3967 connectés
  Water & Xtreme Cooling
  [ User Review (english)] Alphacool Cape Cyclone 38 HF 150 Reservoir
n°2162012
bundymania
Posté le 13-10-2011 à 11:42:44  profilanswer
Hello Guys,
The following short review is about the newest reservoir by Alphacool, the HF 38 Cape Cyclone !
http://www.abload.de/img/img_7600i7if.jpg
There are two sizes available, namely the Cyclone 250 and the smaller Cyclone 150 this review is about.
Let's start with a quick lesson about the history of Alphacool. They've been successful for years with the well known Cape Coolplex reservoirs, available in a lot of variations: beginning with the smallest model, the Coolplex 10, over the very popular Coolplex 25 up to the mega reservoir Cape Coolplex Pro Plexi 50, most customer's wishes are well fulfilled.
One aspect though characterizes all Alphacool reservoirs: the excellent build quality, the use of high quality materials and a good availability of spare parts, just in case.
All former Coolplex reservoirs had the same 50mm diameter and G 1/4" threads.
This time, Alphacool takes a step forward: the new Cyclone reservoirs are supposed to enhance to range of products with features that have never seen before.
The most important features and technical details:
2x G3/8" threads for use with fittings for 8, 10 or more mm inner diameter for high-flow-systems
2x G1/4" threads for LED lighting modules
Riser pipe with 12mm inner diameter and G1/4" inner thread
60 mm pipe diameter for more capacity
90° redirection in the riser pipe for easier filling
cyclone effect because of the controllable riser pipe in an angle of 180°
black POM top and bottom, sealed by O-rings
5mm thick tube made out of acrylic glass
Technical data:
Heigth: 170mm
Diameter: 60mm
Material: POM, PMMA
Capacity: 250cm³ / 1/4 litre
High quality made in Germany.
Price: 49,95 EUR (around 63,43 US$)
Scope of delivery:
Retail packaging, manual, 1x holding clamp (POM, black)
http://www.abload.de/img/img_7596q4x0.jpg
Features and every day use:
When using older reservoirs, the integrated riser tube could on the one hand reduce the amount of air sucked into the system, but on the other hand, when using high power pumps or with few cooler s in the system, made it almost impossible to fill the running system, as the coolant would flow over - usually with fatal consequences.
Alphacool now successfully cope with this issue with the integrated, slightly adjustable rising tube that comes with an exit to the side in the top area, so the water isn't directly pushed to the exit, making safe filling of a running system possible. In addition, this riser tube can be turned in an 180° angle to create appealing optical effects. The top end of the tube also features an additional thread that can be used to mount a lighting module, as it's also the common G1/4" size. You could also fit an angled fitting to create even more spectacular effects in the reservoir. As also stated in the "technical details" section above, the reservoir features bigger threads than usual, namely G3/8" that are supposed to increase the flow rate. When comparing to an EK Waterblocks 150 reservoir the increase was almost 10 litres/hour, even though using the included adapters for G1/4" fittings. This increase will be even greater when using a system made of components only made for G3/8" fittings, like a Thermochill radiator, an EK pump top and the new Alphacool Niagara CPU block, all coming with G3/8" threads.
The reservoir also features two G1/4" threads, which can be used for lighting modules or standard fittings alike, if the two G3/8" threads are covered with sealing caps (sold separately).
Another innovation is the increased diameter of this reservoir. It's 60mm, so it has a capacity of 250cm³, equating to 1/4 litre, which is a lot more than what fitted into other reservoirs of this size before.
The included holding clamp makes a rigid impression and is easy to mount at the reservoir. Screws are also included.
My test setup made of a Laing Ultra Pump, the Alphacool Niagara CPU block and other components helps the Cyclone reservoir to show what it's made of. The effects created by the riser pipe are appealing, filling even with flow rates of more than 150l/h worked perfectly. Separately sold lighting modules can make the reservoir also look great in the darkness.
The build quality is flawless, only the top required a bit more force to open on the first time.
http://www.abload.de/img/img_7602k1rg.jpg
http://www.abload.de/img/img_8106b3k8.jpg
Videos:
Alphacool HF 38 Cape Cyclone 150 AGB Reservoir - YouTube
Alphacool Cape Cyclone AGB - YouTube
Alphacool Cape Cyclone AGB Reservoir - YouTube
Conclusion:
Alphacool was able to succeed in implement a couple of useful new features. Of course, the current price tag is no bargain and the G3/8" threads won't be liked by everyone, but we must always remind ourselves that the development of a new product always costs a lot of money and there're also a lot of risks to be taken as a trendsetter.
In my opinion, Alphacool takes a step towards the right direction, that will hopefully soon be followed by other companies. I especially like the bigger diameter of 60mm and the sophisticated riser pipe with its both optical and practical features, paired up with the outstanding build quality.
It's just fun and eye candy to watch the Cyclone's water effects.
Closing, I'd like to thank Alphacool.de for providing this test sample. This Reservoir is also available at aquatuning.de and their partnershops in europe !
WB CPU: Ek Supreme vs Ek Supreme LT vs EK Supreme HF vs HeatKiller 3.0Conseil Pompe +réservoir objectif silence
Noctua NH-D14 ou Watercooling 150€Mon panier nommé Cyclone GT :)
couple pompe reservoir idéal ???Recherche possesseur WaterBlock Ek Supreme HF pour conseil montage
[AVIS] XSPC - Réservoir Double Baie Plexi pour D5[Worklog] LogicBox, le boitier HomeMade (le successeur p47)
Fixer un reservoir au 800DReservoir
Plus de sujets relatifs à : [ User Review (english)] Alphacool Cape Cyclone 38 HF 150 Reservoir
