9447 connectés
  Divers
  OC e8500 sur ep45-ud3l
n°2192657
chongghost
Posté le 16-02-2012 à 22:56:52  profilanswer
mon bios
Robust Graphics Booster ...............: [turbo]
 CPU Clock Ratio .......................: [ 9]
 Fine CPU Clock Ratio...................: +0.5
 CPU Frequency .........................: 4.4 GHz
 Clock Chip Control
 Standard Clock Control
 CPU Host Clock Control.................: [Enabled]
 CPU Host Frequency (Mhz) ..............: 464
 PCI Express Frequency (Mhz) ...........: 100
 C.I.A.2 ...............................: [Disabled]
 Advanced Clock Control [Press Enter]
 CPU Clock Drive........................: 800mV
 PCI Express Clock Drive................: 900mV
 CPU Clock Skew (ps)....................: 0ps
 MCH Clock Skew (ps)....................: 0ps
 DRAM Performance Control
 Performance Enhance....................: [STANDARD]
 (G)MCH Frequency Latch.................: Auto
 System Memory Multiplier ..............: 2.00D
 Memory Frequency (Mhz) ................: 928
 DRAM Timing Selectable ................: [Manual]
 Standard Timing Control
 CAS Latency Time.......................: 5
 tRCD ..................................: 5
 tRP'...................................: 5
 tRAS...................................: 15
Load Line Calibration..................: [Disabled]
 CPU Vcore...............1.26250V.......: 1.450
 CPU Termination.........1.200V.........: 1.280
 CPU PLL.................1.550V.........: 1.650
 CPU Reference...........0.805V.........: 0.835
 MCH/ICH
 MCH Core................1.100V.........: 1.300
 MCH Reference...........0.760V.........: 0.790
 ICH I/O.................1.550V.........: 1.570
 ICH Core................1.100V.........: 1.200
 DRAM
 DRAM Voltage............1.800V.........: 2.100
Advanced Settings
 Limit CPUID Max. to 3..................: [Disabled]
 No-Execute Memory Protect..............: [Enabled]
 CPU Enhanced Halt (C1E)................: [Disabled]
 C2/C2E State Support...................: [Disabled]
 x C4/C4E State Support.................: [Disabled]
 CPU Thermal Monitor 2(TM2) ............: [Enabled]
 CPU EIST Function......................: [Disabled]
 Virtualization Technology..............: [enabled]
e8500
ep45-ud3l
2X 2gb kingston hyperx pc2-6400 400mhz
hd 6870
750watt
WC corsair h60
Mes question maintenant,
--que pensez vous de l'OC sachant que mon vcore est haut et ca je le sais, pas besoin de me le dire.
-- Virtualization Technology qu'est ce que c'est
-- au niveau Ram, mes timming sont corect pour continuer mon OC ou je devrais les relacher encore un peux plus ?
-- Si en voulant ajouter de la Ram, est ce que je dois me trouver exactement la meme ram kingston... ou je peux mettre autre chose ( j'imagine qu'en mettant d'autre sorte de ram, si les setting ne sont pas identique que ca ne sera pas stable)
-- Et surtout, si quelquun a un site ou des info concernant exactement ce que chaque tension font au motherbord ca serais génial
-- pour finir, pour monter vers 4.6 4.7 quel genre de tension et ou timming je devrais changer ?
Alors j'attends vos réponse, et jai bien hate de pouvoir analyser tout ca
Message édité par chongghost le 16-02-2012 à 22:57:44
n°2192901
chongghost
Posté le 18-02-2012 à 02:09:23  profilanswer
up, quelqu'un svp.. :P
n°2192958
Cresius
Riche de passion !
Posté le 18-02-2012 à 14:05:17  profilanswer
-Pour moi c'est haut comme Vcore mais je connais pas plus que sa ton proc
VID Voltage Range
 0.8500V-1.3625V
source site intel pour ton proc
-Virtualisation technologie te permet d'émulé plusieurs système d'exploitation sans perte de perf (mais bon c'est rare)
-Du cas5 quand tu vois qu'actuellement la majorité et en Cs7/8/9 tu as de la marge, mais relâche que quand tu as des BS du à un problème de ram
-Si tu veux ajouter ils faut généralement la même référence (souci de compatibilité) ou du moins je pense même pcxxxxx et fréquence.
-Je te conseillerais surtout de surveiller les voltage car sa me parrais bien haut
Mon petit worblog !<-8->Mes ventes/achat !<-8->Ma page service sur fb !
n°2193142
chongghost
Posté le 18-02-2012 à 23:09:38  profilanswer
donc la virtualization je peux garder enabled ?? ou le meilleur serais de le disabled ??
merci pour l'info des ram... je croyais la meme chose mais me le faire confirmer est bien.
n°2193160
Cresius
Riche de passion !
Posté le 19-02-2012 à 01:43:13  profilanswer
oui tu peu c'est un petit plus sans conséquence
n°2193431
chongghost
Posté le 19-02-2012 à 22:20:13  profilanswer
je suis passer en 4.5 ghz, mais finalement je devais monter mon v core encore... est-ce normal.. je suis donc passé en 1.47 volt....tandis que en 4.1 ghz jetais a 1.36 volt si mes souvenirs son bon
Je fais donc présentement des test au niveau chaleur et prime.
J'ai aussi rajouter 4 gb de ram de la meme ram que j'ai présentement, ca va faire ca de plus.
Que pensez vous des résulta ??
n°2193432
chongghost
Posté le 19-02-2012 à 22:27:32  profilanswer
je rectifi, ca ne tient pas encore jusqua 1.47.5 volt... un peux plus longtemps voir 7-8 min apres écran bleu qui me dit que window as du arreter se fermer pour pas causer de probleme au hardware, quelque chose du genre. si quelquun sais en quoi ca consiste exacactement ca me donerais un coup de main a continuer de monter.... je suis décourager
n°2194874
chongghost
Posté le 25-02-2012 à 16:55:40  profilanswer
Je suis rendu a 4.5 ghz stable
n°2195569
chongghost
Posté le 27-02-2012 à 21:26:42  profilanswer
Apres avoir monter jusqua 4.7 ghz, tout d'un coup, paf.. tout as flancher, les drivers ont sauter, surtout ceux de ma carte graphique et la pu rien de stable meme a 4 ghz... alors jai du faire un cmos, et je suis reparti, 4.5 ghz stable apres 5h de prime 95
Je tient aussi a dire que jai mit un fan 120 mm de plus sur mon corsair h 60 pour laider a pousser l'air dans le mini rad du Corsair
Avec ca, je dois gagner+- 8-9 degrés au niveau des core
E8500 3.16ghz @ 4.5ghz
  Divers
Overcloacking pour débutantPas d'écran après overcloacking!
Overcloacking d'un Pentium4 650Overcloacking d'une Geforce4mx 420! De 4100pts à 5199 !
P4, DDR/RDRAM, overcloackingOvercloacking radeon
Kit d overcloacking pour tte carte graphique (core et memoire)Overcloacking d une geforce3
Fiabilité d overcloacking des chip nVIDIA selon les drivers ???????Overcloacking des processeurs AMD au fsb 266Mhz
Plus de sujets relatifs à : OC e8500 sur ep45-ud3l
