5121 connectés
  Modding
  Que choisir entre CM 700W ou CORSAIR 650W
n°2055767
eminyoub
Posté le 01-11-2010 à 02:41:12  profilanswer
Salut
je ne sais quoi choisir entre Quoi choisir entre CM 700W ou CORSAIR 650W
COOLER MASTER Silent Pro M700 RS-700-AMBA-D3 700W ATX12V V2.3 SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply
Type ATX12V V2.3
Maximum Power 700W
Fans 135mm silent fan
PFC Active
+12V Rails Single
PCI-Express Connector 2 x 6+2-Pin
SATA Power Connector 9
SLI Certified
CrossFire Ready
Modular Yes
Power Good Signal 100-500ms
Hold-up Time 17ms min.
Efficiency > 85%
Energy-Efficient 80 PLUS Certified
Over Voltage Protection Yes
Overload Protection Yes
MTBF >100,000 Hours
Approvals NEMKO, TUV, CE, GOST, C-tick, UL, FCC
ou
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
Model
Brand CORSAIR
Model CMPSU-650TX
Spec
Type ATX12V / EPS12V
Maximum Power 650W
Fans Thermally controlled 120mm fan
PFC Active
Main Connector 20+4Pin
+12V Rails Single
PCI-E Connectors 2 x 6+2Pin
ATI CrossFire Support Yes
NVIDIA SLI Support Yes
Modular Cabling Support No
Efficiency > 80%
Input Voltage 100 - 240 V
Input Frequency Range 50/60 Hz
Input Current 10A
Output +3.3V@24A,+5V@30A,+12V@52A,-12V@0.8A,+5VSB@3.0A
MTBF >100,000 Hours
Approvals UL, CE, CB, TUV, FCC, CCC
Dimensions 5.9"(W) x 3.4"(H) X 5.9"(L)
Features
Connectors 1 x Main connector (20+4Pin)
1 x 12V(4/8Pin)
8 x peripheral
8 x SATA
2 x Floppy
2 x PCI-E
Ma configuration:
Boitier COOLER MASTER Storm Scout
Processeur AMD Phenom II X2 550  3.11GHz
Motherboard ASUSTeK Computer INC. M4A78T-E (AM3)
2GB RAM DDR3 Corsair
500GB Disque Dur SATA
Carte Vidéo Powercolor Radeon HD 5850 PCS+
Graveur/Lecteur DVDRW
 Zalman CNPS 8700 NT
XIGMATEK XLF-F1253 120mm  (x2)
Message édité par eminyoub le 01-11-2010 à 18:04:21
n°2055840
clembrizou
Posté le 01-11-2010 à 12:07:10  profilanswer
Une petite révision du titre : "Que choisir" plutôt que "quoi choisir", ça fait un peu mieux quand même.
Après pour l'alim une 650 ou 700 watts ça commence à faire surtout vu les composants que tu as, 400 watts seront déjà largement suffisant, Ton système ne devrait consommer qu'aux alentours de 300W, enfin tu vois
Perso avec cette aconfig je prendrais ça
http://www.materiel.net/ctl/Alimen [...] _450W.html
ou si tu veux vraient plus de watt au cas où tu veuilles vraiment plus de puissance (mais qui ne sera pas utilisée dans ton cas)
http://www.materiel.net/ctl/Alimen [...] _550W.html
P.S : j'ai une corsair 650TX (avec une config qui consomme) et je peux te dire que les alim corsair c'est le top, pas un bruit.
EDIT : Tu es dans la mauvaise section du forum
Message édité par clembrizou le 01-11-2010 à 12:26:36
Feedback
n°2055845
truman24
Posté le 01-11-2010 à 12:26:12  profilanswer
Ayant une cooler master, je peux te dire que c'est du costo !! J'ai une 620 et quand je monte a 500w de consomation elle ne bronche pas ! Pas une perte de tension rien, et surtout : PAS UN BRUIT !!
La modularité et pas trop mal.
Je ne connais pas dutout les corsair, donc je ne compare pas je donne juste mon expérience.
Voila
http://forum.hardware.fr/hfr/Overc [...] m#t2043925
n°2055846
clembrizou
Posté le 01-11-2010 à 12:29:29  profilanswer
Les alimentations corsair sont produite par ou à base de seasonic, la meilleur marque d'alimentation (un peu de parti prit ça fait pas de mal ).
Feedback
n°2055948
eminyoub
Posté le 01-11-2010 à 17:59:08  profilanswer
Merci pour les reponses rapide je voudrais vous dire un truc avant  je m'excuse pour les fautes d'orthographe parce que je ne suis pas un francophone :)
parce que moi actuellement j'ai une Ocz 500W SXS est je voulais l'a changer contre CM ou CORSAIR est pourquoi tout ça, parce que pendant que je jouais les jeux genre Splinter cell conviction je vois parfois mais pas a tout le temps je vois comme des petites vagues qui passe sur les graphisme de jeu (je ne sais est ce que vous allez me comprendre) est moi j'ai dis peut etre la carte graphique elle ne donne pas ce qu'elle a cause la faiblesse de mon power supply ou le jeu a besoin de plus que 2GB de ram peut etre ??
n°2056047
eminyoub
Posté le 01-11-2010 à 21:36:54  profilanswer
Voila
merci pour t'as reponse
le probleme c'est que j'ai une Ocz 500WSXS je ne sais pas est ce que je reste avec
voila mon probleme
n°2056063
polomod
www.polomod.fr
Posté le 01-11-2010 à 22:28:36  profilanswer
garde ton alim ... le problème vient d'autre part  ;)
www.polomod.fr   fermé    -     Facebook PoLoMoD
n°2056100
clembrizou
Posté le 02-11-2010 à 00:19:31  profilanswer
Oui peut-être un problème du côté de la carte graphique... pas la peine de changer ton alim, ce n'est pas un mauvais modèle et la puissance est suffisante
Feedback
  Modding
I5 760 choisir la bonne RAM ?quelle pompe choisir ?
[workblog] 800D + RX 480 + GTX 560 bientot watercooléhtpc silencieux: quel ventirad et quels ventillateurs choisir
quel CM matx pour oc c2dplastique entre ventilo et composants dans corsair vx550
Overclocker une Gigabyte GA-8I915PM (CM Packad Bell)Corsair H50 : ce qu'il faut savoir ??
[Workblog] CM 690 II Advanced by Alex-SpecCorsair H50 dans un shuttle
Plus de sujets relatifs à : Que choisir entre CM 700W ou CORSAIR 650W
