4351 connectés
  CPU
  aide pour overclocker sont i 5 3570k
n°2319905
valentinpr​out59
Posté le 11-11-2013 à 13:31:46  profilanswer
bonjour j'ai un problème je n'arrive pas a overclocker mon i5 il toujours est stable a 4.2 ghz mais je n’arrive pas a le stabiliser a 4.3 ghz ,
pouvez vous d'aimer svp ?
n°2319913
valentinpr​out59
Posté le 11-11-2013 à 14:46:11  profilanswer
voici les graphe d'un petit test de 8 min a 42 ghz
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/967581_689623017714741_757018775_n.jpg?oh=0276c83570b757175618f72fd48c48ec&oe=528310A4
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1464952_689623021048074_1368018143_n.jpg?oh=03d463929803772366168a76f052d6b4&oe=52833916
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1456933_689623024381407_1062064573_n.jpg?oh=1a09452e951e44a853627a3e8bfba01e&oe=528322EB
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1396592_689623027714740_2057060060_n.jpg?oh=f95d6325dc8f244f0d0f16324c7206b4&oe=5282F06D
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1392650_689623037714739_318198754_n.jpg?oh=c2d0ac689d23fc6a9ab83e8b5a0ff26f&oe=52833294
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1420565_689623034381406_1780779891_n.jpg?oh=11278ea5ed70165599831bc87f05343f&oe=5282F62D
https://scontent-b-mad.xx.fbcdn.net/hphotos-frc3/v/1415593_689623051048071_1008947698_n.jpg?oh=06938fc109815e7d2ffe0cf12f9928f4&oe=52835F71
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1462050_689623044381405_405283747_n.jpg?oh=04b5589bc80d72ff497b7a5cfc86c662&oe=528320DB
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1454457_689623054381404_1515123353_n.jpg?oh=4c3aa48bc133d6a8c51faf1fd4140f46&oe=5282EF29
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1454428_689623064381403_1145272232_n.jpg?oh=1c0ec74bc91ef979c92330aa473fe486&oe=5282E6E4
https://scontent-b-mad.xx.fbcdn.net/hphotos-frc1/v/1419954_689623071048069_1366582686_n.jpg?oh=da54b8b6f80475977f1a93cfcdfaa840&oe=52831B5B
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1418345_689623067714736_95520773_n.jpg?oh=7ec16881c1eea5b65592c1c7d8441b75&oe=5283204A
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1396575_689623081048068_109059634_n.jpg?oh=b97aad0adfd72ce07f3f7b90c2e72555&oe=52832B74
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1395036_689623084381401_1798962668_n.jpg?oh=ca92677ca67856ab51e560e5050f8f92&oe=52835F8F
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1394994_689623091048067_1771955515_n.jpg?oh=c21ef3a87f51904ce5f74f60bd9e0d51&oe=52831FB3
n°2319917
jean-phili​ppe59400
Posté le 11-11-2013 à 16:05:14  profilanswer
Salut
A 4.2 Gz il n'est pas proprement dit stable, 8 Mn ne suffise pas pour déterminé la stabilité , fait un essai de 30 Mn minimum si c'est stable durant ces 30 Mn, pousse a 4.3 Ghz et noublie pas de monté ton Vcore (comme il ne tient pas sans y toucher)
le mien est gourmand en V il demande prêt de 1,27v a 4.4Ghz tu peut pousser mais ne monte pas au dessus de 1.30v et vérifie tes T°, tu as quoi comme refroidissement ?
Cordialement J-p
tout fil coupé a la même longueur sera toujours trop court
n°2319918
valentinpr​out59
Posté le 11-11-2013 à 16:13:17  profilanswer
j'ai deja fait un test 1 h a 4.2 ghz est ca vas je n'ais pas eux d'erreur
mais si j'augmente le vcore  j'ai un ecran bleu,  même a 4.2 ghz
vous me conseiller de metre combien en vcore pour 4.3 ghz ?
et pour le monter a 4.3 ghz je monte le ratio ou la fréquence bclv/peg ?
 et je suis en watercoolling
ma carte mere est une asus z77p8 vlk
n°2319925
flagadadim
harley quinn fanboy
Posté le 11-11-2013 à 17:56:56  profilanswer
PLL overvoltage activé?
Turbo désactivé?
« Quand j'étais jeune, j'étais très con. Je suis resté très jeune. »Jean-Claude Van Damme
n°2319946
valentinpr​out59
Posté le 11-11-2013 à 19:18:41  profilanswer
internal PLL overvoltage : activer
parcontre si je désactive le mode turbo je ne peut plus changer le ratio je peut donc agir que sur la fréquence BCLK/PEG
ces le ratio du mode turbo que je change enfait mais ce qui fait qu'il est toujour s en mode turbo
n°2320187
valentinpr​out59
Posté le 12-11-2013 à 20:28:10  profilanswer
personne pour m'aidez ?
n°2320191
flagadadim
harley quinn fanboy
Posté le 12-11-2013 à 20:33:21  profilanswer
Et au niveau des réglages de limitation de puissance du bios tu as cherché?
n°2320212
valentinpr​out59
Posté le 12-11-2013 à 21:22:58  profilanswer
pour alimentation du cpu j'ai tout laisser en auto
la j'ai reusis a l'avoir stable a 4.3 ghz mais pas moyen a 4.4 ghz je ne sais pas pourquoi même en mettant un vcore a 1.3v ca ne passe pas
voici les impression écran de mon bios
https://scontent-b-cdg.xx.fbcdn.net/hphotos-prn2/v/1420599_690295827647460_354612222_n.jpg?oh=f068068928a9233cce50023ac1d7aefb&oe=52841CF6
https://scontent-b-cdg.xx.fbcdn.net/hphotos-frc3/v/1420240_690295920980784_2073474777_n.jpg?oh=bebba98d86f1ef1a90070dde9ad44be8&oe=52846914
https://scontent-b-cdg.xx.fbcdn.net/hphotos-prn2/v/1470793_690295957647447_956352060_n.jpg?oh=6f1c7a7d84fd956701d03a158fbd0c31&oe=52845353
https://scontent-b-cdg.xx.fbcdn.net/hphotos-frc3/v/1420079_690296147647428_732694076_n.jpg?oh=f0c05ac90ca2681a4ce286d1cabcc8eb&oe=5284376B
dsl pour tout les images
Message édité par valentinprout59 le 12-11-2013 à 21:24:13
n°2320290
ricobab
Posté le 13-11-2013 à 10:31:50  profilanswer
Quand tu dis que lorsque tu augmentes le vcore à 4.3Ghz, ça plante : Quel vcore as tu mis pour 4.3Ghz.
A ce que je vois, ton proc est dans la moyenne haute pour 1.22v/4.2Ghz.
A part augmenter le vcore, je ne vois pas. Essaie par palier de 0.05v.
PS : post nous uniquement des screen occt du vcore et du core le plus chaud. A ce stade, on n' a pas besoin du reste.
i7 11700K,Asus ROG MAXIMUS XIII APEX Z590, Asus TUF RTX 4070 Super, 32go Crucial Ballistix 3200, M2 Samsung 980 Pro 500go / 970 Evo Plus 1to, Corsair RM 850W
n°2320315
valentinpr​out59
Posté le 13-11-2013 à 13:53:03  profilanswer
J étais a 4,2 GHz a 1,215 v et le maintenant je suis a 4,3 GHz a 1,22v mais je n'arrive pas a atteindre les 4,4 GHz alors que j' augmente de 0,01v
Y a pas un paramètre de mal régler dans mon BIOS ?
n°2320323
ricobab
Posté le 13-11-2013 à 14:51:04  profilanswer
augmente de 0.05v en 0.05v. Puis tu affineras en redescendant par de plus petit palier.
tu devrais arriver à 4.4Ghz entre 1.25 et 1.28v.
Ton proc semble être dans la moyenne, donc rien d'anormal.
n°2320381
valentinpr​out59
Posté le 13-11-2013 à 20:29:15  profilanswer
bah j'ai tester j'ai commencer a  1.22 et j'ai monter de 0.01 en 0.01 donc 1.23 puis 1.24 comme ca jusqu'a 1.3 mais il n’étais pas stable , et plus j'augmenter et moins il étais stable je trouve
une mise a jour de mon bois ne m'aiderais pas ?
n°2320402
ricobab
Posté le 13-11-2013 à 21:38:23  profilanswer
C'est assez étonnant car rien dans ton bios ne semble étrange.
As tu essayé de faire la même chose en laissant la load line calibration sur "auto"
Sinon, tu peux tenter la mise à jour du bios, mais c'est un peu la loterie : tu as 99% de chance que ça ne change rien mais ça peut aussi avoir l'effet inverse : Quand j'ai mis à jour le bios de ma MSI Z77-A GD65, j'ai ensuite eu besoin d'un peu plus de vcore à fréquence égale, sans modifier aucun autre paramètres.
Essaie d'abord sans la load-line calibration, et ensuite tu peux tenter la maj du bios mais sans aucune certitude.
n°2320407
valentinpr​out59
Posté le 13-11-2013 à 22:14:32  profilanswer
j' essayer avec le load line en auto est c'est encore pire qu'en high a 1.23 il ne démarrer pas et a 1.24/1.25 il tenais la charge mais 10 seconde pas plus et a 1.27 il ne démarrer pas nonplus
lorsque j’étais en high  a 1.25v il  tenais la charge environ 2 a 3 min
mon processeur n'aimerais pas les tension élever?
n°2320408
valentinpr​out59
Posté le 13-11-2013 à 22:21:38  profilanswer
enfait c a 4344 mhz qu'il tenais 2 a 3 min pas a 44 ghz
  CPU
Je voudrais overclocker mon core i7 4770kOC 3570k besoin d'avis et conseils
Conseil & aide pour futur achat watercoolingOC I7-3820 LGA2011 sur subertooth X79, besoin d'aide et de conseils
besoin d'aide pour un ventilateur processeurquestion rapport occt après overclock i5 3570K
question rapport occt après overclock i5 3570Kwatercooling complet pièce par pièce
Plus de sujets relatifs à : aide pour overclocker sont i 5 3570k
