8074 connectés
Mod VDD abit NF7
n°743377
nasdak
Posté le 06-03-2003 à 21:59:59  profilanswer
bon quelqu'un la tente la mod?
j'ai reperé et apparement ya le meme chip sur la nf7 que sur l'epox
a priori meme chipset donc ca devrait etre la meme
n°743403
nasdak
Posté le 06-03-2003 à 22:14:20  profilanswer
n°743411
mokembo
Que c'est bon la retraite
Posté le 06-03-2003 à 22:24:01  profilanswer
moi je l'ai samedi matin donc je mod samedi soir  :D
The Mem voltage mod is the exact same as the BE7, BD7. I hook up a 10 ohm resister to pin 19 after cutting the pin. The resister goes from pin 19 to the mosfet. Then I hook a 100ohm VR to pin19 to ground for Voltage adjustments.
You can find the v-mod in the v-mod forums, be7 or bd7.
The VDD mod is easy money. The 6520 IC just under the AGP slot, I hooked up a 50k ohm resistor to pin 6 to ground. I think the 50k is an overkill but thats what I used. It actually reads 4.16k ohms right now. I assume a 10k VR would work fine. You measure the VDD off of a mosfet that is near the IC. I personally soldered a wire to the mosfet leg so I could have easy access to read the voltage, it would be impossable to measure when the agp card is in place.
I'll take some pictures right now.
OPP
Message édité par mokembo le 06-03-2003 à 22:28:19
n°743413
nasdak
Posté le 06-03-2003 à 22:25:35  profilanswer
marche po
n°743433
nasdak
Posté le 06-03-2003 à 22:34:47  profilanswer
oki
Zalman ZM80-HP ou ZM50-HP Abit KT7[Topic Specifique]A7N8X Mod Vcore (>2v)photo inside!
[A7N8X] Mod Voltage CPU + NorthMicro pince Mod Vcore
Mod VCore VMem Radeon 9700Pro ... j'ai un doute ! ... confirmé !*Topic officiel ABIT BH7* la reine de l oc???
[adie] o/c KR7A-133Raid + XP1700+ JIUHB 0304 (edit NF7-S)Augmenter le Vcpu sur ABIT NF7-S
XP 2600 sur NF7 ...
Plus de sujets relatifs à : Mod VDD abit NF7
