7935 connectés
  CPU
  Problème Overclocking de mon i5 750 4ghz
n°2489070
Euphoria84
Posté le 08-03-2018 à 19:04:10  profilanswer
Bonjour à tous, j'ai overcloker mon cpu i5 750 à 4ghz avec les réglages que voici:
Ai Overclock Tuner-----------------------------------Manuel
OC From CPU Level Up---------------------------------Auto
cpuCPU Ratio Setting---------------------------------20.0
Technologie Intelr SpeedStepT------------------------Désactiver
Xtreme Phase Full Power Mode-------------------------Activer
BCLK Frequency---------------------------------------200
PCIE Frequency---------------------------------------100
DRAM Frequency---------------------------------------DDR3-1600Mhz
QPI Frequency----------------------------------------"6407"
ASUS/3rd Party UI Priority---------------------------3rd Party Utility
OC Tuner---------------------------------------------Turbo Profile
CPU Voltage Mode-------------------------------------Manuel
Fixed Voltage----------------------------------------1.32v
IMC Voltage------------------------------------------1.15v
DRAM Voltage-----------------------------------------1.65v
CPU PLL Voltage--------------------------------------1.80v
PCH Voltage------------------------------------------1.05v
DRAM DATA REF Voltage on CHA-------------------------Auto
DRAM DATA REF Voltage on CHB-------------------------Auto
Load-Line Calibration--------------------------------Activé
CPU Spread Spectrum----------------------------------Désactivé
PCIE Spread Spectrum---------------------------------Désactivé
CPU Ratio Setting------------------------------------20.0
C1E Support------------------------------------------Désactivé
Hardware Prefetcher----------------------------------Activé
Adjacent Cache Line Prefetch-------------------------Activé
Max CPUID Value Limit--------------------------------Désactivé
Intel(R) Virtualization Tech-------------------------Désactivé
Fonction TM du CPU-----------------------------------Désactivé
Execute-Disable Bit Capability-----------------------Activé
Active Processor Cores-------------------------------All
A20M-------------------------------------------------Désactivé
Technologie Intelr SpeedStepT------------------------Désactivé
Intel(R) C-STATE Tech--------------------------------Activé
une fois que je lance occt pour vérifier la stabilité de mon overclocking: je reçois un message me disant: CPUTIN a depassé la valeur maximale Valeur:86,5 Valeur maximale:85.
Voici ma config:
Processeur : Intel Core i5-750 @ 2.67Ghz
Ventirad : Cooler Master Hype 212 plus
Carte graphique : AMD Radeon Sapphire HD 7870 2gb
RAM : 8Go G.Skill Kit Extreme3 (2x2 GO + 1x4 GO) PC 12100 Ripjaws
Alimentation : Coolmaster 500w B500 v2
Pourtant le processeur est à 46°c en idle.
Cordialement.
n°2489089
dift666
Posté le 08-03-2018 à 22:08:53  profilanswer
Ton système de refroidissement est insuffisant quand tu stress ton cpu.
Tu as dépassé la température maximum (safe) donc occt arrête le test.
CPUTIN = température du processeur (4 coeurs)
Solutions: changer la patte thermique, changer le ventirad ou baisser l'overcloking a 3.6ghz ou 3.8ghz
Mon i5 750 et 760 a l'époque étaient tout deux équipé d'un gros ventirad noctua équipé de 2 ventilateurs pour tenir les 4ghz-4.2ghz dans des températures raisonnables!
Si quelqu'un peut valider
Message édité par dift666 le 08-03-2018 à 22:39:28
n°2489105
Euphoria84
Posté le 09-03-2018 à 06:37:43  profilanswer
bonjour merci pour la reponse j'ai changer la pate thermique ya 2 jours, je suis a 44°c en idle la sans oc , selon toi un Noctua NH-U12S peut faire l affaire ?
  CPU
Problème CPU ?Problème Démarrage Pompe Waterblock Nepton 120 XL
Problème circulation du fluide WCOverclocking Ryzen 7 1700 sur MSI Carbon Pro x370 Ventirad Msi Frozr L
[Résolu] Problème first WC customAide overclocking EVGA GTX 1070 SC
Grosse chauffe nécessité de delid un i5 4960K ?Surchauffe I5-7600K
Aide @ I5 8600K Asus Prime Ainterpretation OCCT i5 6600k
Plus de sujets relatifs à : Problème Overclocking de mon i5 750 4ghz
