5739 connectés
  Epox 4G4A+ => Aux chiottes !
 Page :   1  2  3
Page Précédente
n°518251
Doc TB
CPC Hardware
Posté le 15-06-2002 à 03:00:35  profilanswer
Salut, je voudrais savoir si il y a encore quelqu'un pour me donner un petit coup de main a cette heure si sur un probleme qui me pourrit la vie la, marchi.
Comme c'est long a expliquer, j'attends de voir si quelqu'un est suceptible de me filer un coup de main.
Message édité par Doc TB le 15-06-2002 à 12:00:01
Doc_TB @ Canardpc.com
n°518252
*PIKACHU*
Midnight Hot! Midnight Hot!...
Posté le 15-06-2002 à 03:01:30  profilanswer
allez vas y
...In A Few Moment On Fashion TV!
n°518254
Doc TB
CPC Hardware
Posté le 15-06-2002 à 03:04:02  profilanswer
je vous met le mail que je vais envoyé au constructeur.
My name is Samuel DEMEULEMEESTER, I'm the webmaster of
http://www.x86-secret.com and I need your help quickly
about lots of memory issues on an ---------. We had
this motherboard for a review since two weeks. This
motherboard was NOT sent by ------ and come from a PUBLIC
retailer store. We can't complete our tests because we
had LOTS of stability issues regarding the memory. Here
is an explanation of the problems.
1) When we use only ONE stick of memory in the FIRST bank
(first slot), all works fine and the performance are very
good with NO stability issue
2) When we use TWO sticks of memory, we ran into big (very
big) troubles. The systeme is COMPLETLY unstable, even
without any overclocking, DDR200 settings in the BIOS and
less agressive timing (2.5-7-3-3) !
Of course, we had tryed with lots of differents memory
modules and combinaisons (Kingmax DDR333 / Kingmax DDR400 /
Samsung DDR333 / Micron DDR266 / Micron DDR333) and with
lots of software configuration (windows 98/2000/XP). We also
had tryed to change the PSU (Enermax 365W), the video card
(GF4 Ti4600) and all the others PCIs cards (3Com 905C-TX,
Sb Live! 5.1 / Adaptec 29160), but the issues remains.
About the BIOS, we had tryed with the bios dated (11/04/2002)
which can be found in your website, with the version dated
21/04/2002 (originally shipped with) and with the latest
performance BIOS dated from 10/05/2002.
We have no more ideas about how to solve these issues.
We have reviewed a --------- with the same chipset without
those kind of problems.
Je prefere pas mettre le modele de la carte mere pour le moment.
n°518255
Doc TB
CPC Hardware
Posté le 15-06-2002 à 03:05:44  profilanswer
Je vais devenir fou avec cette carte sans deconner... :gun:
Si ca continue, je fous un monstrueux coup de masse dessus et je publie le tout apres...
Message édité par Doc TB le 15-06-2002 à 03:06:29
n°518256
*PIKACHU*
Posté le 15-06-2002 à 03:07:41  profilanswer
si g bien compris
tu as mis une barrette sur le premier slot
et tout fonctionne nickel
tu en mets une 2em
et la ca commence a deveni instable
tu as essaye tt pleins de barrettes haut de gamme et c tjrs pareil
n°518257
*PIKACHU*
Posté le 15-06-2002 à 03:07:58  profilanswer
tu as essaye avec une barrette sur le slot 2?
n°518258
Doc TB
CPC Hardware
Posté le 15-06-2002 à 03:09:06  profilanswer
ouai, ca marche
n°518261
*PIKACHU*
Posté le 15-06-2002 à 03:10:14  profilanswer
et quand tu mets 2 barrettes
meme sans overclokcing ca marche pas?
n°518262
Doc TB
CPC Hardware
Posté le 15-06-2002 à 03:11:28  profilanswer
non, DDR200 en 2.5-7-3-3 ca plante au bout d'un moment. DDR266 en 2.5-7-3-3, ca plante au bout de quelques minutes. Changement de timing ou DDR333, ca plante direct au boot
n°518263
Doc TB
CPC Hardware
Posté le 15-06-2002 à 03:12:26  profilanswer
et c'est FSB 100 ca encore, parceque FSB 133, j'en parle meme pas
n°518264
*PIKACHU*
Posté le 15-06-2002 à 03:13:45  profilanswer
c quoi cette daube de carte mere
pourtant l'incompatibilite n'existe plus ...
c de la marque pas de la no name
tu as essaye pleins de barrette
pas d'O/C
la cm est casse?
c une cm beta ?
n°518268
Doc TB
CPC Hardware
Posté le 15-06-2002 à 03:18:59  profilanswer
A qui le dit tu ! si tu savais le constructeur....
pas d'O/C
Kingmax DDR333
Kingmax DDR400
Samsung DDR333
Micron DDR266
Micron DDR333
12 barrettes en tout
Ouai,
la cm est casse?
c une cm beta ?
C'est la deuxieme qd meme :(
Elle vient d'une boutique, pas du tout beta.
n°518269
*PIKACHU*
Posté le 15-06-2002 à 03:20:18  profilanswer
elle supporte pas ce genre de ram peut etre...
l'histoire d barrettes double faces peut etre?
elle accepte combien au maxi?
n°518270
Doc TB
CPC Hardware
Posté le 15-06-2002 à 03:20:19  profilanswer
Bien sur tout les sites US qui l'ont testé ont testé avec UNE barrete... Sauf un (un site DE)... qui a eu aussi plein de problemes.... :mad:
n°518271
*PIKACHU*
Posté le 15-06-2002 à 03:20:29  profilanswer
a tt les coups c pour du p4
n°518272
Doc TB
CPC Hardware
Posté le 15-06-2002 à 03:20:47  profilanswer
2 Go, testé avec simple et double face, c pareil...
n°518273
*PIKACHU*
Posté le 15-06-2002 à 03:20:53  profilanswer
c un probleme general et les autres voulaient pas se mouiller bref...
n°518275
Doc TB
CPC Hardware
Posté le 15-06-2002 à 03:21:55  profilanswer
Vu la reputation du constructeur, c la honte...
n°518276
*PIKACHU*
Posté le 15-06-2002 à 03:24:55  profilanswer
asus ou abit
n°518277
Doc TB
CPC Hardware
Posté le 15-06-2002 à 03:25:18  profilanswer
tu peux loader ton icq ?
n°518280
*PIKACHU*
Posté le 15-06-2002 à 03:28:55  profilanswer
mais 5min parce que je dois dodo
n°518298
igor
Posté le 15-06-2002 à 07:34:54  profilanswer
The Mad, cela serait sympa de donner le modéle de cette CM, surtout si elle est deja dispo à la vente en France afin que personne ne l'achete tant que ce pb n'est pas réglé.
Message édité par igor le 15-06-2002 à 08:59:12
n°518511
Doc TB
CPC Hardware
Posté le 15-06-2002 à 11:52:12  profilanswer
Exact, au final, j'en ai rien a foutre de ce qu'ils peuvent bien penser. la carte en question est donc une :
=>  EPOX 4G4A+  <=
Apres quelques infos, je lache le nom parceque je suis maintenant persuadé que ce n'est pas un probleme qui est propre a ma carte, mais qui est général. Cette carte est mal concue. Completement bugguée.
Shame sur les sites genre tweaktown qui ont pas captés ca !!!
Au final voici un test allemands d'HardwareLuxx qui a eu le meme probleme :
http://www.hardwareluxx.de/cgi-bin [...] 000016&p=9
Un topic sur [H]ard|OCP :
http://www.hardforums.com/showthre [...] did=409649
Quelques phrases choisies :
- t all day...could be an immature chipset, some timing issue with the better mem controller
- I have one of these two and I can confirm it doesn't overclock for anything. I can't even run my 1.8A at 2.4. And just so you know, I got a golden 1.8A Malay 3/27/02 will do 2.9 on my friends 4BDA2+ I am at this moment pretty pissed
- Really? Your's too, eh? Thanks for getting back with your input on that...I spent a LOT of time with this 4G4A+, and it drove me nutz. I went on a two-day bender just to get it outta my head
- ARGH!!! Well, after 2 days of tinkering around with the 4G4A+, I am about to pull my hair out! Yes, when I first installed it, it was great! Now that I am doing more things with it (or lack thereof), it is really starting to annoy me...
- Right now it's running at 2.4/1.6v/DDR375, which allows me to run 3DM2K1 infinitely (or so it seems), but that limitation appears to be a RAM issue
- Tomorrow I will go and exchange the board.
Bref, Epox => Aux chiottes !! :gun: :mad:
n°518533
Doc TB
CPC Hardware
Posté le 15-06-2002 à 12:04:03  profilanswer
J'ai vu dans un autre topics des gens avec cette mobos. Quelqu'un pourrait temoigner avec DEUX modules de DDR ?
n°518542
The NBoc
Quo Modo Deum
Posté le 15-06-2002 à 12:07:20  profilanswer
et sinon en o/c par rapport a la dfi c'est comment??
n°518548
Doc TB
CPC Hardware
Posté le 15-06-2002 à 12:10:17  profilanswer
Lol, deja que c'est pas stable a 100 Mhz, je te parle meme pas de l'oc. Avec une seule barrete, ca tiens pas a 2.4 Ghz sur mon 1.6A de test alors que ca rulez sur la DFI, comme sur quasiement toute les autres cartes d'ailleurs. Avec deux barrettes.... ben j'en parle meme pas...
n°518550
The NBoc
Quo Modo Deum
Posté le 15-06-2002 à 12:10:57  profilanswer
ok :/
n°518590
Beegee
Posté le 15-06-2002 à 12:31:38  profilanswer
cf ma config : 1.6A@2.4 sur cette epox, 1.7V,ventirad intel, 55°C max (en compression divX ou seti)
RAM : 2x256 Mo DDR2700 Samsung rev D double face
réglages : VDDR = 2.7V si je me souviens bien, et RAM à 187 MHz cas 2.5 (c la ram qui limite), ratio 4:5.
Aucun problème de stabilité !!!!
par contre j'ai eu 2-3 fois un pb de boot a froid, enfin en fait je c pas trop si c la CM qui merdait ou l'écran qui s'allumait pas ... à mon avis si c un pb de CM ce sera résolu avec un bios :)
Mon bios est celui du 24 avril je crois ;)
n°518591
Beegee
Posté le 15-06-2002 à 12:32:45  profilanswer
au passage : mon 1.6A tien aussi à 2.56 GHz (160 de FSB) sans planter, mais il chauffe plus (car voltage dans les 1.8V) : 60°C max avec le ventirad intel ...
donc je préfère le laisser @2.4 ;)
n°518599
mugen
Posté le 15-06-2002 à 12:37:01  profilanswer
:sarcastic:  dire que je voulais acheter cette cm
n°518606
*PIKACHU*
Posté le 15-06-2002 à 12:38:50  profilanswer
du bon caca epox
n'est ce pas jon
n°518609
Oxygen3
Tears from the moon
Posté le 15-06-2002 à 12:39:14  profilanswer
vi ca commence à craindre severe là :/
Metro-Pole ▬ Réseau A Suivre...: Annuseries|LeVillage|pErDUSA
n°518612
*PIKACHU*
Posté le 15-06-2002 à 12:40:29  profilanswer
fallait me croire quand je disais que ct caca au lieu de me traiter d'heretic
Message édité par *PIKACHU* le 15-06-2002 à 12:40:48
n°518614
Oxygen3
Tears from the moon
Posté le 15-06-2002 à 12:41:02  profilanswer
b'en ma 8k3a+ a pas de pb mais apparement certains en ont :/
n°518615
The NBoc
Quo Modo Deum
Posté le 15-06-2002 à 12:41:09  profilanswer
du bon caca epox
n'est ce pas jon
gt tres content de ma 8kta-2
n°518663
Beegee
Posté le 15-06-2002 à 12:54:10  profilanswer
ca marche chez moi (cf au dessus)
donc on ne peut pas dire que c la conception de la CM qui est mauvaise, sinon ca merderait chez tout le monde !
au passage, j'ai eu une feuille volante dans la boite de la CM, disant que si on met 2 barrettes double face, faut les mettre dans des emplacements précis : DIMM1 et DIMM2.
citation :
"Supplemental
Dute to packaging issues we were unable to update the user's manual durin printing. Therefore we have included this insert notifying you.
Warning:
Once 2 pcs of double-side memory modules are used, please install them in DIMM1 and DIMM2 to prevent any unstability issue happened!"
n°518668
marte
Posté le 15-06-2002 à 12:55:45  profilanswer
Dis nou ou tu la jetes....
Garc. Jo
n°518674
The NBoc
Quo Modo Deum
Posté le 15-06-2002 à 12:56:37  profilanswer
mais tout le monde utilise les slot les plus proches du cpu, a savoir dimm1 et 2!!!!
n°518841
Doc TB
CPC Hardware
Posté le 15-06-2002 à 14:37:47  profilanswer
de toute facon, foutre 3 slots de ram sur une carte avec un chipset qui gére que 4 banques, c pas vraiment top...
Rhhaaaaaaa, chuis repassé a la DFI NB76 (sur mon propre systeme !!) et no soucis @ 2.53 Ghz - 2x256 Mo DDR420 CAS 2.5-2-3 ! D'la balle. je reapprends la stabilité la
n°518847
cpulloverc​lock
Posté le 15-06-2002 à 14:40:11  profilanswer
t a 210 en desynchro
 Page :   1  2  3
Page Précédente
Overclocking sur epox 4G4A+Epox 4BE4 ou DFI NB76 ?
cm p4 en i845 g , laquelle ?????? dfi nb76, epox g4, etcEPoX 4G4A+, Asus P4S533 ou Asus P4B533 ?
[Topic unique] EPoX 4G4A+ (Intel 845G, USB2.0, RAID,... )qui a moddé son epox 4bd2a+?
Epox 8k3a : ont peut fonctionner avec pci a 33 et fsb a + de 166?epox 8K3A kt333 ou abit kx7-333 ou asus a7n266-c what is best for oc ?
[PIV] IT7 ou la EPoX i845 ?Test Epox 4G4a+ (Chipset i845G)
Plus de sujets relatifs à : Epox 4G4A+ => Aux chiottes !
