2703 connectés
  CPU
  OC i5 3570k + z77 extreme 4 ( finalisation )
n°2299149
fredodido5​6
Posté le 01-07-2013 à 19:41:29  profilanswer
:hello: Hello tout le monde :hello:
Je voulais savoir si il manque des réglages pour peaufiner le tout  :D
Merci !  :jap:  :jap:
http://img11.hostingpics.net/thumbs/mini_185930130701191343.pnghttp://img11.hostingpics.net/thumbs/mini_349823130701191348.pnghttp://img11.hostingpics.net/thumbs/mini_837101130701191413.pnghttp://img11.hostingpics.net/thumbs/mini_953509130701191436.pnghttp://img11.hostingpics.net/thumbs/mini_566419130701191503.png
http://img11.hostingpics.net/thumbs/mini_9201472013070119h06CpuUsageCPUUsage.pnghttp://img11.hostingpics.net/thumbs/mini_4729432013070119h06FrequencyBus.pnghttp://img11.hostingpics.net/thumbs/mini_8369822013070119h06MemoryUsageMemoryUsed.pnghttp://img11.hostingpics.net/thumbs/mini_5671592013070119h06TemperatureCore0.pnghttp://img11.hostingpics.net/thumbs/mini_5369242013070119h06TemperatureCore1.pnghttp://img11.hostingpics.net/thumbs/mini_9265722013070119h06TemperatureCore2.pnghttp://img11.hostingpics.net/thumbs/mini_7541522013070119h06TemperatureCore3.pnghttp://img11.hostingpics.net/thumbs/mini_4702212013070119h06Temperaturecore2.pnghttp://img11.hostingpics.net/thumbs/mini_9059522013070119h06Temperaturecore3.pnghttp://img11.hostingpics.net/thumbs/mini_2041462013070119h06Temperaturecore4.pnghttp://img11.hostingpics.net/thumbs/mini_9528312013070119h06Temperaturecore.pnghttp://img11.hostingpics.net/thumbs/mini_7870342013070119h06TemperatureCPUTIN.pnghttp://img11.hostingpics.net/thumbs/mini_7768042013070119h06Voltage3VCC.pnghttp://img11.hostingpics.net/thumbs/mini_2239122013070119h06VoltageAVCC.pnghttp://img11.hostingpics.net/thumbs/mini_4862102013070119h06VoltageCPUVCORE.pnghttp://img11.hostingpics.net/thumbs/mini_4689182013070119h06VoltageVIN0.pnghttp://img11.hostingpics.net/thumbs/mini_9378852013070119h06VoltageVIN1.pnghttp://img11.hostingpics.net/thumbs/mini_6498132013070119h06VoltageVIN4.pnghttp://img11.hostingpics.net/thumbs/mini_5165292013070119h06VoltageVIN5.pnghttp://img11.hostingpics.net/thumbs/mini_4946212013070119h06VoltageVIN6.png
n°2299186
ricobab
Posté le 01-07-2013 à 21:33:00  profilanswer
Si c'est stable, chapeau.
4.6Ghz pour 1.175v le tout à env 75C° en charge, c'est plus que bon.
Rien à dire de particulier sur le bios : à part peut être désactiver le intel turbo boost (pas de boost, car ton proc est oc de toute manière...), mettre le PLL overvoltage sur "high" ou "enabled" et desactiver le Intel C-State
Beau proc en tout cas !
i7 11700K,Asus ROG MAXIMUS XIII APEX Z590, Asus TUF RTX 4070 Super, 32go Crucial Ballistix 3200, M2 Samsung 980 Pro 500go / 970 Evo Plus 1to, Corsair RM 850W
n°2299189
fredodido5​6
Posté le 01-07-2013 à 21:37:23  profilanswer
Merci je vais tester ça ;) là je viens de faire les même test à 4.7Ghz et j'ai testé également sous battlefield 3, aucun soucis, temp à 60 sur le core le plus chaud ( en jeu seulement ^^ )
n°2299205
ricobab
Posté le 01-07-2013 à 22:38:23  profilanswer
C'est beau car moi je suis a env 65c° en jeu (3770K 4.5Ghz à 1.28v) et 78C° sous occt linpack avec avx.
Rien à dire, tu as un excellent proc !
n°2299222
siccagm
Carpe Diem
Posté le 01-07-2013 à 23:59:50  profilanswer
Salut, tres joli OC avec ton asrock.
T'a quoi comme ventirad pour avoir ces temp?
n°2299227
fredodido5​6
Posté le 02-07-2013 à 00:25:42  profilanswer
Slt !
Oui apparement il tient bien ca fait plaisir ^^
Pour le refroidissement je suis sous H100i ;)
edit : 81C° sous occt linpack avec avx.
Message édité par fredodido56 le 02-07-2013 à 00:37:48
n°2299515
TealeaF
bier-biere-beer
Posté le 03-07-2013 à 19:15:37  profilanswer
Salut fredodido56,
Tu as posté les screens de ton bios uniquement sur les valeurs que tu as modifié ou tu as également touché à la RAM?
Pour comparaison j'ai 4.6Ghz à ~1.22v mais on offset mode.
3570K/Extreme 4/2x4Go Kingston 1600Mhz cl9
n°2299541
ricobab
Posté le 03-07-2013 à 21:08:19  profilanswer
Sur ses screens, on voit que la ram est en auto.
n°2299573
fredodido5​6
Posté le 04-07-2013 à 01:40:55  profilanswer
Ram en 1:6 à 1600 mhz, ;) merci rico :D
  CPU
Probléme OC ram kingston hyperx beast 1866 @ 2800Comment commencer l'OC
Aide oc i5 3570k et cm gygabite z77 d3hWater Cooling Extreme (exemple avec un Corsair H100)
[Aide OC] i7 2600K + Asus P8Z78-V 3.0O/C mon i5 2500 non k
Besoin d'aide pour OC i7 2700K , Asus Sabertooth P67OC 3570k+scythe ninja 3
Plus de sujets relatifs à : OC i5 3570k + z77 extreme 4 ( finalisation )
