10529 connectés
 Page :   1  2  3  4  5  6  7  ..  20  21  22  23  24  25
The topic du 1700+ JIUHB :) DLT ROX :D
n°771855
niiizzzz
Posté le 09-04-2003 à 17:29:28  profilanswer
a propos du downgraded :
" Examples :
9367337260464
9397647280017
The digits "26" and "28" actually carry certain meaning.
You might be able to guess it already. In our opinion after reading more than 50 personal reviews of Thoroughbred is:-
"26" means it is a downgraded version from 2600+ Thoroughbred.
"28" means it is a downgraded version of 2800+ Thoroughbred.
Believe it or not, those CPU with "26", "27" or even "28" tested to be stable at that particular speed with default voltage 1.65v, or even 1.525v which is fantastic !! That's why they run much cooler at extreme voltages, and can be overclocked to high speeds up to 3000+ (2.4GHz).
In General, assuming that:
24 = 2400+ 2.0GHz 266FSB
25 = 2500+ (should be a 2.5GHz Thoroughbred with 266FSB but it does not exist!!)
26 = 2600+ 2.083GHz 333FSB or 2.13GHz 266FSB
27 = 2700+ 2.17GHz 333FSB
28 = 2800+ 2.25GHz 333FSB
30 = 3000+ but not exist!!!
n°771858
digitorum
Posté le 09-04-2003 à 17:35:56  profilanswer
du neuf en proco ?
n°771859
Jonvidia
x0:y0:z0
Posté le 09-04-2003 à 17:36:48  profilanswer
dlt3c jiuhb rpmw 0308
ca tappe cbn ca ?
n°771860
digitorum
Posté le 09-04-2003 à 17:36:58  profilanswer
matilo a écrit :
N'est ce pas  :love:  :whistle:
c clair
tu pends cbn avec le dlt finalement en WC ?
n°771862
Posté le 09-04-2003 à 17:38:48  answer
" Examples :
9367337260464
9397647280017
Et sui la:
AXDA1700DLT3C
JIUHB0308SPMW
9571376251078
 ?????? :heink:
n°771864
Jonvidia
x0:y0:z0
Posté le 09-04-2003 à 17:40:15  profilanswer
m'enerve cette histoire de downgrade  :kaola:
n°771866
matilo
Posté le 09-04-2003 à 17:43:37  profilanswer
digitorum a écrit :
c clair
juste 2300 @1.81v, pas encore essayé vaec voltage plus élevé
n°771875
guynemer
Trust rather than monogamy
Posté le 09-04-2003 à 17:49:00  profilanswer
Avec un 0309 9 dlt3c , je frise le 2.5 Ghz en air cooling à 1.8V.
C potable ou pas pr cette série ?
j'avoue que je m'y perds carrémetn dans tous les chiffres qu'on voit
Message édité par guynemer le 09-04-2003 à 17:49:22
n°771878
Posté le 09-04-2003 à 17:50:21  answer
C est le meilleur step :jap:
Tu l as acheté ou?
n°771891
Gandalf_Le​_Gris
Posté le 09-04-2003 à 17:59:08  profilanswer
Tu l as acheté ou?
dut3c spa mieux ? ca encaisse mieux les voltages de bourrins :D
n°771895
Posté le 09-04-2003 à 18:01:41  answer
Vi , et ta factue d electricité, tu y as pensé??? :lol:
n°771896
guynemer
Posté le 09-04-2003 à 18:04:14  profilanswer
Ah ben non alors , j'étais persuadé que DLT c'était mieux.Ce qui parait logique.Le L c'est pr 1.5V ,alors que le U c'est pr 1.65V donc logiquement le L laisse plus de marge pr OC avec un Vcore grandissant.
Me trompe-je ?
n°771905
Ludal the ​lethal
Don't even think about it !
Posté le 09-04-2003 à 18:07:40  profilanswer
Me trompe-je ?
Oui, tu te trompes, ton proco est pourri, il faut absolument que tu cherches un DUT, donc tu me vends celui-là  :ange:
n°771907
Gandalf_Le​_Gris
Posté le 09-04-2003 à 18:08:33  profilanswer
Me trompe-je ?
non, mais un dlt ca boot pas o dessus de 2v un dut oui, a confirmer  :ange:
n°771911
guynemer
Posté le 09-04-2003 à 18:10:20  profilanswer
J'espère que t'as tort , j'avais prévu de leur foutre du 2.15V mini quand j'aurais eu ma nf7s
n°771912
misteroads​ter
Posté le 09-04-2003 à 18:11:00  profilanswer
c kler k un 0302 4 encaisse mieux les volts :
la je teste un 1800+dlt 0309 y crache 2330 rock a 1,725 et plus ,mais ca chauffe tellement ki fo pas esperer plus de 1,85V en aircool.
n°771913
Posté le 09-04-2003 à 18:11:08  answer
oui, les DLT montent un peu plus haut, mais pas beaucoup,le seul avantage, c est le faible voltage qui economise le matos(alim,carte mere)...
Message édité par Profil supprimé le 09-04-2003 à 18:13:28
n°771915
misteroads​ter
Posté le 09-04-2003 à 18:11:38  profilanswer
+1 enfin si ca boote mais c est instable a haut vcore
Message édité par misteroadster le 09-04-2003 à 18:12:08
n°771917
mokembo
Que c'est bon la retraite
Posté le 09-04-2003 à 18:13:02  profilanswer
certains oui mais il y en a qui prennent 2.2V ss problemes
n°771918
Gandalf_Le​_Gris
Posté le 09-04-2003 à 18:13:04  profilanswer
monte plus haut a meme voltage mais a partir d un moment ca booteras plus avec un gros voltage et le dut grapillent ses derniers mhz sur la fin
donc 1.85v c dlt le mieux
et 2.15v c dut :D
n°771921
misteroads​ter
Posté le 09-04-2003 à 18:13:21  profilanswer
le voltage change rien c est l intensité X voltage qui compte
et ces procos requierent plus d Intensite qu un dut
n°771922
Gandalf_Le​_Gris
Posté le 09-04-2003 à 18:13:25  profilanswer
pas vu  :??:
n°771923
misteroads​ter
Posté le 09-04-2003 à 18:14:35  profilanswer
et 2.15v c dut :D
we on peut dire ca comme ca mais ca depends des DUT et DLT
y a les bons et les movais  :D
n°771926
xigfrid
Tjs vivant
Posté le 09-04-2003 à 18:14:56  profilanswer
+1 : bcp plus de courant qu'un DUT ! :cry:
n°771927
VW Seb
Who's the Boss !!
Posté le 09-04-2003 à 18:15:36  profilanswer
bon aucun rapport ms jme posait une kestion...
Les 1700+ non JIU.. s'overclok komen  :??:
n°771929
xigfrid
Tjs vivant
Posté le 09-04-2003 à 18:17:07  profilanswer
Je cherche quelqu'un qui aurait en stock :
  • plusieurs DUT et DLT
  • voltmetre faisant ohmetre
pour petite confirmation d'une idee qui m'est venue comme ca : on peut me pm  :)
n°771930
VW Seb
Who's the Boss !!
Posté le 09-04-2003 à 18:17:50  profilanswer
kesako ton idée ?
n°771931
guynemer
Posté le 09-04-2003 à 18:18:03  profilanswer
Bon ben je vais me prendre qqs dut3c  pr voir
n°771936
xigfrid
Tjs vivant
Posté le 09-04-2003 à 18:21:47  profilanswer
VW Seb a écrit :
kesako ton idée ?
Vu les parametres technologiques de la chaine de fabrication des microprocesseurs AMD, y a aucune raison que tel chips ou tel chips consomme bcp plus ... les differences observées en nanotechnologie se mesurent en millieme de nanometre , aps assez pour doubler la conso du proc , d'ou mon idee :
en fait c'eest le package qui fait la difference : les resistances autour du core doivent etre differentes selon que ca soit DLT ou DUT : d'ou l'idee : si on prend un DUT qui boost on lui fait le "pencil trick" pour le mettre en "haute consommation de courant" ca nous donne un super DLT  [:criun]
n°771937
Posté le 09-04-2003 à 18:22:50  answer
Ben rachete des DUT  :D
n°771939
misteroads​ter
Posté le 09-04-2003 à 18:23:15  profilanswer
mais bon je suis impressionné par les 1800+ 0309 dlt3c TPMW
je viens d en tester 4 tous 2380-2400 stable a 1,85V
mieux que 0302 4 apparemment  :??:
n°771942
xigfrid
Tjs vivant
Posté le 09-04-2003 à 18:24:11  profilanswer
et moins bien que les 1700 0309 DLT :cry:
n°771943
misteroads​ter
Posté le 09-04-2003 à 18:24:18  profilanswer
mais 3° de plus (a 1,85V) par rapport a mon 0302 4 dut3c a 1,93V
n°771944
Posté le 09-04-2003 à 18:24:29  answer
achetés aujourd hui? :D
n°771948
nikopop
凸(`0´)凸
Posté le 09-04-2003 à 18:25:31  profilanswer
moi je lache l'affaire avec les procos amd, c'est trop déprimant je trouve :(
Votre Installation Home-Cinema ici : installations-home-cinema.eu
n°771951
Gandalf_Le​_Gris
Posté le 09-04-2003 à 18:26:20  profilanswer
je fais pareil avec mon 0302 '4'
1.85v bios, 1.81 reel, 2400 stable, meme 2420 et des poussieres
n°771954
Posté le 09-04-2003 à 18:27:32  answer
pourquoi déprimant? :lol:
n°771956
misteroads​ter
Posté le 09-04-2003 à 18:29:21  profilanswer
ouais mais moi j en ai eu une bonne vingtaine de 0302 4 donc je peux avoir un avis pertinant.
n°771957
mokembo
Posté le 09-04-2003 à 18:29:24  profilanswer
tu vas en avoir a vendre?
n°771959
guynemer
Posté le 09-04-2003 à 18:29:29  profilanswer
Ben avec mon 0309 dlt3c je suis stable à 2482 Mhz (17*146) à 1.8V.
Comment vous différenciez voltage bios et voltage réel ?
n°771961
Gandalf_Le​_Gris
Posté le 09-04-2003 à 18:30:46  profilanswer
quel ventilo pour un Athlon XP 1700+ JIUHB pour 30?.XP 1800+ JIUHB
[AVIS]ou acheter un xp1700+ ou 1800+ jiuhb?Info sur des 1700+ JIUHB
Topic - Xp 1700+ 0.13 - - Série JIUHB 0251 F - -DLT kesako ?
Plus de sujets relatifs à : The topic du 1700+ JIUHB :) DLT ROX :D
