3712 connectés
  Linux et OS Alternatifs
  réseaux et sécurité
  Problème de put en SFTP
n°1176525
smea
alias peshane SW-1088-1675-051
Posté le 02-11-2009 à 10:56:08  profilanswer
sur un serveur AIX, et avec openssh, des transferts avec le client sftp de fichiers d'environ 10 Mo s'arrêtent de la façon suivante:
debug3: Sent message SSH2_FXP_WRITE I:144 O:4620288 S:32768
debug3: SSH2_FXP_STATUS 0
debug3: In write loop, ack for 128 32768 bytes at 4096000
debug2: channel 0: rcvd adjust 32768
debug3: Sent message SSH2_FXP_WRITE I:145 O:4653056 S:32768
debug3: In write loop, ack for 129 32768 bytes at 4128768
test2        26% 4576KB  69.4KB/s   03:03 ETAdebug2: channel 0: rcvd adjust 32768
debug3: Sent message SSH2_FXP_WRITE I:146 O:4685824 S:32768
debug3: In write loop, ack for 130 32768 bytes at 4161536
debug3: Sent message SSH2_FXP_WRITE I:147 O:4718592 S:32768
debug3: In write loop, ack for 131 32768 bytes at 4194304
debug3: Sent message SSH2_FXP_WRITE I:148 O:4751360 S:32768
debug3: In write loop, ack for 132 32768 bytes at 4227072
test2        26% 4672KB  72.1KB/s   02:55 ETAdebug2: channel 0: rcvd adjust 32768
debug3: Sent message SSH2_FXP_WRITE I:149 O:4784128 S:32768
debug3: In write loop, ack for 133 32768 bytes at 4259840
test2        27% 4704KB  68.1KB/s   03:05 ETAdebug2: channel 0: rcvd adjust 32768
debug3: Sent message SSH2_FXP_WRITE I:150 O:4816896 S:32768
debug3: In write loop, ack for 134 32768 bytes at 4292608
debug3: Sent message SSH2_FXP_WRITE I:151 O:4849664 S:32768
debug3: In write loop, ack for 135 32768 bytes at 4325376
debug3: Sent message SSH2_FXP_WRITE I:152 O:4882432 S:32768
debug3: In write loop, ack for 136 32768 bytes at 4358144
test2        27% 4800KB  70.8KB/s   02:56 ETAdebug2: channel 0: rcvd adjust 32768
debug3: Sent message SSH2_FXP_WRITE I:153 O:4915200 S:32768
debug3: In write loop, ack for 137 32768 bytes at 4390912
test2        27% 4832KB  67.0KB/s   03:06 ETAdebug2: channel 0: rcvd adjust 32768
debug3: Sent message SSH2_FXP_WRITE I:154 O:4947968 S:32768
debug3: In write loop, ack for 138 32768 bytes at 4423680
debug3: Sent message SSH2_FXP_WRITE I:155 O:4980736 S:32768
debug3: In write loop, ack for 139 32768 bytes at 4456448
debug3: Sent message SSH2_FXP_WRITE I:156 O:5013504 S:32768
debug3: In write loop, ack for 140 32768 bytes at 4489216
debug3: Sent message SSH2_FXP_WRITE I:157 O:5046272 S:32768
debug3: In write loop, ack for 141 32768 bytes at 4521984
debug3: Sent message SSH2_FXP_WRITE I:158 O:5079040 S:32768
debug3: In write loop, ack for 142 32768 bytes at 4554752
debug3: Sent message SSH2_FXP_WRITE I:159 O:5111808 S:32768
debug3: In write loop, ack for 143 32768 bytes at 4587520
debug3: Sent message SSH2_FXP_WRITE I:160 O:5144576 S:32768
debug3: In write loop, ack for 144 32768 bytes at 4620288
debug3: Sent message SSH2_FXP_WRITE I:161 O:5177344 S:32768
debug3: In write loop, ack for 145 32768 bytes at 4653056
test2        29% 5088KB  85.9KB/s   02:22 ETAdebug2: channel 0: rcvd adjust 32768
debug3: Sent message SSH2_FXP_WRITE I:162 O:5210112 S:32768
debug3: In write loop, ack for 146 32768 bytes at 4685824
debug3: Sent message SSH2_FXP_WRITE I:163 O:5242880 S:32768
debug3: In write loop, ack for 147 32768 bytes at 4718592
debug3: Sent message SSH2_FXP_WRITE I:164 O:5275648 S:32768
debug3: In write loop, ack for 148 32768 bytes at 4751360
debug3: Sent message SSH2_FXP_WRITE I:165 O:5308416 S:32768
debug3: In write loop, ack for 149 32768 bytes at 4784128
debug3: Sent message SSH2_FXP_WRITE I:166 O:5341184 S:32768
debug3: In write loop, ack for 150 32768 bytes at 4816896
debug3: Sent message SSH2_FXP_WRITE I:167 O:5373952 S:32768
debug3: In write loop, ack for 151 32768 bytes at 4849664
test2        30% 5280KB  96.5KB/s   02:04 ETAdebug2: channel 0: rcvd adjust 32768
debug3: Sent message SSH2_FXP_WRITE I:168 O:5406720 S:32768
debug3: In write loop, ack for 152 32768 bytes at 4882432
debug3: Sent message SSH2_FXP_WRITE I:169 O:5439488 S:32768
debug3: In write loop, ack for 153 32768 bytes at 4915200
debug3: Sent message SSH2_FXP_WRITE I:170 O:5472256 S:32768
debug3: In write loop, ack for 154 32768 bytes at 4947968
debug3: Sent message SSH2_FXP_WRITE I:171 O:5505024 S:32768
test2        31% 5376KB  96.4KB/s   02:04 ETAdebug2: channel 0: rcvd close
debug3: In write loop, ack for 155 32768 bytes at 4980736
debug2: channel 0: output open -> drain
debug2: channel 0: close_read
debug2: channel 0: input open -> closed
Received disconnect from xxx.xxx.xxx.xxx: 11: ssh disconnect by application
je n'ai pas la main sur le serveur distant qui est un windows.
Généralement, le transfert s'arrête entre 2 et 3 Mo (l'exemple est donc exceptionnel  :o )
Le sftp est lancé sans option particulière et en face, on me dit que "tout est OK".
j'ai l'impression que le client sftp reçoit beaucoup de "rcvd adjust 32768" mais je ne vois pas trop quoi y faire pour le moment.
Vous en pensez quoi ?
  réseaux et sécurité
probleme reconnaissance port usb sur ubuntu + driver CG ATIProblème accès disque sous ubuntu
Problème installation nconf sous redhat 4 ELProblème de conflit de slots [Gentoo] ou un truc du genre apparemment
Sendmail : GROS probleme de relayProbleme de grub
Probleme courrier POP - UIDL mailsProblème de transfert sFTP/SSH entre 2 Ubuntu
Problème vitesse de transfert sftpProbleme SFTP
Plus de sujets relatifs à : Problème de put en SFTP
