3658 connectés
  Water & Xtreme Cooling
  [avis] waterblock zalman 8800 gtx
n°1984190
cogliostro​1
on est toujours le con d1 autr
Posté le 17-02-2010 à 14:28:18  profilanswer
Bonjours
j ai trouver une bonne occasion pour acheter des waterblock GPU zalmann pour 8800 gtx je voulais savoir votre avis la dessus
dans le but de me faire un water cooling  pour gpu *2 + cpu + mosfet carte mere
n°1984839
cogliostro​1
Posté le 19-02-2010 à 00:10:43  profilanswer
tit up
j ai trouver ca sur le site de zalmann ca vous inspire quoi ??
visiblement c est de l alu c est pas trop mal ??
a 30 roro le block vous prendriez ??
ZM-GWB8800 Ultra/GTX
VGA water-block produced with dimple-processing, designed for use with NVIDIA Geforce 8800 Ultra/GTX series.
 Zalman’s innovative dimple-type processing technology allows lightness in weight and excellent cooling performance.
 Pure aluminum-base material water bock provides excellent heat transfer, and anodized base prevents corrosion.
 High performance thermal pads with excellent elasticity provide great adhesion to all heat-generating components.
 The optimized design allows easy installation and direct cooling of RAM, FET, and I/O chipset.
*  Notice
This CPU water block is a component for water cooling systems for CPUs and cannot be used independently. It must be used with a water cooling system such as ZALMAN's RESERATOR 1 Plus/ RESERATOR 1 V2/RESERATOR 2/ RESERATOR XT Water Cooling System.
Dimensions  93(W) x 183(L) x 31(H) mm
Weight  420g
Base Material  1) Water Block Cover / Base : Pure Aluminum 2) Fitting : Brass
Compatible Tubes (Outer x Inner)  13 x 9mm, 12 x 8mm, 11 x 8mm, 10 x 8mm
- VGA Water Block Assembly
- Nine (9) Nipples
- Nine (9) Nuts
- Two (2) PVC Washer Plates
- Ten (10) Springs
- Ten (10) O-rings
- Two (2) Tube Clamps
- Thermal Grease
- Thermal Pads
   One (1) 14 x 14 x 1T (for I/O Chipset Contact)
   Four (4) 7 x 23 x 1T (for FET Contact)
   Three (3) 16 x 70 x 1T (for RAM Contact)
- User’s Manual
je vend mon waterblock 295avis sur temp cpu i7 oc a 4.00ghz
Overclocking - Q9550 : votre avis ?Waterblock Rampage
Help Waterblock ASUS P5QD TURBO et EN260GTXNouveau en matiere de watercooling....conseil ,avis
[Workblog] Tomy en MM H2gO - 3930K et sli 580 :) Full KOOLANCE <3[Topic Unique] La gamme de ventirads CPU Zalman
Meilleur bios pour 8800 GT?[Avis] wc configuration..
Plus de sujets relatifs à : [avis] waterblock zalman 8800 gtx
