3629 connectés
  Linux et OS Alternatifs
  réseaux et sécurité
  Probleme de deconnection ( neufbox + mdk10.1 off)
n°652951
Crazy141
Posté le 21-03-2005 à 18:09:26  profilanswer
Bonjour a tous,
J'ai branché ma neufbox il y a peu et je deconnecte tres regulierement, j'utilise une carte reseau ethernet.
Je n'ai pas ce probleme sous Win.
n°652962
YupYup
Non.
Posté le 21-03-2005 à 18:24:38  profilanswer
Tu as consulté tes logs ?
"The marketing guys said the HP-35 would be a failure because it was too small, and then we couldn't make them fast enough to meet the demand. The marketing folks don't know everything." - Bill Hewlett
n°652984
Crazy141
Posté le 21-03-2005 à 18:44:45  profilanswer
voici les logs:
Mar 20 18:41:24 localhost pppd[8557]: No response to 3 echo-requests
Mar 20 18:41:24 localhost pppd[8557]: Serial link appears to be disconnected.
Mar 20 18:41:30 localhost pppd[8557]: Connection terminated.
Mar 20 18:41:30 localhost pppd[8557]: Connect time 137.7 minutes.
Mar 20 18:41:30 localhost pppd[8557]: Sent 107184519 bytes, received 847038122 bytes.
Mar 20 18:41:30 localhost pppoe[8558]: read (asyncReadFromPPP): Session 4726: Input/output error
Mar 20 18:41:30 localhost pppoe[8558]: Sent PADT
Mar 20 18:41:30 localhost pppd[8557]: Using interface ppp0
Mar 20 18:41:30 localhost pppd[8557]: Connect: ppp0 <--> /dev/pts/1
Mar 20 18:42:01 localhost pppd[8557]: LCP: timeout sending Config-Requests
Mar 20 18:42:01 localhost pppd[8557]: Connection terminated.
Mar 20 18:42:01 localhost pppd[8557]: Connect time 137.7 minutes.
Mar 20 18:42:01 localhost pppd[8557]: Sent 107184519 bytes, received 847038122 bytes.
Mar 20 18:42:01 localhost pppd[8557]: Using interface ppp0
Mar 20 18:42:01 localhost pppd[8557]: Connect: ppp0 <--> /dev/pts/3
Mar 20 18:42:05 localhost pppoe[9504]: Timeout waiting for PADO packets
Mar 20 18:42:12 localhost net_monitor[9589]: running: kdesu --ignorebutton -c /sbin/ifup ppp0
Mar 20 18:42:32 localhost pppd[8557]: LCP: timeout sending Config-Requests
Mar 20 18:42:32 localhost pppd[8557]: Connection terminated.
Mar 20 18:42:32 localhost pppd[8557]: Connect time 137.7 minutes.
Mar 20 18:42:32 localhost pppd[8557]: Sent 107184519 bytes, received 847038122 bytes.
Mar 20 18:42:32 localhost pppd[8557]: Using interface ppp0
Mar 20 18:42:32 localhost pppd[8557]: Connect: ppp0 <--> /dev/pts/1
Mar 20 18:42:36 localhost pppoe[9574]: Timeout waiting for PADO packets
Mar 20 18:43:03 localhost pppd[8557]: LCP: timeout sending Config-Requests
Mar 20 18:43:03 localhost pppd[8557]: Connection terminated.
Mar 20 18:43:03 localhost pppd[8557]: Connect time 137.7 minutes.
Mar 20 18:43:03 localhost pppd[8557]: Sent 107184519 bytes, received 847038122 bytes.
Mar 20 18:43:03 localhost pppd[8557]: Using interface ppp0
Mar 20 18:43:03 localhost pppd[8557]: Connect: ppp0 <--> /dev/pts/3
Mar 20 18:43:07 localhost pppoe[9655]: Timeout waiting for PADO packets
Mar 20 18:43:34 localhost pppd[8557]: LCP: timeout sending Config-Requests
Mar 20 18:43:34 localhost pppd[8557]: Connection terminated.
Mar 20 18:43:34 localhost pppd[8557]: Connect time 137.7 minutes.
Mar 20 18:43:34 localhost pppd[8557]: Sent 107184519 bytes, received 847038122 bytes.
Mar 20 18:43:34 localhost pppd[8557]: Using interface ppp0
Mar 20 18:43:34 localhost pppd[8557]: Connect: ppp0 <--> /dev/pts/1
Mar 20 18:43:38 localhost pppoe[9689]: Timeout waiting for PADO packets
Mar 20 18:44:05 localhost pppd[8557]: LCP: timeout sending Config-Requests
Mar 20 18:44:05 localhost pppd[8557]: Connection terminated.
Mar 20 18:44:05 localhost pppd[8557]: Connect time 137.7 minutes.
Mar 20 18:44:05 localhost pppd[8557]: Sent 107184519 bytes, received 847038122 bytes.
Mar 20 18:44:05 localhost pppd[8557]: Using interface ppp0
Mar 20 18:44:05 localhost pppd[8557]: Connect: ppp0 <--> /dev/pts/3
Mar 20 18:44:06 localhost net_monitor[9589]: running: kdesu --ignorebutton -c /sbin/ifup ppp0
Mar 20 18:44:09 localhost pppoe[9722]: Timeout waiting for PADO packets
Mar 20 18:44:36 localhost pppd[8557]: LCP: timeout sending Config-Requests
Mar 20 18:44:36 localhost pppd[8557]: Connection terminated.
Mar 20 18:44:36 localhost pppd[8557]: Connect time 137.7 minutes.
Mar 20 18:44:36 localhost pppd[8557]: Sent 107184519 bytes, received 847038122 bytes.
Mar 20 18:44:37 localhost pppd[8557]: Using interface ppp0
Mar 20 18:44:37 localhost pppd[8557]: Connect: ppp0 <--> /dev/pts/1
Mar 20 18:44:40 localhost pppoe[9755]: Timeout waiting for PADO packets
Mar 20 18:45:08 localhost pppd[8557]: LCP: timeout sending Config-Requests
Mar 20 18:45:08 localhost pppd[8557]: Connection terminated.
Mar 20 18:45:08 localhost pppd[8557]: Connect time 137.7 minutes.
Mar 20 18:45:08 localhost pppd[8557]: Sent 107184519 bytes, received 847038122 bytes.
Mar 20 18:45:08 localhost pppd[8557]: Using interface ppp0
Mar 20 18:45:08 localhost pppd[8557]: Connect: ppp0 <--> /dev/pts/3
Mar 20 18:45:12 localhost pppoe[9830]: Timeout waiting for PADO packets
Mar 20 18:45:39 localhost pppd[8557]: LCP: timeout sending Config-Requests
Mar 20 18:45:39 localhost pppd[8557]: Connection terminated.
Mar 20 18:45:39 localhost pppd[8557]: Connect time 137.7 minutes.
Mar 20 18:45:39 localhost pppd[8557]: Sent 107184519 bytes, received 847038122 bytes.
Mar 20 18:45:39 localhost pppd[8557]: Using interface ppp0
Mar 20 18:45:39 localhost pppd[8557]: Connect: ppp0 <--> /dev/pts/1
Mar 20 18:45:43 localhost pppoe[9863]: Timeout waiting for PADO packets
Mar 20 18:46:09 localhost net_monitor[9589]: running: kdesu --ignorebutton -c /sbin/ifup ppp0
Mar 20 18:46:10 localhost pppd[8557]: LCP: timeout sending Config-Requests
Mar 20 18:46:10 localhost pppd[8557]: Connection terminated.
Mar 20 18:46:10 localhost pppd[8557]: Connect time 137.7 minutes.
Mar 20 18:46:10 localhost pppd[8557]: Sent 107184519 bytes, received 847038122 bytes.
Mar 20 18:46:10 localhost pppd[8557]: Using interface ppp0
Mar 20 18:46:10 localhost pppd[8557]: Connect: ppp0 <--> /dev/pts/3
Mar 20 18:46:14 localhost pppoe[9897]: Timeout waiting for PADO packets
Mar 20 18:46:41 localhost pppd[8557]: LCP: timeout sending Config-Requests
Mar 20 18:46:41 localhost pppd[8557]: Connection terminated.
Mar 20 18:46:41 localhost pppd[8557]: Connect time 137.7 minutes.
Mar 20 18:46:41 localhost pppd[8557]: Sent 107184519 bytes, received 847038122 bytes.
Mar 20 18:46:45 localhost pppoe[9959]: Timeout waiting for PADO packets
Mar 20 18:46:45 localhost pppd[8557]: Connect time 137.7 minutes.
Mar 20 18:46:45 localhost pppd[8557]: Sent 107184519 bytes, received 847038122 bytes.
Mar 20 18:46:45 localhost pppd[8557]: Exit.
Mar 20 18:46:50 localhost pppd[10009]: pppd 2.4.2 started by root, uid 0
Mar 20 18:46:50 localhost pppd[10009]: Using interface ppp0
Mar 20 18:46:50 localhost pppd[10009]: Connect: ppp0 <--> /dev/pts/1
Mar 20 18:47:11 localhost net_monitor[9589]: running: kdesu --ignorebutton -c /sbin/ifup ppp0
Mar 20 18:47:21 localhost pppd[10009]: LCP: timeout sending Config-Requests
Mar 20 18:47:21 localhost pppd[10009]: Connection terminated.
Mar 20 18:47:21 localhost pppd[10009]: Using interface ppp0
Mar 20 18:47:21 localhost pppd[10009]: Connect: ppp0 <--> /dev/pts/3
Mar 20 18:47:21 localhost pppoe[10078]: PADS: Service-Name: ''
Mar 20 18:47:21 localhost pppoe[10078]: PPP session is 7619
Mar 20 18:47:23 localhost pppd[10009]: CHAP authentication succeeded: CHAP authentication success, unit 8605
Mar 20 18:47:23 localhost pppd[10009]: local IP address XX.XXX.XX.XXX
Mar 20 18:47:23 localhost pppd[10009]: remote IP address XX.XXX.XX.X
Mar 20 18:47:23 localhost pppd[10009]: primary DNS address XX.XXX.XXX.XXX
Mar 20 18:47:23 localhost pppd[10009]: secondary DNS address XX.XXX.XXX.XX
Pour pouvoir me connecter je debranche/rebranche la neufbof
n°653622
Crazy141
Posté le 22-03-2005 à 19:45:49  profilanswer
Ca inspir personne???
n°655804
YupYup
Non.
Posté le 28-03-2005 à 14:03:51  profilanswer
La neufbox c'est juste un modem adsl ? Parce que si c'est un routeur transparent il n'y a pas besoin d'utiliser pppoe.
  réseaux et sécurité
chtites probleme ....diver et varie[script] Problème de su dans mon script
probleme fichiers passwd et shadow videsproblème avec archive tar.gz et clock
Probleme de droits utilisateur pour le partageProblème lancement/installation kde
probleme installation red hat 9.0problème bizarre de son sous mandrake 10.1
probleme de BootLoader avec SuSE 9.2probleme d'installation gaim 1.1.4
Plus de sujets relatifs à : Probleme de deconnection ( neufbox + mdk10.1 off)
