load Balance:           No
    Processor Affinity:                   No
  < Processor(s) >
    Model:                                AMD Duron(tm) Processor
    Speed:                                1.01GHz
    Model Number:                         1006 (estimated)
    Performance Rating:                   PR1338 (estimated)
    L2 On-board Cache:                    64kB ECC synchronous write-back
    Front Side Bus Speed:                 2x 101MHz (202MHz data rate)
 <<< CPU Multi-Media Benchmark >>>
    Integer aEMMX/aSSE:                   5482it/s
    Floating-Point aE3DNow!:              6074it/s
  < Test Status >
    SMP Test:                             No
    SMT Test:                             No
  < Processor(s) >
    Speed:                                1.01GHz
    Model Number:                         1007 (estimated)
    Performance Rating:                   PR1339 (estimated)
  < Technology Support >
    MMX Technology:                       Yes
    SSE Technology:                       No
    SSE2 Technology:                      No
    Hyper-Threading Technology:           No
    Extended AMD MMX Technology:          Yes
    3DNow! Technology:                    Yes
    Extended 3DNow! Technology:           Yes
<<< Memory Bandwidth Benchmark >>>
    RAM Bandwidth Int Buffered aEMMX/aSSE:765MB/s
    RAM Bandwidth Float Buffered aEMMX/aS:763MB/s
  < Int Buffered aEMMX/aSSE (Integer STREAM) Results Breakdown >
    Assignment:                           769MB/s
    Scaling:                              768MB/s
    Addition:                             762MB/s
    Triad:                                763MB/s
    Data Item Size:                       4-bytes / 32-bits
    Buffering Used:                       Yes
    Bandwidth Efficiency:                 95% (estimated)
  < Float Buffered aEMMX/aSSE (Float STREAM) Results Breakdown >
    Assignment:                           768MB/s
    Scaling:                              768MB/s
    Addition:                             757MB/s
    Triad:                                760MB/s
    Data Item Size:                       8-bytes / 64-bits
    Buffering Used:                       Yes
    Bandwidth Efficiency:                 94% (estimated)
  < Test Statistics >
    Array Memory Used:                    64MB
    SMP Test:                             No
    SMT Test:                             No
  < System Chipset >
    Model:                                VIA Technologies Inc VT8363/5 KT133/KM133 System
                                          Controller
    Max. Bus Bandwidth:                   1616MB/s (estimated)
  < Logical/Chipset Memory Banks >
    Bank 0 Setting:                       64MB SDRAM 2-2-2CL
    Bank 4 Setting:                       64MB SDRAM 2-2-2CL
    Bank Interleave:                      4-way
    Memory Bus Speed:                     1x 101MHz (101MHz data rate)
    Max. Memory Bandwidth:                808MB/s (estimated)
  < Instruction Set Support >
    MMX Technology:                       Yes
    SSE Technology:                       No
    SSE2 Technology:                      No
n°497016
JOEBAR_91
Dieu le Mecano :)
Posté le 28-05-2002 à 19:49:44  profilanswer
mes tx de transfert de sdramm il sont bon ?
c de la pc 100
ils osnt correct ces pers pour un 1000 ?
mon system report sisoft sandra 2001133-333 vs 100-222, sandra vs cpumark
Mes scores à 3DMARK 2001 SE avec un athlon + kt3333D mark 2001: comment ca marche
gforce 4 leadtek overclocke baisse dans 3dwinmark 2001 ?mes scores à pc mark 2002
Sandra 2002 ALU / FPU -- Athlon XP (vs) Northwood
Plus de sujets relatifs à : kelkes scores a sisoft sandra 2001
